Closed Thread
Old 3rd February 2009, 09:52   #316
sgiitk's Avatar
Thanked: 3,883 Times
Folks Nitrogen has a molecular weight of 28 and oxygen is 32. In other words the Oxygen in the air is a heavier molecule and should diffuse out slower.
As very rightly stated the laws of Physics give be zilch for nitrogen.
Nitrogen is used in aircraft and F1 primarily becuse of slightly better conductivity. If you have dry air (this may not be there at a fuel pump/service station due to close proximity of washing apparatus) then there should be no difference. I use a small electric/foot pump at home and have no problem. Quite often the improvement you see is because of uniform and full pressure.
sgiitk is offline
Old 3rd February 2009, 10:57   #317
Thanked: 420 Times
Relax folks all of us fill 78% pure nitrogen and some of us spend more money and get the percentage to may be 90%. Those who are not in coastal areas any way get the dry 78% nitrogen.
But Nitrogen filling has an important role to play that is to give a decent living to the Tyre guys and their families.
amitk26 is offline
Old 3rd February 2009, 12:50   #318
alpha1's Avatar
Thanked: 1,035 Times
Originally Posted by Nikhilb2008 View Post
Why does Nissan fill Nitrogen in the GTR then?
If as you 'experts' say Nitrogen has NO effect whatsoever, why does Nissan fill Nitrogen?
Why is it that most racing cars (f1 included) used Nitrogen? Why is it that today F1 doesnt use dry compressed air, but some special gas?
The reason why Nitrogen is used is because it is closest to the normal air that we breathe.
It is non toxic, inert, slightly lighter than air.
I guess whatever advantages the customers are facing - might be mainly due to less moisture.
Nitrogen under NO circumstances can diffuse LESS than air (which is a mix of nitrogen and oxygen)
Probably the leaking of air from tyres is attributable to microscopic oxidation of valve/lining.
Pure nitrogen being inert will not allow that.
alpha1 is offline
Old 3rd February 2009, 12:56   #319
Thanked: 63 Times
Originally Posted by Mindgrinder View Post
What all places in bangalore?
One was observed at HP petrol Pump Near Cosmos Mall, Brookfields, Kundalahalli, Marathahalli.
Need to figure out other places , if they are any !
lambuhere1 is offline
Old 3rd February 2009, 15:17   #320
There is one at HP pump on the old airport road next to pizza hut
enzo10 is offline
Old 3rd February 2009, 20:57   #321
tsk1979's Avatar
Thanked: 16,421 Times
Nitrogen molecules are bigger.
So loss of air pressure over time is lesser.
As for expansion, nitrogen expands lesser than normal air when tires get heated, but to get the actual "benefits" such they really make a significant difference, you have to be ripping the car on a racetrack. In normal usage, nitrogen won't make a very significant difference. Therefore its worth it if you can get it for free.
tsk1979 is offline
Old 3rd February 2009, 21:20   #322
Thanked: 253 Times
Sorry, that is not quite correct.
Normal compressed air is in any case 78% Nitrogen. And because there's almost 20% oxygen, higher molecular weight, there will be less tendency for porosity leakages.
There is no reason for Nitrogen to expand any less than DRY compressed air. Both will follow the Gas Laws.
anupmathur is online now
Old 3rd February 2009, 22:14   #323
vikram_d's Avatar
Thanked: 940 Times
After umpteen number of experiments done with the help of the TPMS system on my car I have found that nitrogen expands as much as normal compressed air and runs pretty much the same temperatures.
Some results below. Please note that the ambient air temperature was within +/- 2 deg C on all the test days. This was checked using a old school mercury thermometer.
Compressed air at 7:00am on January 2nd - pressure = 27.6psi, temperature inside tyre = 20 deg C
Nitrogen at 7:00am on January 8th - pressure = 27.8psi, temperature inside tyre = 21 deg C.
Compressed air at 10:15am on January 2nd after normal city driving for 30kms to office - pressure = 31.6psi, temperature inside tyre = 42 deg C.
Nitrogen at 10:20am on January 8th after normal city driving for 30kms to office - pressure = 31.2 psi, temperature inside tyre = 41 deg C.
Compressed air at 6:15pm on January 2nd after vehicle being parked under shade the whole day - pressure = 28.2psi, temperature inside tyre 26 deg C.
