Closed Thread
Old 7th May 2009, 17:48   #466
watashi75's Avatar
There was a column in today's Hindu. Here are some quotes from that article.
Generally those going on long drives can fill nitrogen for a smooth ride. Some people use it because it is a light element and it makes handling the vehicle much easier
Hmm. Maybe we should try filling tyres with Helium.
Also, with most of the cars using alloy wheels, the radials are filled with nitrogen when one buys the wheels. "Since it is a non corrosive element, dry nitrogen doesn’t react with alloy wheels and rusting of rims is less likely"
Aren't alloys supposed to be more resistant to corrosion?
watashi75 is online now
Old 7th May 2009, 20:17   #467
ashwinurao's Avatar
Originally Posted by bblost View Post
In the interest of Science, requesting someone who really cares about this to fill N2 in the left tires and ordinary air in the rhs.
Run for a couple of days and check.
Just use the N2 pressure reader on all tires.
Nobody is arguing the fact that filling N2 will reduce the amount of air lost over a period of time. It is just that this is the only significant advantage over normal air and all other advantages are only applicable in high stress conditions (F1, Space shuttle etc..).
The only question is - Are you willing to spend Rs 100/150 so that you don't have to check your tyre pressure and top-up every 15 days?
ashwinurao is offline
Old 7th May 2009, 23:07   #468
bblost's Avatar
Thanked: 6,979 Times
I know one person who would not do it. ME
At least till I see some actual science explaining the advantages.
and not just some feel good factor.
bblost is offline
Old 7th May 2009, 23:44   #469
Thad E Ginathom's Avatar
Thanked: 8,377 Times
Would that turn the engine noise into a high pitched squeak?
Thad E Ginathom is offline
Old 8th May 2009, 01:01   #470
johnda's Avatar
Thanked: 11 Times
Easy way to Take Off too, imagine one of those wacky tail wings with the turbine thingy and under it written "this is not it! my tires have helium"
johnda is offline
Old 8th May 2009, 01:38   #471
Roy.S's Avatar
Thanked: 111 Times
I like the nice, bright green valve caps!
Yeah! Pretty common now, but used to be something of a conversation starter when they first came out.
If I had helium in my tyres, I'd be sniffing the stuff all day just for the laughs.
Roy.S is offline
Old 8th May 2009, 09:28   #472
watashi75's Avatar
Depends. Did you happen to install a Boeing turbo in your engine?
I think you mean N2O (nitrous oxide). Helium is inert at best.
Old 8th May 2009, 13:27   #473
Spitfire's Avatar
Thanked: 707 Times
Since we are talking Helium, Nitrogen and Air. There was a study made in US to see whether a football filled with Helium can be kicked further then one filled with air. The helium filled one went about 1.3 meters(average over different players) further then a air filled one.
So if you fill helium in your tyres then for 4 wheelers - you will go 5.2 meters further for each kick on every tyre and 2.6 meters further on each kick on every tyres of a two wheeler. Note no need to kick the spare tyres.
Now with Nitrogen the only perceived advantage could be it would hold its pressure no matter how many times you kicked it. But you would have to pay about 100 times more for it.
Spitfire is offline
Old 8th May 2009, 13:55   #474
Thanked: 253 Times
LOL, Spitfire, does it also mean that for each pothole the car will jump 2.6 times higher than if there was air in the tyres?!
And what about the Scorpio's famous sway & body roll? Would that be delightfully enhanced to such a level than right upon ingress a passenger would need a sickness bag?!!
anupmathur is online now
Old 8th May 2009, 19:41   #475
Helium for kicks and laughs?
Whilst people have been known to misuse "laughing gas", the helium means laughs for everybody else, as it makes the deapest voice come out as a squeak. Something to do with sound travelling at a different speed in it, I think?
Old 8th May 2009, 20:08   #476
Roy.S's Avatar
Thanked: 111 Times
Oh no. I meant helium all right. Inhale some of the stuff and try talking. But not from your neighbourhood balloonwalla.
I have seen this done in my chemistry lab in school. The results were hilarious.
From Wikipedia:
Helium alone is less dense than atmospheric air, so it will change the timbre (not pitch) of a person's voice when inhaled. However, inhaling it from a typical commercial source, such as that used to fill balloons, can be dangerous due to the risk of asphyxiation from lack of oxygen, and the number of contaminants that may be present. These could include trace amounts of other gases, in addition to aerosolized lubricating oil.
Roy.S is offline
Old 8th May 2009, 20:34   #477
watashi75's Avatar
@Thad, @Roy, thanks for the clarification! But this certainly deserves some merit. I can also imagine reduction in road rage incidences and noise pollution. Maybe somebody should suggest this to the F1 teams.
Old 8th May 2009, 21:42   #478
dockap's Avatar
Thanked: 378 Times
the cost of filling nitrogen is rs 20 per tyre = rs 80 for 4
cost of topup is rs 5 per tyre if you check once in 3 months = 20 x 3 =60
80 + 60 = rs 140 is what you spend in 1 year
if you fill normal air and check once in 10 days = 3x5=rs 15 per month(at least thats what i pay rs 5 as tips to the guy who fills air in the bunk)
15 x 12 =rs 180 in 1 year
so nitrogen works out cheaper than normal air
add to that the placebo or real advantages
dockap is offline
Old 9th May 2009, 07:59   #479
johnda's Avatar
Thanked: 11 Times
IOC opened up their "cool your wheels" at their company outlet near technopark (tvm) There was a huge rush to cross over to nitro in the wheels
johnda is offline
Old 24th May 2009, 08:42   #480
greenhorn's Avatar
Thanked: 1,518 Times
dad showed me the place recently. Still in two minds whether its worth it. How much are they asking ?
greenhorn is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
