Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 30th October 2006, 22:22   #46 (permalink)
hydrashok's Avatar
I filled the tyres to my usual pressure -- 30psi. Fiat recommends 28psi for normal usage (not laden with weight) and 32psi for full load. I always fill 30psi as this is what agrees with me, my Palio and the Pilot Precedas.
Nitrogen does make the feel tyres kinda squishy. Is this the feeling you get? But you know, this makes the ride so much better. I'd resigned myself to a harsher ride in the city after I switched to 50 profiles. But the ride is much better with Nitrogen -- because of this squishy feel. It also feels like it grips the road better. The steering does get just a wee bit heavier, but that's not a problem for me.
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 1st November 2006, 11:51   #47 (permalink)
vivekiny2k's Avatar
Location: Loveland, OH (cincinnati area), jabalpur, chennai
Originally Posted by pujaari
. Only question i have is that i find my tires a little deflated then when i got air on them. Should'nt nitrogen filled be a tad more(20% more) than what recommended by tire manufacturers? cos there recco is for air which is a mixture of gases and we are getting 1 pure gas filled which is much lighter and has diff pressure exertion on side walls of the tires.
that's the whole point. why else are we discussing nitrogen as a substitute?
gas pressure is gas pressure. no matter what gas or mixture of gases it is.
different pressure on sidewalls.....diferent from what? 30 psi is 30 psi
__________________
______________________________________
with great power, comes great responsibility.
bigger the car, longer the cleaning time.
vivekiny2k is offline   Reply With Quote
Old 2nd November 2006, 14:48   #48 (permalink)
You mean to suggest that at different tempratures all the gasses will behave the same way?? at 100 deg for eg the expansion of all gasses would be the same and hence would behave the same . At 30 psi and X temp a nitro filled tyre will behave diff from 30 psi of air at X temp. And the manufac recco's are for air and not nitro my dear. When i got my tyres nitro filled, i just noticed that tyres looked a tad under inflated and hence was worried that it might be bad for the tyres.
pujaari is offline   Reply With Quote
Old 2nd November 2006, 15:08   #49 (permalink)
Just curious.. if the tyre looks underinflated, wouldnt the contact patch change and wear out the sides faster?
harishsegar is offline   Reply With Quote
Old 3rd November 2006, 04:27   #50 (permalink)
kailashnj's Avatar
I am interested in trying out Nitrogen gas in my car. But before that I need to find out answers to few questions. Do you need tubeless tyres only to fill nitrogen or can you fill nitrogen in a tubed tyres too.
Where is it available in Mumbai, I have read the entire thread but have failed to find out this answer. Please provide me the answers to this question.
__________________
Indica Vista Aura - 2009
PULSAR 220 DTS-Fi 2007
Baleno VXi 2006
Avenger 2005
kailashnj is offline   Reply With Quote
Old 3rd November 2006, 08:44   #51 (permalink)
viper's Avatar
Premji's at Mahim offer this. I think they charge Rs50/- per wheel. Logically I feel you would need tubeless tyres.
Viper
viper is offline   Reply With Quote
Old 3rd November 2006, 11:12   #52 (permalink)
vikram_d's Avatar
Yes you can fill in nitorgen in tubed tyres too, but the noticable difference is going to be very small. On tubeless tyres the difference is much more noticable.
__________________
Been there. Done that.
Old 3rd November 2006, 13:05   #53 (permalink)
That is the only thing that bother's me otherwise there is immense improve in ride qual and wud highly recco u to go for it. I topped up my tires with 20% more nitro and still the ride qual is as good with tyres looking normal and not deflated....u could try that.
Old 3rd November 2006, 13:07   #54 (permalink)
Old 3rd November 2006, 13:23   #55 (permalink)
An interesting article i found on the net about nitro filled tyres check it out at http://www.hindu.com/mp/2006/08/16/s...1600310300.htm
Few excerpt's from the article
Nitrogen was first used in aircraft tyres, racing car tyres and has even been used in the space shuttle's tyres, all of which needed Nitrogen to handle the extreme operating conditions, especially the heat.
