Closed Thread
Old 13th February 2009, 19:35   #406
Originally Posted by vikram_d View Post
In my own factory, I have a air compressor coupled to an air dryer. Sadly not for public use.
You have not seen any proof because none exists. i have always said that if you have access to 99.9% dry compressed air then you dont need nitrogen.
The second side of the coin is that the compressed air available in our petrol bunks is always loaded with moisture as they do not see it fit to use an air dryer along with the compressor. They just use a small air filter and think that it is enough for drying the air.
Nitrogen that is available over here is relatively dry when compared to the above mentioned compressed air. Hence it make a very small amount of difference.
I use dry air and find it much better than nitrogen. But not everybody has access to dry air.
The only reason petrol bunks dont do it is because of the costs involved. The N2 generator is extremely expensive when compared to an air compressor. I told my petrol bunk guy to invest in an air drier for his compressor which costs about 50k. He said saaar too expensive saaar. When 50k is expensive then do you think they will spend 2 - 3 lakhs on a good quality N2 generator. Dont think so. Also if petrol bunks started using air driers then nitrogen would become obsolete.
Well what you have said is true. But the advantage with nitrogen is that there is less moisture content in it when compared to the normal compressed air available at all our petrol bunks. And oxygen and nitrogen dont expand too much by themselves because of heat. The water vapour or moisture is what causes the pressure to change due to heat. I have access is 99% dry compressed air and I have found that this air behaves much better than nitrogen that we use. But one thing I have noticed from my experience is that the ride quality is better with nitrogen than with dried compressed air.
And what you have said about 90% purity of nitrogen is not true as even the most commercial nitogen available is 95% pure.
Vikram i see that you were a fan of nitrogen filling back in the days. and i also came to know from where one can source "dry" compressed air in bangalore. Totally agree with you "dry" compressed air and nitrogen filling will give similar results, the key word here being "dry".
enzo10 is offline
Old 13th February 2009, 21:26   #407
Thanked: 253 Times
No compressor will produce dry compressed air or dry nitrogen. 'Dryness' has to be achieved by deploying dryers, silica-gel based or refrigeration type.
anupmathur is offline
Old 13th February 2009, 21:49   #408
True, getting 100% dry compressed air is a costly affair. however, nitrogen pumped out by the N2 generator installed at the fuel pump will be many times drier than the normal compressed air
enzo10 is offline
Old 13th February 2009, 23:27   #409
tsk1979's Avatar
Thanked: 16,420 Times
Most nitrogen filling machines give "dry" nitrogen, as they are designed to take in air, and remove all other gases except nitrogen. So you have 99% humidity.
But even so I don't think if you are filling your tires properly with ordinary air you have to worry about pressure variations unless you are running on a racetrack
tsk1979 is offline
Old 14th February 2009, 00:08   #410
SS-Traveller's Avatar
Thanked: 11,626 Times
Is that a typo?
It seems it is now fashionable to fill tyres with nitrogen, never mind the actual advantages. Next step: Beer shampoo for the paintwork.
SS-Traveller is offline
Old 14th February 2009, 00:25   #411
tsk1979's Avatar
Is that a typo?
Oh yea typo. I meant 99% pure N2
tsk1979 is offline
Old 19th March 2009, 12:41   #412
bblost's Avatar
Thanked: 6,976 Times
You can fill Nitrogen at the Jubillee Hills Check Post Petrol bunk.
Price: 40 Rs per tire. 10 Rs per tire for topups.
PS: I don't use Nitrogen in my tires.
bblost is offline
Old 19th March 2009, 13:39   #413
vikram_d's Avatar
Thanked: 940 Times
Oh I had completely forgotten about this thread. Yes I used to be a fan once upon a time but soon came to realize that N2 was overrated in all aspects. I have a refrigeration type air dryer and am very happy with compressed 'dry' air.
vikram_d is offline
Old 19th March 2009, 14:12   #414
Thanked: 253 Times
Now that is a luxury most of us cannot afford at home! And even if I did invest in one, how would it help me if I do not also have a compressor/reservoir system at home!??
Now, let's suppose I am rich and go in for one of these thingys too.
What happens when I go on longish holidays?
Old 19th March 2009, 14:52   #415
vikram_d's Avatar
Thanked: 940 Times
I don't have it at home. I have it in my factory for feeding my CNC machines with dry air. I have just tapped one of the lines for use with my car.
When on a longish holiday rely on petrol pumps or carry a small 12V compressor like I do.
vikram_d is offline
Old 19th March 2009, 15:03   #416
Thanked: 253 Times
I do! I have the SLIME smart sport duo!
But with Slime in my car tyres I have never had ANY problem so far! Ladakh, Jalori etc. notwithstanding! Nearly 15 months now!
Old 19th March 2009, 15:05   #417
rider60's Avatar
Thanked: 47 Times
alright one more new place with special price in the city nice find mate, now i am off to that place.
rider60 is offline
Old 20th March 2009, 18:26   #418
speed0mania's Avatar
i dont know whether it was the well calibrated pressure guage or actually N2 but my car felt smoother after it! sadly you don't get it anywhere in Delhi anymore! not that i know of. i was thinking, i have a compressor at home, if i fill the reservoir tank with lotsa silica gel packets, would it actually give me dryer compressed air? i know it cant be completely dry but what do you think would be the difference, i'm talkin fillin it up something like 10% its volume at least!?
speed0mania is offline
Old 20th March 2009, 18:36   #419
Spitfire's Avatar
Thanked: 707 Times
With Nitrogen, the omni also feels a lot more faster, especially around corners. I filled Nitrogen in the tyres of our 2 decade old Omni and now i can take that roundabout at speeds of 40kmph instead of 38 kmph. Even the ride has got better the leaf springs on the rear suddenly feel like gas filled shock absorbers.
The Nitrogen has also reduced the tyre noise and makes turning the steering easier, it's now as if i have Power Steering.
Even though i stay barely 400 meters away from the sea front with 90% humidity all through out the year, after i filled nitrogen and due to the awesome characteristics there is no rust at all. Only the rims are getting saved though the rest of the body is still catching rust. Maybe I should make the whole van airtight and fill it with Nitrogen inside the cabin that would stop the rusting. But then how do i drive?
Even the local air filling fellow who got a new Nitrogen pump, owns a Audi R8. Nitrogen is helping everyone.
Spitfire is offline
Old 20th March 2009, 18:39   #420
motionfreak's Avatar
Thanked: 54 Times
i don't know about the better road holding or tyre temp, but with Nitrogen my car's tyre noise has reduced considerably.
It matters to me considering that I use 195 section tyres
motionfreak is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
