Closed Thread
Old 13th September 2007, 08:00   #181
vikram_d's Avatar
Thanked: 940 Times
Finally I know. Thanks tsk. But dont you think that this was true for normal tyres and not tubeless radials?
Tubeless radial are much stronger than normal tyres and also if you just fill to manufacturers recommended pressure than you should not face any problems. Do you agree?
vikram_d is offline
Old 13th September 2007, 08:58   #182
Thanked: 253 Times
Yes, that should be OK, theoretically. Problem is that a lot of pertol pumps have poorly maintained/uncalibrated gauges at their air station. Since under-inflation can be very dangerous, it is wiser to keep a 'margin' in hand and fill up a wee bit extra. If you have your own, reliable gauge, by all means stay with recommended pressure.
anupmathur is offline
Old 13th September 2007, 09:16   #183
vikram_d's Avatar
Thanked: 940 Times
Well I have my own gauge and I also use a tyre pressure monitoring system in my car.
So for me manufacturer recommendation it is. Thanks for clarifying guys.
vikram_d is offline
Old 13th September 2007, 09:36   #184
BWN
I am running a set of new Goodyear Eagles for my baleno and i inflate it with Nitrogen.
Advantage are Lower Deflation Rate(1 PSI per 2-3 Months) and and Nitrogen dosn't heat quickly like Compressed air, particularly on concrete roads.
I am maintaining 30 PSI though recomended is 29 PSI.Ride is a bit harder but has amaging road grip.I am planning to ride on 28-29 PSI sometime later.
BWN is offline
Old 13th September 2007, 12:29   #185
Thanked: 253 Times
If expansion of N2 is less than compressed air (for whatever reason), it would be ill advised to reduce pressure below the recommended value. At highway speeds the excessive flexing (because of N2 not expanding as much as compressed air) of the sidewalls might lead to blowout. At the very least the temps the tyres will have to endure would be higher, leading to accelerated wear.
Old 16th September 2007, 23:35   #186
Can someone let me know where in Bangalore (preferably South Bangalore) do they offer Nitrogen filling ?
Ches
cdcruz is offline
Old 17th September 2007, 12:05   #187
jassi's Avatar
Thanked: 11 Times
Smile
I have only seen it in one place - which is Madhus tires under the flyover near Divyashree chambers
jassi is offline
Old 17th September 2007, 18:54   #188
Nikhilb2008's Avatar
Thanked: 6,661 Times
It is under the richmond road flyover (from double road side).
Nikhilb2008 is offline
Old 17th September 2007, 18:56   #189
Originally Posted by bottle View Post
sorry missed your post.. i guess its undercalibrated as well or that i need to reduce psi a bit.
regarding tyres i wore the fronts out real bad during track day so replaced them alone
just filled nitrogen and find the ride a lot more harder than air can really feel the bumps and ride is a bit bouncy .. tyres also feel quite hard now compared to when it was on air. filled at 28psi
front tubeless and back tubed , filled at xl tyre shop
What happened ?? Is it still too hard ??
PS: Come to Bangalore.... free nitrogen inflation for you :
Old 17th September 2007, 21:13   #190
Where in Delhi/Noida, do I get to fill Nitrogen for free ? Any members know of any Petrol pumps that offer it and are functional ?
Shankyz is offline
Old 17th September 2007, 22:31   #191
Eddy's Avatar
Thanked: 5,078 Times
Have seen one in Dwarka, if that helps
EDIT: Oops, just read yr post again. The dwarka guy charges 20 bucks. Not sure if thats per tyre or for the entire set
Eddy is online now
Old 17th September 2007, 22:42   #192
It has to be per tyre....
Old 6th November 2007, 11:56   #193
The Indian Oil COCO pump right opposite Hyatt New Delhi is currently offering it free of charge.You may just tip the attendant if you wish
pujaari is offline
Old 6th November 2007, 14:48   #194
Does anyone know whether it is available in Hyderabad? If yes then where is it?
varma is offline
Old 18th November 2007, 22:55   #195
kaps_loves_fiat's Avatar
any filling station in mumbai??
kaps_loves_fiat is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
