Old 13th October 2004, 02:14   #1
Deeps's Avatar
Thanked: 68 Times
i have a query regarding my CLio. Its done 66,000km here in Paris. Abt 2 weeks ago i noticed a mild whistling noise coming from the engine. Back then i ignored it. Now, its occuring more frequently. The sound is not very loud and can only be heard if the music is off. It occurs between 2500 and 3500 rpm in the first 4 gears and neutral (haven't tried in 5th yet). the car is also due for a service. What could be the reason for this and is it anything major?? i suspect its a belt that has become loose or misaligned..
Deeps is offline   Reply With Quote
Old 13th October 2004, 02:55   #2
just guessing here : If the belt is loose I think the sound would increase as you revved up and stop as you take your foot off the accelerator.
otherwise leakage in the air intake ? or something stuck in the radiator fan ?
zaphod
zaphod is offline   Reply With Quote
Old 13th October 2004, 04:46   #3
Shan2nu's Avatar
Thanked: 89 Times
I've heard a few SUVs here that make such sounds. It could be the belt. Why don't you get it checked at the dealer itself.
i must say, it's surprising to know that the Clio should have such problems.
Shan2nu
Old 13th October 2004, 04:51   #4
Shan2nu's Avatar
Thanked: 89 Times
Speaking of Clio, i recently did a F1 version of the Clio V6 using Photoshop. Check out the link below........
Photoshopped Clio V6
Shan2nu
Old 13th October 2004, 10:52   #5
Thanked: 103,712 Times
I dont know much about Clios..but...um, TURBO?
Old 13th October 2004, 13:25   #6
Domnic's Avatar
Do you have the clio V6?? 0-100 6.4secs
Belt im not so sure, coz belts do usually make a screeching noise. is it a whining noise???
Dom
PS: How is engine noise is your car condidering the engine is behind you??
Domnic is offline   Reply With Quote
Old 13th October 2004, 14:12   #7
Deeps's Avatar
Thanked: 68 Times
Its not the V6 version. I wish it was. Its just the regular 1.4 petrol engine. Thanx for the help. I'll get it checked this weekend.
Old 24th November 2005, 01:18   #8
Deeps,
Any solution to your problem? I am facing the same issue with my 1.6 Accent. Wanted to see if I am worried for nothing.
zabcd is offline   Reply With Quote
Old 24th November 2005, 08:08   #9
sajo's Avatar
Thanked: 1,064 Times
As mentioned in this thread (Need Tips for restoring M800.) I am too experiencing the same whooshing (whistling?) sound from my 800. Is it very serious ?
sajo is offline   Reply With Quote
Old 24th November 2005, 09:50   #10
sandeepmdas's Avatar
Thanked: 716 Times
Regarding the 800, there is 99 per cent chance that it is belt noise. I dont know anything about the french beauty. But, c'aussi a pu Ítre bruit de ceinture, (courtesy google).
sandeepmdas is offline   Reply With Quote
Old 24th November 2005, 18:06   #11
Deeps's Avatar
Thanked: 68 Times
Guys it turned out to be related to a small leak in the radiator somehow. And if its the belt in the 800, i guess tightening the belt should help....and this is not an expensive/time consuming procedure. Sandeep, lol, good effort with the french.
Whistling noise in AC vents bdubya Technical Stuff 3 21st January 2010 23:32
Whistling Outside Rear View Mirror rex_varghese Technical Stuff 13 22nd December 2008 17:02
Funny Whistling Sound in Scorpio gd1418 Technical Stuff 27 5th December 2008 12:09
Whistling Soung from Blower mobike008 Technical Stuff 9 21st February 2008 01:05
whistling sound Thomas T Technical Stuff 3 14th December 2007 10:15