The culprit in regular air, which is filled from the low-end pumps, that you find being vended for free in most fuel stations is moisture and of course, the Oxygen content. For one, the mix of gases in air tends to make it more susceptible for heat expansion, leakage and loss of pressure leading to its gradual flow out from tyre and tube valves. In comparison, the molecular structure of pure Nitrogen and its inherent characteristics enable it to be less prone to heat expansion and leakage.
Further, the moisture and Oxygen in air tends to react with the wheel rim and tube rubber leading to long-term deterioration. In tubeless tyres, the moisture and Oxygen leads to accelerated oxidization of both aluminium and steel depending on the type of wheels being used
But, a couple of the big benefits are of course, the improved mileage from the more consistent maintenance of recommended air pressure in the tyres for a longer duration and the longer life of the tyres.
Old 3rd November 2006, 20:32   #56 (permalink)
vivekiny2k's Avatar
the answer is "NO", and what I meant was that is THE reason N2 was being preferred over air.
I beileve you already found that, in your latest post.
__________________
Old 3rd November 2006, 20:53   #57 (permalink)
aZa
aZa's Avatar
Pujaari : where in delhi is nitro available brotha ?
__________________
-[ " Objects in the mirror are loosing. " - Getz CRDi ]-
Old 4th November 2006, 12:02   #58 (permalink)
jerish666's Avatar
Normally nitrogen is used in F1 racing.I am using this nitrogen for last 6months.For high speeds and for long journey it is useful.It reduce the tire blasting.And ofcourse we dont have to check the tyre pressure for 2 or 3months.Pressure only varies 1psi 0r 2 psi in a month or 2.
jerish666 is offline   Reply With Quote
Old 4th November 2006, 13:10   #59 (permalink)
HP's Hemkund service station just after the Def col flyover(Over looking JLNehru stadium) Mon-sun except saturday. go generally after 10 in the morning till 6 in eve. rs 15(4 wheelers) for all 5 tyres and u could tip the guy when u go for a recheck and Rs 10 for 2 wheelers.
just incase u cant find the station their tel no is:24361301,24361358 (written on the pamphleti got when got tyre niro filled)
some adv written on the pamphlet are:
Low Thermal Conductivity of Ntrogen
Nitro doesnt expand due to heat, therefore in summer or at hih speed, the tyre does not expand or burst due to inc in temp.
Due to high thermal coeff of expansion, nitrogen derives a stable nature. therefore, the gas does not expand due to inc in temp and hence does not exert pressure on internal wall of the tyre. it gives longer life to tyre.
The nitro gas does no contract due to low temp. thus the tyre rubber does not contract. therefore for the life of the tyre rubber increases.
Also as the tyre rubber remains softer( elastic) because of low expansion and contraction, the breaking of tyre is improved due to improved road grip.
Advantages of nitrogen gas
As the elastic property of tyre rubber is intact, the tyre does not skid on turns. the tyre makes less noise on turns.
Usage of nitrogen gas in tyre "increase the tyre life by 20-25% & fuel saving by 6-10%.
Al F1 and racing cars use nitro in tyre for better road grip, driving comfort and safety
Nitro is lighter than air in weight. Usage of nitrogen gas in wheels dec overall weight of the vehicle and hence inc fuel efficiency
The size of nitrogen gas molecules is 4 times bigger than air molecules therefore incase of puncture, the nitrogen gas escapesvery slowly from the tyre thus giving more time to drive a punctured tyre.
Old 4th November 2006, 13:13   #60 (permalink)
point taken sir , i am not into any arguments was just discussing a concern i had. you may be right. was just worried if underiflated looks could by any means be harmful for the tyres? cheers mate.
Thread Tools
tyres with nitrogen losing pressure mdesai_1981 Technical Stuff 3 13th June 2008 14:31
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 16:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
