Thread Tools
Old 28th September 2004, 22:16   #1 (permalink)
X-Machine's Avatar
Hey all.
I`ve heard bout this throttle thingy a lot of times since the past one week.One of my friend recently got a throttle installed in his Lancer,and said the performance has improved.
Now,i dunt really know wot this throttle does to the engine.
Also do u need a TC if u have a throttle??
Can sumbody help me out in understanding wot is it and how does it function.
Thanks.
X
__________________
------->> X <<-------
X-Machine is offline   Reply With Quote
Old 28th September 2004, 23:37   #2 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
According to Penguin dictionary throttle as a noun means the valves in the engine to regulate the supply of gas.
Throttle as a verb means to suppress shut off power of the engine and so lessen speed.....
Anybody (can use?) it as a name as you've experienced
Old 29th September 2004, 01:55   #3 (permalink)
F50
Team-BHP Moderator
F50's Avatar
Originally Posted by [b
Quote[/b] (Rudra Sen @ Sep. 28 2004,22:07)]According to Penguin dictionary throttle as a noun means the valves in the engine to regulate the supply of gas.
Now thats what I called Text Book stuff
__________________
F50
When in doubt, throttle out.
F50 is offline   Reply With Quote
Old 29th September 2004, 03:14   #4 (permalink)
SLK
SLK's Avatar
.. all I know is...
every car has a throttle
its just a ... valve or shutter... or what ever u might call it.
its connected.. to the accelerator cable.. harder u push .. the more it opens.. and allows more air into the engine.
The complete thing is called a throttle body... its the whole system.
my alto's was changed by maruti for free .. without any complaint from our side (they said there was a problem with that batch).
my wagonR's throttle body has a deffective valve (not the main door, just a side valve)... b'coz of which the idle rpm is not completely smooth. (5% problem).... they say whole throttle body has to be changed... for 5k.... i say .. go to hell.
I think.. your friend must have got, say a modified throttle... for more .. performance... maybe..
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Old 29th September 2004, 12:24   #5 (permalink)
Domnic's Avatar
Well a throttle as rudra mentioned is used to control the flow of gas, in a car this controls the amount of air entering the engine on the intake stroke, more air = more power and more revs, Its simply a butterfly valve. Now in Fuel Injected cars we have something called a throttle body.
The throttle body is a housing where the valve (butterfly) is housed. It also has added sensors like the TPS (throttle position sensor) and a IAC valve ( Idle Air Control).
Now, Most cars out from the company have preset butterfly sizes, like an MPFI Zen has a 47mm or so body and a Esteem 51mm. By increasing this butterfly size you can increase engine response and inturn get a bit of power too as it reduces restriction. The Lancer responds very well to this mod, you can increase a lancers upto 66mm (requires a bit of modification). You can expect upto 14hp by this mod. And by doing this other mods like NOS, Filter and TC etc will work better.
Hope this answers your q.
CHeers
Dom
__________________
Dom@Team-Bhp.Com
Domnic is offline   Reply With Quote
Old 29th September 2004, 22:16   #6 (permalink)
X-Machine's Avatar
Thanks for the response guys.
Dominic got ur explanation perfectly.But i have a few querries regarding this.
1. Will the increase in buttefly size affect the performance in any other way??Like a drop in FE or performance over the time.
2. And also,if this mod is done with just the free flow and air filter in the car,will it respond well?
Thanks.
X
__________________
Old 30th September 2004, 19:38   #7 (permalink)
SLK
SLK's Avatar
Hey Domnic.. thanks for that explanation....
I also would like to know a bit about the IAC valve.
Since my car's IAC valve is not functioning properly, would it affect the engine in any other state i.e. while its running and not idleing
See my car has a knocking probelm... and after all types of tuning and fuel it doesn't go away. So is there any role an IAC value could play in knocking?
SLK
__________________
Č╠╣€€Я$
$£Қ
Old 30th September 2004, 22:13   #8 (permalink)
Domnic's Avatar
First to answer Xmachine:
1) Yes FE will drop in extreme conditions. As engine breathing will be easier, more air means more fuel.
2) With just the free flow and air filter i will respond pretty good, but it will be better if good porting has been done, over size valves etc.
SLK
Strange that the IAC is not functioning properly. Does the car idle at all? what are the exact symptoms?.
The IAC's work is just to keep enough air flowing to idle the car well when the throttle body (butterfly) is not open. Once accelerating (pressing the throttle) the IAC has no work. So its not of any concern when running.
Now on the knocking part : .... The IAC wont play any role in this at all... but if the valve is not opening correctly it can create a huge restriction, which will lower the idle dramatically which you will feel by heavy vibration. Get the IAC repaired else go to the local scrap yard and pick up one from a throttle body assembly etc. WHich car do you have?. Does the engine pink only on hard acceleration or always?. What is the ignition timing set at?
Dom
__________________
Dom@Team-Bhp.Com
Old 30th September 2004, 22:20   #9 (permalink)
X-Machine's Avatar
Ahhh.Got it perfectly.
Thanks Dom.
X
__________________
Old 30th September 2004, 23:33   #10 (permalink)
SLK
SLK's Avatar
I have a wagon R 2000 model
My IAC valve had failed (according to MASS) 1.5 years after buying the car. It was already out of warranty by then.
My Car idles almost perfectly.... with very slight vibrations. But the problem comes when you suddenly switch on something... like the a/c The engine vibrates badly for a while and then feels a bit better.. but still not very smooth.
Well its not just the a/c ... every electrical equipment makes the engine vibrate... but of course not as bad as the a/c.
