Closed Thread
Old 5th May 2009, 21:05   #451
Thanked: 253 Times
Originally Posted by anupmathur View Post
It is beyond debate hat if Nitrogen gives you a 'feel good' benefit you are welcome to use it.
Hear! Hear!! This mirrors my POV.
Thanks, R2D2 but I wish you'd inserted a 't' in my quote (bold)! Silly typo! By the time I realized the window period had expired!
anupmathur is offline
Old 5th May 2009, 21:14   #452
dockap's Avatar
Thanked: 378 Times
my feedback regarding nitrogen
2 months after filling nitrogen -pressure still same
with air pressure usually drops in 2 weeks
after long drives at high speed-pressure difference is only 1 psi with nitrogen
with air pressure goes up by 4 to 5 psi
dockap is offline
Old 5th May 2009, 22:02   #453
Thanked: 253 Times
OK, a simple question.
Assume you start your long highway journey with under-inflated tyres, through some oversight. What happens then?
And if you do the same with 'normal' compressed air which has moisture?
Which of the above two scenarios sounds safer?
Old 5th May 2009, 22:41   #454
ashwinurao's Avatar
Think about this, though: if you fill your tires with air, the oxygen is more likely to permeate out of the tires before the nitrogen and over time you end up with a higher concentration of nitrogen. I have not checked this but it seems possible.
/ducks
ashwinurao is offline
Old 6th May 2009, 00:04   #455
Raccoon's Avatar
Thanked: 105 Times
Are you sure the ambient temprature was exactly the same when you measured the pressures?
Actually its good that the pressure goes up on long drives!!
As for air retention, my new Yokos (on steel rims) seem to hold up damn well!! Even after a month I didn't notice any air loss!
Raccoon is offline
Old 6th May 2009, 00:26   #456
Spitfire's Avatar
Thanked: 707 Times
/ducks
Sir Einstein what an hypothesis. I fell off my chair after reading that.
PS: I know you are joking and the logic is irrefutable.
So to all nitrogen filling guys here's a tip - fill normal air, throw in some silica gel and let the oxygen molecules pass out of the rubber and you have the noble gas (literally) with its bigger molecules trapped behind. Oh my sides hurt
Spitfire is offline
Old 7th May 2009, 12:58   #457
mail2vm's Avatar
Thanked: 13 Times
After reading the entire thread & getting the flash back of schooling with Physics & chemistry, I took my own decision to try Nitrogen for a fact that it would improve handling, road safety & smoother ride control.
I left my vehicle for service in Pratham Motors, the service engineer informed me that they wud charge Rs.100/= to fill Nitrogen in all the 5 tyres. Hope i feels good after the try.
I found the below information in one of the site : Just an FYI..
Nitrogen Information and Advantages
mail2vm is offline
Old 7th May 2009, 13:26   #458
mobike008's Avatar
Thanked: 8,319 Times
That is way too much! You should have got the tyres checked for slow leaks and/or leaking valves.
Originally Posted by CrackedHead View Post
That means that your tyre has a leaky valve or a small puncture or something.
Mobike008, my car's tyres lose about 3 PSI over a month. And these are no hot rod high perf tyres but plain Jane BS Turanza ER300 OEM shoes.
That was on my previous OEM S322 Bridgestone tubed tyres and got them checked for valve leakage but there was none. Also, a small puncture cannot be in same state for so long ( used those tyres for 36K kms) and situation was same from beginning.
I checked tyre pressure yesterday on my new michelin tubeless and guess what, its the same psi since the exact date 2 months ago when i filled Nitrogen when i got these new tyres.
Since the first fill was free of cost i had gone this route. Keeping all tech stuff aside, i can't complain now since i am seeing the benefit from it apart from the convenience of NOT going to a bunk for check every week
mobike008 is offline
Old 7th May 2009, 13:42   #459
Tempelhof's Avatar
Thanked: 125 Times
Originally Posted by mail2vm View Post
This site has, by far, the most comprehensive analysis on the use of N2.
Tempelhof is offline
Old 7th May 2009, 15:52   #460
Thad E Ginathom's Avatar
Thanked: 8,377 Times
I like the nice, bright green valve caps!
Thad E Ginathom is offline
Old 7th May 2009, 17:12   #461
Spitfire's Avatar
Thanked: 707 Times
You do realise that the above findings are listed by a company selling Nitrogen filling systems.
Spitfire is offline
Old 7th May 2009, 17:19   #462
the_maassk's Avatar
If Ingersoll-Rand makes nitrogen filling systems, there must be some value and market for it. It would not just be thin air!
Anyways - just my experience with N2 in tires - I've had N2 on mine since the last 10 months now. Have checked pressure around 6 times ever since the first fill. Just needed a top up once (2 psi diff.). Not comparing the ride quality and other stuff, but just the fact that my tires do not lose pressure is good enough for me!
the_maassk is offline
Old 7th May 2009, 17:23   #463
bblost's Avatar
Thanked: 6,979 Times
In the interest of Science, requesting someone who really cares about this to fill N2 in the left tires and ordinary air in the rhs.
Run for a couple of days and check.
Just use the N2 pressure reader on all tires.
bblost is offline
Old 7th May 2009, 17:34   #464
Tempelhof's Avatar
Thanked: 125 Times
Yes, I saw that, even before posting my message !
Still searching for an independent assessment.
Old 7th May 2009, 17:34   #465
mobike008's Avatar
Wow, who would be that brave and totally experimental ( considering the the effort and time required) to do such a thing? I am sure there won't be any
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