Nitrogen at 6:15pm on January 8th after vehicle being parked under shade the whole day - pressure = 28.4psi, temperature inside tyre = 25 deg C
Compressed air at 7:30pm on January 2nd after normal city driving for 30kms back from office - pressure = 31.4psi, temperature inside tyre = 41 deg C.
Nitrogen at 7:40pm on January 8th after normal city driving for 30kms back from office - pressure = 31.6 psi, temperature inside tyre = 42 deg C.
I have tons of such data and have tried air and nitrogen from all the bunks and tyre shops that I frequent.
My conclusion: It does not matter at all whether I run nitrogen or air. The conditions inside the tyre are more or less the same. Even after heavy track driving the conditions are within 5% of each other. The temperature inside the tyres has touched 65 deg C after heavy track driving.
Also spoke to the company representative of Bhoruka Gases. They are the people who supply industrial gases to my company. According to him the commercial quality cylinders that the tyre shops use will contain anywhere from 5 - 15% moisture in them. He also rubbished the fact that people claim that nitrogen molecules are bigger.
Edit: Even after highway driving of 300+ kms the pressure & temperature difference between air & nitrogen is within 4% of each other. Also please note this is not to deter people from using nitrogen. Use it if you want to. But I have found no difference between the two.
vikram_d is offline
Old 3rd February 2009, 22:20   #324
Thanked: 253 Times
Vikram, which car is this? Scorpio mHawk?
If yes, aren't you running with pressure on the lower side? Perhaps that's why you could measure 65 celsius.
Old 3rd February 2009, 22:25   #325
vikram_d's Avatar
Thanked: 940 Times
I drive a Swift ZXi with an aftermarket Xenos make TPMS. The cold tyre pressure that I maintain is 28psi. Also there are no limits for temperature. It will show what ever is there inside the tyre. It has high & low limit alarms for pressure though. The alarms are in 3 levels +/- 12%, +/- 25% and +/- 50%.
During the track session the system sounded the 12 & 25% alarms for high pressure. Now I start my track sessions with 22psi in the tyres. And still it goes up to 32 - 33 psi after 4 - 5 laps.
vikram_d is offline
Old 3rd February 2009, 22:40   #326
devarshi84's Avatar
Thanked: 119 Times
From what I have read, talked about with proffesors and seen in real life. Nitrogen is best left for uses where even a 1% difference makes major differences. (F1, Moto GP)
I wont use Nitrogen in everyday use unless it is free.
devarshi84 is offline
Old 3rd February 2009, 22:47   #327
suzuki san's Avatar
Thanked: 346 Times
Hi Guys,
Filled Nitrogen in my Swift Zxi Michelin XM1+ tyres yesterday at Mastakar Pump (Andheri - West). Cost was Rs. 100/= and valid for refills for 3 months. You get a card which you keep in the car. After the initial 3 month period you pay Rs. 60/= and it is then valid for another 3 months.
All the (old) air was sucked out of the tyres using a vacuum pump and then the N2 was filled in. I have to say that i noticed an immediate difference in the ride quality which is much softer (and more comfortable) now. swift owners will know what I mean.
For all the money we spend on our vehicles I think Rs. 100/= for a more comfortable ride is well worth it.
I will be doing my Wagon R tomorrow.
Cya.
SS
suzuki san is offline
Old 4th February 2009, 09:29   #328
Thanked: 253 Times
Vikram, what I meant was: Have you tried starting with pressure 30 psi (or whatever is the recommended pressure for the Swift), instead of 22 psi? Does the pressure still increase rapidly?
Is this increase happening because of tyre sidewall flexing or very frequent use of brakes?
Old 4th February 2009, 10:00   #329
weejai's Avatar
I got Nitrogen filled into my OHC in Oct 2008 when I drove from Mumbai to B'lore & back. I covered 1100 kms (home to home, oneway) in 13 Hrs and at some streaches doing about 140 km/h for upto 10 minutes. I could experience better handling, it felt as though the car was gliding, the braking was better than the usual, I got an average FE of 17km/L. I haven't had to refill it yet and the tyre pressure looks good.
And yes, I got this filled at a fuel pump before I entered Pune and was left with Rs.200 lesser in the pocket.
weejai is offline
Old 4th February 2009, 10:50   #330
alpha1's Avatar
Gosh, placebo really works!
alpha1 is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
