Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 2nd August 2005, 16:24   #16 (permalink)
johnjacob's Avatar
Originally Posted by cheatingdeath
cant be penny wise pound foolish
if i dont have to check my tyre pressure fer 6 months nothing like it ...... and as rehaan said... less tyre wear and stuff.. so iwill savin on tyre maintainence tooo....but the only thing bothering me is there not many outlets supplying us with it... so in case of a puncture or soo...it will really diffficult
they should do some more research and push this concept further..get it to the commaners
Hmmm... Normal air is 70% nitrogen. So if you have to fill air every two weeks using air, then you will still have to fill every three weeks using Nitrogen. I don't think you can EVER afford to go for six months without filling up, no matter what gas you use!
Could help on the reducing tire wear, I suppose.
__________________
I have seen God... His name is Petter Solberg...
johnjacob is offline   Reply With Quote
Old 24th November 2005, 08:22   #17 (permalink)
jkdas's Avatar
any idea regarding the rates? I just in newspaper that its available at Trivandrum?
Is there any tbhpians who have used nitrogen?
__________________
Audio, video, disco
Tat tvam asi
Old 8th September 2006, 13:08   #18 (permalink)
jobinjv's Avatar
Default Re:
Searched and found this but no proper rply.. Wanna know if there is any where in chennai where it can be done..
Read in a post by zak that its perfect on his.. and its a tried and tested method
pls
jobinjv is offline   Reply With Quote
Old 8th September 2006, 14:47   #19 (permalink)
Very good thread!
I had been wanting to know more about Nitrogen in tires.
I saw an ad for the first time while I was munching away at a Mac, Kalamboli, before Panvel, Navi Mumbai (the one just before joining Mumbai - Pune Expressway, ).
The only thought that comes to my mind is what are the effects of a rubber body that is pressurised and lower in temperature on the inside and hotter on the outside, given the fact that rubber is a bad conductor of heat.
I have been trying to get an answer for this on the net.
Any of you?
__________________
...looking forward to sit a few feet above mean road level and away from potholes...
gbpscars is offline   Reply With Quote
Old 8th September 2006, 15:51   #20 (permalink)
I have filled Nitrogen in my Palio 1.2 at a tire shop called Madhu's Tire Center near Richmond circle. I refilled only after 3 months and there was no significant loss of tire pressure. The ride is better than when I filled in air. I do not see any change in the fuel economy. For the first time, it takes Rs. 20 to fill each tire. For any subsequent refill, just a tip to the person who fills suffices.
__________________
Deepak Honnalli.
deepakhon is online now   Reply With Quote
Old 8th September 2006, 16:03   #21 (permalink)
vikram_d's Avatar
I second Deepak. I have been using nitrogen in all my cars from a very long time and the ride is definitely better than air. I am not sure why this is but it is.
Vikram
Old 3rd October 2006, 02:17   #22 (permalink)
speed0mania's Avatar
Exclamation nitrogen inflated tyres!!f1 style!
i was just getting my fuel topped up when i saw this banner !! wherein you could get nitrogen filled in your tyres instead of normal air! this is used in f1 cars too for the following advantages:-
-low thermal coefficient of expansion, so almost no diff in pressure during hot or cold tyre! no deshaping , hene better grip as elasticity of rubber is intact!
- nitrogen is lighter than air hence better ride !!! much softer noticable!! more fuel efficient therefore!
-size of nitrogen molecules is larger hence slower escape in case of puncture!!
well this was available for rs15/- ore free if you got rs750 worth of fuel!! so tried it and felt much better !!
i think its really great!!
go try it! i tried it at hemkunt service station near jangpura(hp station)
__________________
everybody falls! its just how fast u get up!
speed0mania is offline   Reply With Quote
Old 3rd October 2006, 03:39   #23 (permalink)
Rehaan's Avatar
Threads merged
cya
R
Old 3rd October 2006, 11:07   #24 (permalink)
yogi1771's Avatar
is it available in mumbai if so where,would like to try it out
yogi1771 is offline   Reply With Quote
Old 3rd October 2006, 12:16   #25 (permalink)
Maybe we should ask Sumit to start this.
sandeep108 is offline   Reply With Quote
Old 3rd October 2006, 13:42   #26 (permalink)
rjstyles69's Avatar
Originally Posted by Rudra Sen
May be a point to discuss here. Has anybody tried nitrogen instead of air in tubeless tyre? I believe nitrogen doesn't expand or contract. One or two shops are pumping nitrogen in Bangalore.
Therezz a place near the Richmond Road (down the road after the Tata show-room) fly-over who fills nitrogen. Checked with one of the guys and was told that they do fill . Did anyone have a chance to try the same????
Old 3rd October 2006, 14:19   #27 (permalink)
naveendhyani's Avatar
where is it available in delhi??? ny info brothers?
naveendhyani is offline   Reply With Quote
Old 3rd October 2006, 16:26   #28 (permalink)
yogi1771's Avatar
???? care to explain
Old 3rd October 2006, 19:09   #29 (permalink)
Sumit is a known expert in tires - he answers questions in ACI and also has a great shop at Opera Hse.
Old 3rd October 2006, 19:22   #30 (permalink)
theMAG's Avatar
Toyo recommends filling of nitrogen in lieu of compressed air. Chk out http://www.toyo.com.au/tech_info11.html
__________________
Become who you are.
Thread Tools
tyres with nitrogen losing pressure mdesai_1981 Technical Stuff 3 13th June 2008 14:31
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 16:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