My point is.. the engine is at the 900rpm alright, but weak.
Remember in Wagon R the a/c doesn't open the throttle for running ... it runs at idle rpm only.
well.. knocking...
it knocks only under hard acceleration.... rather say it knocks the moment you cross 3500rpm mark (approx).
Its like.... 5th gear ... it starts knocking .. if u go over 115km/h.
.. I don't really know about the ignition timing... but I believe its perfect as per maruti!... I make it a point to remind those guys to set it properly.
One more point.... there is certain valve noise from the engine, which doesn't go no matter how many times I get the clearances adjusted (maybe its normal).
thats about it all
__________________
Č╠╣€€Я$
$£Қ
Old 1st October 2004, 15:13   #11 (permalink)
reading the postings, my experience has been that a lot of vibration issues on acceleration are due to the poor quality air filter used in indian cars (incl legal imports). to solve the problem on the GTX Palio, i switched to the standard K&amp;N filter replcament - and made a big difference to the ride. the clean aceleration, no idling/running jerks, low resistance allowing longer roll. check it out before you make major changes on mechanicals. cheerz
__________________
pbajaj/mumbai/FIAT GTX
auto is offline   Reply With Quote
Old 1st October 2004, 19:43   #12 (permalink)
Domnic's Avatar
Hi SLK,
* * No performance filters aint goin to solve your problem. You say the car idles perfect. When you switch on the ac, the iac valve is supposed to open further and increase idle to support the accessory. But in your case this is not happening. Im not sure of the wagon r system, as i mentioned either the IAC should open to a further extent raising the idle, but there are systems on older cars where a air solenoid valve is present which opens when the ac is switched on, allowing more air enter the engine and thus increasing idle. where are you located slk??
About your knocking.... really strange that your car knocks, just check if the vaccum line running to the distributor is not blocked. Also have your distributor checked as the problem may lie in it. As these cars will automatically advance on acceleration. I feel somehow this mechanism is not working in your case and your distributor is not pulling timing causing the knock after a particular rpm. Have the MASS check this and i think the problem will solve.
Dom
__________________
Dom@Team-Bhp.Com
Old 1st October 2004, 20:13   #13 (permalink)
SLK
SLK's Avatar
Thanks Dom...
I will get it checked at a workshop owned by Maruti for one last time at the next service... .. BTW I am in Delhi.
The problem.. is... Wagon R .. has got too complex for the MASS guys to understand ...LOL
16 valves .. they are scared to even touch the clearances.
There's no distributor... its digital ignition.
I don't quite understand why does it knock!... and neither do MASS guys!! (they have no clue)
Since we also own an Alto Vxi... exactly same engine... and it doesn't knock.. or vibrate.... I give this e.g. to MASS ... and they just don't seem to get it.
Well in day-to-day running.. i don't go more than 3500 rpm.. so knocking is not an issue... but i have to get rid of it.. anyways.
I would have got the IAC changed if it was available separately..... they say .. u got to buy the whole throttle body for 5k. And that would be a gamble as i can see their capabilities.
__________________
Č╠╣€€Я$
$£Қ
Old 1st October 2004, 20:37   #14 (permalink)
Team-BHP Moderator
Rtech's Avatar
Hey SLK,
what fuel are you using? Do you fill up from the same pump everytime? If so, try using 93 octane and see if there's a difference. Or else maybe its the knock sensor thats gone kaput! With the right scanners (which I hope MASS has), its really a simple job to check if these sensors are working. The problem lies with the person reading the screen! If he doesn't know what to look for, the scanner is not gonna be much help.
Another thing, You say when you turn your AC on, it vibrates badly and then smoothens out. How long does it take to smoothen out? Is it in an instant or are we talking a few minutes here? If its just a few seconds before it smoothens out, I don't think its much of a problem. Have you checked the AC compressor and engine mountings? Loose mounts or a couple of loose bolts could be the culprit here.
Rt
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 1st October 2004, 23:25   #15 (permalink)
SLK
SLK's Avatar
Hi rtech
I have used all fuels...... speed, power, josh, premium, Xtra premium, Speed 93.. .. and the regular
Speed 93 is the best with Xtra premium close second... i can feel the difference with 93. Again.. it reduces.. knocking.. but.. its still there on hard acceleration.
Yes my car vibrates for just a second or maybe 2 at most. and then back to normal (with a/c is slightly harsh)
I did get the compressor checked... it was fine.
Once I sat with the MASS guy with his palmtop plugged into my car. It shows a lot of information. BUT as you rightly said...
Quote[/b] ]The problem lies with the person reading the screen
The screen was displaying O2 sensor readings..... and the guy says... this shows how much your car is polluting right now and this is how we check pollution..
Anyways, I switched on the a/c and the rpm in the palmtop dropped to 650+ just for a sec.. and then back to 850-900.
Knocking... when they can't solve it they say ... some knocking is good for fuel efficiency.
I don't really expect much for MASS after so many of such instances at different service stations.
__________________
Č╠╣€€Я$
$£Қ
Thread Tools
Throttle body cleaning amit_mechengg Technical Stuff 36 16th February 2008 12:28
Throttle Body Bypass 1self Modifications & Accessories 3 7th September 2007 14:31
Throttle opening....and Greetings get_hiyyer_714 Introduce yourself 8 13th August 2007 17:28
Motorized throttle intake..what is it? Nimz Technical Stuff 10 13th June 2007 21:20
Hi all who love to Kick Throttle kick.throttle Introduce yourself 0 21st August 2006 16:20
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
