Closed Thread
Old 4th December 2007, 09:30   #211
tsk1979's Avatar
Thanked: 16,422 Times
Originally Posted by Harbir View Post
I'd like to see scientific evidence of the difference that wet vs dry air makes in the real world.
I think any scientific textbook will tell you that moist air will expand more.
With Nitrogen(only way to have dry air in your tires) the PSI difference between hot and cold is very less.
Just do a search and you will find my post a few pages back.
I got nitrogen filled just once, because it was free, and I was in that area of town.
Its not worth it to spend fuel and go there to get N2 filled. Paying for it is pretty useless unless you are going to track
tsk1979 is offline
Old 11th December 2007, 08:13   #212
Fillmore's Avatar
Thanked: 141 Times
I use dry air and find it much better than nitrogen. But not everybody has access to dry air.
Hi Vikram_d,
Since you are in Bangalore, could you please let us know where do you have access to dry air ?
Fillmore is offline
Old 11th December 2007, 18:53   #213
vikram_d's Avatar
Thanked: 940 Times
In my own factory, I have a air compressor coupled to an air dryer. Sadly not for public use.
vikram_d is offline
Old 15th December 2007, 08:52   #214
Fillmore's Avatar
Thanked: 141 Times
Have a query, appreciate it if someone can respond today, as I am free to get this corrected today
I have filled in Nitrogen for my Santro. The normal pressure for Santro Tyres is 30psi for air. However when filling Nitrogen the guy there said 28psi is the right pressure.
Is this correct, or should I stick to 30psi ? Found that with 28 the ground clearance also has come down a bit. (did not measure this though, maybe my imagination as well)
Fillmore is offline
Old 15th December 2007, 19:42   #215
hell boy's Avatar
Thanked: 9 Times
hey guyes i just filled nitrogen in my tyres today for 100rs for 5 tyres and think that its fine for the next 3 mths and let time go and nitrogen will get cheaper as it always happens with the market ups and downs in it.............
hell boy is offline
Old 16th December 2007, 13:07   #216
vikram_d's Avatar
Thanked: 940 Times
@Fillmore - 28 psi will do just fine for your santro. No need to worry. I dont think the ground clearance would have come down by much. It will just be a very small difference.
vikram_d is offline
Old 2nd January 2008, 09:08   #217
kARTIK IYER's Avatar
Thanked: 12 Times
Default Nitrogen for Tyres
Originally Posted by akole View Post
I would like to know if anyone has had the experience of filling dry nitrogen in their car tyres? The sales pitch says that dry nirtogen is a better choice as (a) nitrogen, having larger molecules, dissipates at a lower rate (than air) through the tube walls and (b) the lack of moisture in the nirogen keeps the tryres running cool.
Due to both, the trye pressure remains constant over larger periods (one needs to check pressure only after 6 months).
Any opinions would be welcome. Chennai has at least one such outlet.
Though i am replying late as have recently joined in but may be this info can still be of use . I have recently filled Nitrogen in all my tyres in my scorpio . It costed me INR 100 for 5 tyres . The advantage which i have realised till now is you tyre pressure does not drop infact atall till now . The ride is become more cushioned . I am sure there will be a positive impact on milieage beacuse of the tyre pressure.
kARTIK IYER is offline
Old 2nd January 2008, 11:27   #218
amit_mechengg's Avatar
Thanked: 1,556 Times
in pune some shops are pumping nitrogen...but how to determine whether its 95% or 100 % pure nitro....
they are costing 30Rs per tyre...
they claim, more F.E...less air refills, better handling..less tread wearout..and mainly safer long speedy drives on express highway
amit_mechengg is offline
Old 2nd January 2008, 11:43   #219
arunkumar_rec's Avatar
To me, Filling Nitrogen may not be a necessity unless you have a bad problem of tyre pressure dropping every week. My car tyre pressure doesn't drop at all for close to 15days from the stipulated 30PSI. Only once it dropped to 29PSI in 15 days. I fill full tank in my Getz every 15 days. I fill air at the same time. Who wants to pay 50bucks for N2 when air comes for free?
arunkumar_rec is offline
Old 2nd January 2008, 12:12   #220
sgiitk's Avatar
Thanked: 3,884 Times
I do not think Nitrogen is of any benefit in cars. As for dry air I have no problem since I use a portable compressor (12V lighter powered) which I use once a week. The little moisture picked up from the air is irrelevant. Nitrogen in used in Aircraft tyres, and may be F1 tyres. Have never heard of their widespread use in normal autos anywhere in th world.
I would advise your own compressor (Approx Rs.700-800) for three other reasons. Firstly, the tyres are inflated Cold. Secondly, when you have a flat the spare is almost invariably low or under inflated. Lastly, with a tubeless tyre you can pump it up to get to the nearest convenient point for wheel change/repair.
sgiitk is online now
Old 2nd January 2008, 14:16   #221
@sgiitk Which brand of the compressor do you use? And does it have auto cutoff once the required Pressure is achieved?
Old 2nd January 2008, 14:58   #222
sgiitk's Avatar
These are small (mostly unbranded) units of (presumably) Chinese origin (less than 7"x7"x12" weighing a couple of kg ar most), available at many accessory shops. They easily last 8-10 years.
They pump the tyres quite slowly and you switch them off when done. What I have found is that the gauges tend to fail and are unreliable. So I keep my own gauge separately. Both of my cars have an electric pump in the boot. I have used them for 10-15 years.
Earlier I kept foot pumps. Keeping a pump in the car dates back to 1973 or so.
Old 7th January 2008, 11:35   #223
vijit.gangwar's Avatar
Thanked: 67 Times
Originally Posted by aZa View Post
Dhruv i saw an advert in the newspaper saying Tyre shoppee in noida has Nitrogen for cars now!
Tyre Shoppe Noida charges Rs. 20.00 per tyre.
vijit.gangwar is offline
Old 14th January 2008, 16:07   #224
Thanked: 67 Times
Originally Posted by Eddy View Post
Have seen one in Dwarka, if that helps
EDIT: Oops, just read yr post again. The dwarka guy charges 20 bucks. Not sure if thats per tyre or for the entire set
Last Saturday i filled up nitrogen free of charge at the IOC Pump opposite Bikaji Cama Place on the ring road. He deflated the tyres & filled up with Nitrogen. He repeated the process twice upon my request.
Old 14th January 2008, 23:13   #225
rider60's Avatar
Thanked: 47 Times
please excuse me for not reading the previous pages i dint have the patience,
well my query is has any one ever filled nitrogen at ashoka wheels at minister in Hyderabad? is it dry nitrogen? and any experiences regarding filling the nitrogen there?
i have recently upgraded the Swift DDiS's alloys and shoes, and i have filled in nitrogen from there and they charged me 50bucks for each tyre including the spare tyre!
please do post any experience filling there! and are any other places in Hyderabad where they fill dry nitrogen?
rider60 is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
