Old 18th April 2016, 17:26   #31
Thanked: 114 Times
Default Re: Converted my Santro Automatic to Manual!
You cant imagine The amount of problems dirty oil or an improper amount of oil can cause to an auto trans. They probably never gained popularity in india because the auto cos besides the FE disadvantage realised the extremely poor upkeep that is prevelant in the indian market.
Ive seen symptoms exactly like yours get cured simply by a complete oil and oil filter change. Not once but many times. I really think, your mechanic isnt as good as you think he is. If you read around international AT forums you'll realise the same
AT's are very durable infact, due to their basic construction they are seldom subjected to shocks/impacts of anykind. the only wear part are the brake bands and they too can easily cross lakh(s). had you probably stuck to getting your car serviced at hyundai, youd still be driving an AT.
if you still have the parts and they werent damaged in taking them off i think they are worth a second chance. costs next to nothing in labour to remove a trans and reinstall.
let me reiterate. Even if your oil level is ok, old oil alone can cause an AT trans to slip.
mycarhasablower is offline   Reply With Quote
Old 1st June 2016, 00:33   #32
Thanked: 31 Times
Originally Posted by Rahul Rao View Post
There are local mechanics who repair AT boxes and torque converters in most major cities. I know two aftermarket experts in Pune. One of them is actually a lathe and turning shop owner, and requires a auto mechanic to dismantle the converter which he repairs and hands back for reassembly.
Rahul
I think my torque converter in my 2003 XG has failed just a few hours ago, exactly as described earlier in the thread, at odometer reading of 76234 Km. I would like to retain my car as an automatic and therefore I would be highly obliged if you could let me know if I could get the torque converter sent across to your Lathe guy for reconditioning ? Kindly share the details with me and the likely costs at the machine shop. Thanks.
Karadi is offline   Reply With Quote
User Manual / Service Manual for ICE & other accessories Mr.Boss In-Car Entertainment 5 6th July 2012 12:21
Tube-Type Tyres Converted to Tubeless - Is it safe? bhp Tyre & Alloy wheel Section 46 7th March 2010 20:52
Tube tyres converted into tubeless - Is it possible and safe?? Deeps Tyre & Alloy wheel Section 3 28th September 2007 20:22
WagonR (automatic) or Santro (automatic) Blue Thunder Hatchbacks 6 24th August 2007 08:39
Sonata converted to Limo. pdev29 Shifting gears 5 26th May 2006 23:29
