Closed Thread
Old 6th February 2009, 23:32   #361
D1ISTHE1's Avatar
Originally Posted by kutlee View Post
so it is still 50-50 i guess. I too filled up nitrogen for all 4 tyres. But sadly the tyres didn't last for a month. After that changed the tyres and filled normal air. For the few days i drove with Nitrogen filled tyres, the placebo was mind boggling.. Now i don't think there is any difference. REad somewhere that GTR comes nitrogen filled from the factory. May be the conditions are too demanding.
Vikram - i think you hate nitrogens don't you? :-)
anyway can you point me to good tyre pressure gauges? i would love to have one.
The GTR footwear is designed for a totally different kind of performance, but i drive in hills and as well as in the plains, dont' seem to find a significant diff in the ride quality. The gauge i use is digital Accutire, i imported these 15 of them now left with 5 or 6 models.
D1ISTHE1 is offline
Old 7th February 2009, 00:09   #362
Harshavarthan's Avatar
Thanked: 110 Times
When i filled in my car tyres with nitrogen i did feel a marginal difference in ride quality. May be it was just a placebo effect or may be my car was running in accurate tyre pressure. One good thing about filling nitrogen is you get it done with accurate values, where in it is unreliable in petrol bunks.
Harshavarthan is offline
Old 7th February 2009, 10:32   #363
vikram_d's Avatar
Thanked: 940 Times
Not all bunks are unreliable. The ones with the new electronic gauges and auto cut off are pretty accurate. Even the old dial type gauges will be accurate but there is a factor of human error in them.
vikram_d is offline
Old 7th February 2009, 12:33   #364
Thanked: 420 Times
Vikram contrary to popular belif pneumatic gauges most of the times are more reliable then digital ones at petrol pumps.
Case in point is HP Petrol pump at C.V. Raman Nagar bangalore , Once I got 47 in one of the tyre and 24 in other of my maruti and I detetcted it when I observed the car behaving funny.
I tried multiple times on this pump and found new values ranging from 30 to 47 every time , After this experience I started checked pressure filled by digital gauges of other pumps in my area and only 2 pumps ( IBP at Koramangla & HP at Jeevan Bimanagar ) out of 8 in the area around my home and office have proper gauges.
amitk26 is offline
Old 7th February 2009, 15:34   #365
Raccoon's Avatar
Thanked: 105 Times
The digital/automatic pressure gauges are definitely NOT accurare at most petrol bunk! And I speak from experience. While very few digital gauges are accurate, ALL the burdon pressure gauges used at puncture shops have been totally inaccurate... thats been my experience. I guess these gauges are susceptible to shock damage... and must be taking lots of shocks/falls from shabby hands...
Raccoon is offline
Old 7th February 2009, 19:14   #366
mdesai_1981's Avatar
i put in nitrogen in all my five tyres, costed me rs100/= with 3 months guarantee and free refills during that period.
this petrol pump had this nitrogen generation machine which produced 99.99% pure oxygen and this guy evacuated enitre normal air with the help of vaccum and then filled it with pure nitrogen. lets see how long it will last.
mdesai_1981 is offline
Old 7th February 2009, 19:25   #367
Thanked: 106 Times
Which pump you used for filling? I'm yet to find a place in south bombay. The nearest one is in Mahim. If anyone can help about the places in mumbai where it's available.
saurabhkum is offline
Old 7th February 2009, 19:44   #368
there is pump on bhullabhai road(near american councilate) the big INDIAN OIL pump he has notrofil they charge 100rs 5 tyres.
Old 7th February 2009, 20:04   #369
Sprucegoose's Avatar
Thanked: 40 Times
PAL tyres near lamington road
Sprucegoose is offline
Old 9th February 2009, 09:59   #370
tamojoym's Avatar
Thanked: 26 Times
I filled nitrogen in my tyres after which ride quality has improved considerably and so has the braking.
tamojoym is offline
Old 9th February 2009, 10:40   #371
Thanked: 253 Times
All the symptoms are that you had much higher pressure in the tyres when on compressed air!
anupmathur is offline
Old 9th February 2009, 14:36   #372
m_upreti's Avatar
Thanked: 311 Times
Is it available in Navi Mumbai ? I would like to try it out.
Originally Posted by gbpscars View Post
Very good thread!
I had been wanting to know more about Nitrogen in tires.
I saw an ad for the first time while I was munching away at a Mac, Kalamboli, before Panvel, Navi Mumbai (the one just before joining Mumbai - Pune Expressway, ).
The only thought that comes to my mind is what are the effects of a rubber body that is pressurised and lower in temperature on the inside and hotter on the outside, given the fact that rubber is a bad conductor of heat.
I have been trying to get an answer for this on the net.
Any of you?
m_upreti is offline
Old 9th February 2009, 15:38   #373
tamojoym's Avatar
Thanked: 26 Times
Smile
I used to put 30psi on compressed air also and put the same 30psi with Nitrogen as well .Possibly compressed air gauges were faulty
tamojoym is offline
Old 10th February 2009, 00:12   #374
Atlblkz06's Avatar
Nitrogen does NOT i mprove anything. So stop saying "OMG! I filled my tires with nitrogen and my braking and handling improved".
By filling up with nitrogen you're simply decreasing the pressure volatility of the air in your tires. It makes sense for HPDEs or any high performance driving situation but for the regular road car - clean dry air is the best. Just fill up on a dry day and you're fine.
Atlblkz06 is offline
Old 11th February 2009, 13:48   #375
Default Check Your Tire Pressure Again
I filled my tires with Nitrogen a few days ago.
They jack up the car then deflate your tires and then inflate them with nitrogen, right?
So they jack up the car and fill your tires with say 33 psi ( which is the right pressure when the car is on all four wheels) but when the car is taken off the jacks it increases to 35 or more depending on the weight of your car.
After ur tires are inflated and the car is taken off the jack, ask them to check the tire pressure again.
I had this problem. The ride comfort decreases alot, it will feel quite stiff.
Maybe thats why your'll feel acceleration has improved.
Wayne D is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
