Closed Thread
Old 26th August 2009, 23:35   #556
johnda's Avatar
Thanked: 11 Times
where can I get it near thiruvalla, anybody from kottayam who has Nitrogen ??
is there a brand name attached to this? I mean if Indian Oil has them at their pumps..?
johnda is offline
Old 26th August 2009, 23:42   #557
New Bharath Tyres, which has branches at several town in Kerala offers it. Here it is near to my office and they charge Rs.300/-. Suggested me several times but I refused.
janitha is offline
Old 26th August 2009, 23:44   #558
di1in's Avatar
Thanked: 92 Times
Originally Posted by asethi View Post
Nitrogen means less air refilling, plus quite a comfy ride. My car now actually is more shock absorbent than before, due to cushion effect of the nitrogen in the tyres!
Nitrogen doesn't have any special cushioning effect. It only reduces oxidation and the amount of air seeping out as well as helping to keep the tire cool.
di1in is offline
Old 26th August 2009, 23:46   #559
johnda's Avatar
Thanked: 11 Times
I pass by Kollam while i drive to TvM where is New Bharath tyres located in Kollam?
johnda is offline
Old 27th August 2009, 00:15   #560
About half km before you reach Kollam/Chinnakkada on the left side beside the Reliance building.
janitha is offline
Old 27th August 2009, 10:08   #561
watashi75's Avatar
It is disheartening to see people still extolling false virtues of nitrogen. It appears to me that most of the people have not even taken the pain to read this thread completely, or conveniently skipped the posts which discusses the technical aspects.
It goes on to show that for most people hearsay still rules over the head.
watashi75 is offline
Old 27th August 2009, 11:02   #562
di1in's Avatar
Thanked: 92 Times
If it's completely useless then would you care to explain the 0 loss of pressure in my tires after the fill which was 4 months ago?
di1in is offline
Old 27th August 2009, 12:00   #563
watashi75's Avatar
The only benefit that users have been stating consistenly is that they need to refill less often. As far as I can see there doesn't seem to be any other noticeable benefit. Considering that is true, you could very well fill the tyres to 20% above the regular tyre pressure. After a few days the other gases will leak leaving behind pure nitrogen. And the tyre pressure would come down to the recommended pressure. So you would have the benefit of nitrogen filled tyres minus the cost.
Old 27th August 2009, 12:13   #564
asethi's Avatar
Thanked: 40 Times
Considering that is true, you could very well fill the tyres to 20% above the regular tyre pressure. After a few days the other gases will leak leaving behind pure nitrogen. And the tyre pressure would come down to the recommended pressure. So you would have the benefit of nitrogen filled tyres minus the cost..
So you mean whenever there's a pressure loss in your tyres, all gases except nitrogen leak from the tyres? I didn't know air disintegrates while leaking from the tyres! New lesson in chemistry!
asethi is offline
Old 27th August 2009, 12:59   #565
I fill in Nitrogen only for the convenience as I do it once in 3 weeks and not every week for air. Also it cost INR 20 to "Top-Up" with Nitrogen.
I haven't seen any difference with Nitrogen
AKNAN is offline
Old 27th August 2009, 13:01   #566
watashi75's Avatar
Yeah, maybe I am wrong. And maybe air is a type of molecule after all and not a homogenous mixture like many people are led to believe. There is always a new lesson to be learnt every day.
Old 27th August 2009, 13:35   #567
di1in's Avatar
Thanked: 92 Times
I do think watashi75 has a point. When you lose air pressure you're effectively losing the molecules in air other than nitrogen, if all the technical stuff is right. So if we fill up with extra air then eventually we might end up with higher nitrogen content in the air left in the tire.
@asethi Air does disintegrate when it's flow is blocked. Smaller particles pass through while larger particles remain at the barrier, as long as the cohesion between the particles isn't too high. It's how an air filter works.
di1in is offline
Old 28th August 2009, 02:52   #568
johnda's Avatar
Thanked: 11 Times
The Chemistry may be right but is it going to work? has anybody tried it? I'm interested in the economics too I mean if all I need to is fill more air, hey I'm ready to do that but if I have to do the same every weekend, so that I have Nitrogen, then that doesn't Add up!! LOL
johnda is offline
Old 17th September 2009, 19:27   #569
I have been using Nitrogen for my cars for the past 5 yrs. Even if you go in for a refill the nitrogen with be filled with a mixture of air. U cannot use 100% Nitrogen. If you fill more than given PSI for your car tyre u may end up weakening the Wheel Bearing, Lower arm, Suspension.. How ??.. When the Tyre is inflate beyond normal, every time you hit a bump or rough patches of the road the tyre will not take 80% of the impact which normally does and this will in-turn be absorbed by the mentioned components. I have had hands on exp.
Nitrogen helps in slowing down the process of deflation while ur having a puncture and absorb more of the vibrations produced by rough roads. For Each tyre it will cost you Rs.50 for each refill per wheel Rs.10. Refill required at least once in 3 weeks.
above the limit is offline
Old 17th September 2009, 22:08   #570
Sportsmind's Avatar
Thanked: 28 Times
Cool
Nitrogen is catching on fast. Was at the new Bimal workshop near Yelahanka for my scheduled service. They were glad to do the nitogen fill free of cost.
Did observe that PSI dropped by 1 during rains, and increses by 1 when the roads are dry. Is that due to Nitrogen? I Could monitor this through the TPMS.
Sportsmind is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
