Old 1st October 2004, 23:34   #16
speedsatya's Avatar
Thanked: 706 Times
Originally Posted by [b
Quote[/b] (SLK @ Oct. 01 2004,18:43)]I don't quite understand why does it knock!... and neither do MASS guys!! (they have no clue)
I would have got the IAC changed if it was available separately..... *they say .. u got to buy the whole throttle body for 5k. And that would be a gamble as i can see their capabilities.
hey slk,
a similar type of problem of knocking and poor pick up in a wagon r was solved by adjusting the timing,the tappet settings .
the idling can be set right by lubricating the throttle body.
isnt ur vehicle under warranty.or if u have an extended warranty for the 3rd and 4th year u can get ur faulty part replaced free .
speedsatya.
speedsatya is offline   Reply With Quote
Old 2nd October 2004, 02:13   #17
SLK
SLK's Avatar
Thanked: 185 Times
.. nope.... no warranty....
and somehow.. the pickup... is very decent... ... only problem.. is.. 4th, 5th gear 4000+rpm...... otherwise its quite fast.
Quote[/b] ]the idling can be set right by lubricating the throttle body
will check this out too...
SLK is offline   Reply With Quote
Old 2nd October 2004, 02:21   #18
RJK
RJK's Avatar
Thanked: 16 Times
Quote[/b] (SLK @ Oct. 01 2004,21:55)]The screen was displaying O2 sensor readings..... and the guy says... this shows how much your car is polluting right now * *and * this is how we check pollution..
Knocking... when they can't solve it they say ... some knocking is good for fuel efficiency.
When will these people ever learn !
RJK is offline   Reply With Quote
Old 2nd October 2004, 17:16   #19
normally_crazy's Avatar
Thanked: 387 Times
Quote[/b] ]some knocking is good for fuel efficiency
knocking these guys around is good for their brain's too.. tell them !!!
maan what kinda people we have in the service stations !!!!
and they wont listen to you , they go on as if they r the last word on these matters !! baah !!
normally_crazy is offline   Reply With Quote
Old 2nd October 2004, 21:05   #20
Rudra Sen's Avatar
Thanked: 4,092 Times
Quote[/b] (normally_crazy @ Oct. 02 2004,15:46)]maan what kinda people we have in the service stations !!!!
and they wont listen to you , they go on as if they r the last word on these matters !! *baah !!
When I was checking with Sundaram Motors that after completing 5000km, I want to put MOBIL1 and I need a complete engine flushing by them...the reply was very promt.
"Sir we cannot do that. GM as a policy don't recommend any other consummables other than what we use. And why do you want to do that? You're violating the service rule. If you go for any other oil.. Sir, we won't be responsible and so is GM."
I came back and sent a mail to GM's customer service.
The reply came within half hour saying there is no issue using Mobil1 and infact they believe it's the best available. The reason why they don't recommend is due to high price tag.
They'll inform Sundaram Motors as and when I'm ready for a oil change.
Old 2nd October 2004, 23:38   #21
X-Machine's Avatar
Thanked: 11 Times
Just remembered one of my funny knocking instances during my esteem days.
I had this problem and drove the car to SaiService at lower parel.And guess wot crap they told me....
Sir,its either cos of less amount of fuel in the car or due to faulty tyres.We recommend to empty the present fuel and fill in a whole tank and see if the problem still persists.
[img]http://www.team-bhp.com/iB_html/non-cgi/emoticons/***.gif[/img]
Just walked out and gave the car to my local mechanic who cleared up the fault in a couple of hours.
How unprofessional can these guys get.
X
X-Machine is offline   Reply With Quote
Old 3rd October 2004, 18:23   #22
Thanked: 387 Times
Quote[/b] ]When I was checking with Sundaram Motors that after completing 5000km, I want to put MOBIL1 and I need a complete engine flushing by them...the reply was very promt.
should i do the same with my ikon ??
Old 3rd October 2004, 18:24   #23
Thanked: 387 Times
change the oil to mobil i mean !!
Old 3rd October 2004, 19:20   #24
Rudra Sen's Avatar
Quote[/b] (normally_crazy @ Oct. 03 2004,16:54)]change the oil to mobil i mean !!
Without thinking twice
Old 4th November 2004, 04:25   #25
SLK
SLK's Avatar
Thanked: 185 Times
Quote[/b] (Rudra Sen @ Oct. 02 2004,19:35)]I want to put MOBIL1 and I need a complete engine flushing
So we have to do more than we do while normal oil changing!
Since i am planning to get mobil 1 in wagonR
Is it really required to flush (not just drain out)?
How much time does it take!... (I don't have time! )
I'll just be going for a oil change. and nothing else!!
Old 4th November 2004, 04:34   #26
X-Machine's Avatar
Thanked: 11 Times
Hey SLK.It takes bout 20-40mins to get the flushing done.Not that time consuming and it surely helps.It is highly recommended to better the cars performance.
Take some time out and get it done perfectly.
X
RPM Surges-Throttle Body Cleaning wolfinstein Technical Stuff 29 6th October 2009 08:12
Hi all who love to Kick Throttle kick.throttle Introduce yourself 0 21st August 2006 16:20
130mph, throttle stuck, then brakes fail. What do you do? bigman Shifting gears 35 18th March 2006 00:53
