| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #616 (permalink) |
| BHPian Join Date: May 2005 Location: BANGALORE
| Had filled my Octy with Nitro and the pressure dropped in a week a lot. Yes the ride felt more smoother & comfortable. But its not worth the amount they charge. Have since stuck to our old good AIR. No more nitro for me. IMHO. Totally crap
__________________ Pete'd 130bhp Skoda Octavia 1.9TDI 2006 Santro Automatic 2006 Land Rover Defender 110 1990. |
| | #617 (permalink) | |
| BHPian Join Date: Feb 2009 Location: Kollam, Kerala
| Quote:
| | #618 (permalink) |
| BHPian Join Date: Jan 2008 Location: Hyderabad
| This question merits no thought. Once you have filled the tyre with a gas be it nitrogen, oxygen or any plain gen to the required pressure, the volume will remain constant. The only variables that can possibly change are pressure and temperature. Hence, for any gas inside the tyre, if temperature increases by x%, the pressure will also increase by x%. With regards to dry vs wet air, water vapor has a molecular weight of 18 as compared to Nitrogen's 28. So tyres with more vapor content are actually lighter than the drier version. But what happens is that moisture condenses at low temperature and evaporates at higher temperature leading to fluctuations in tyre pressure at hot and cold conditions. However, for the same temperature the pressure is going to be the same. If you could actually fill tyres with dry air, the effect would be same as if you filled it with "dry" Nitrogen. People who use Nitrogen also say that it leaks less. But that is only for leakage through the rubber itself. More often than not air leaks through gaps in the rims and valves. |
| | #619 (permalink) |
| BHPian Join Date: Jul 2009 Location: Mumbai
| Well said watashi, you are dot on and couldn't agree more with you. Whatever we were taught at school with p, v, t, was done with that fine print: held true for ideal gases! Water vapor and carbon dioxide are far from ideal. But then another thought crossed my mind. Is it necessary to invoke the gas laws to explain all the varied observations on this nitrogen filling matter? For example, give a thought to this: the attendant at the pump had filled my tyres using a digital gauge and a preset controller; leaving no room for doubt. However, soon after this the SA at a MASS found that my tyres had different pressures and all of them less than the stipulated 30psi. What had gone wrong? Nothing serious really, as I discovered the next time we went for an air-fill. The attendant would retract the air nozzle in a rather sloppy manner thereby leaking a goodly amount of pressure. What I mean to point out is that the experiment here is grossly riddled with the human factor hence making inferences and explaining the various phenomena makes for a good source of amusement, and I am loving every bit of it! I would often doze off in the chemistry classes and this thread sort of compensates for all that I missed at that time. Thanks guys! |
| | #620 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Haha, gostel, same case here - I enjoy reading what gets posted at this thread! However, when you say that there is little room for doubt BECAUSE a digital gauge was used along with 'auto' cutoff I would disagree. Quote:
It is in this area that most of our equipment is dubious and untrustworthy! | |
| | #621 (permalink) |
| Oops anupji, did I make a slip? Gosh Sir Anupji, if I didn't know about gauges and calibration then I ought to jump into a well. However, my case rests on the fact that the four tyres, all had different pressures in them, which I humbly believe were due to human factor. Now just imagine somebody filling free air carelessly, and another somebody filling expensive nitrogen very carefully. The reason for observed differences could be due to the human factor (which includes quality and calibration of gauges used). About the argument on digital versus analog: it is not the accuracy in question, but the repeatability that is better ensured by digital equipment. A digital instrument will be wrong every time and by the same amount. For analogy: you know very well that a stopped watch will show the correct time twice a day, don't you? ![]() Nonetheless it is so nice to hear (or read) from you, sir, that being on T-BHP is a truly rewarding experience. |
| | #623 (permalink) |
| Newbie Join Date: May 2009 Location: New Jersey / Kerala
| In the recent times, coming across facebook and forums I've learned that many people have a fad of filling up tires with Nitrogen. Sure, it costs more than regular air, then you can also claim more mileage, less wear, less leakage, more comfort and better ride, and yeah, of course the bragging rights. Can't speak for everyone, but if I remember correctly, regular air is 78% Nitrogen? So theoretically for improved fuel efficiency either friction has to be less or weight has to be less. Now friction only depends on the tire surface and thread pattern, so basically no effect putting Nitrogen. So, then it has to be lesser weight, right, well, yeah, we are talking less weight for the remaining 22% of air in four tires. It's got to be less than a few grams. I can't help, but, stop laughing. Now, air leakage. Assuming we all still run our cars on Petrol/Diesel you have to visit the pump at least every 2 weeks, if not more. So please check air, in most cases it costs nothing and you probably won't have to fill up as well. Oh yeah, the temperature, fire resistance, blah blah. While I can see how this could be a serious concern in Formula 1, but how many of us have a 600 horse power engine, revving at 8000 rpm or more, driving in race tracks on ultra high performance tires for 3-4 hours non-stop? Or how many of us drives a massive lorry or a trailer with 18 wheels where tire pressure needs to be in the 100 psi range. I guess none in this forum. What I'm trying to say is that there is only anecdotal evidence (if at all) that points out that Nitrogen is better than air. For all practical purposes it is the SAME! Save yourselves some time and money. For me good 'ol air just works fine. |
| | #625 (permalink) |
| Senior - BHPian Join Date: Dec 2007 Location: Kanpur
| @watashi: What messes you up badly with service centre/petrol pump air is the moisture content. This tends to collect inside the tyre and then on warming up changes the pressure far more than pure gas would. I always use a small pump (about Rs.800) and fill up at home into cold tyres.
__________________ Life is short, do not make it shorter! Accent GLS 2002 Santro Automatic 2005 |
| | #626 (permalink) | ||
| Quote:
Consider a tyre filled with pure water vapor at 30psi and another tyre filled with nitrogen at 30 psi. If the temperature is increased by 10 % (in absolute Kelvin), the pressure of both tyres will increase by 10% to 33 psi. This follows from the gas law - Quote:
| | #627 (permalink) | |
| Quote:
And it's not the pump alone, what is more important is an accurate gauge to check the pressure with. My 'Slime' compressor needs at least two fifteen minute cooling breaks for pressing up Scorpio tyres to 32 psi! Total time goes to over an hour per tyre, starting from flat! ![]() | |
| | #629 (permalink) | |
| Quote:
I have been buying cheap unbranded pumps (I guess chinese) for the past decade plus, and they easily last me for 5+ years. I do all the four tyres on the trot. Before this I used a foot pump.
__________________ Life is short, do not make it shorter! Accent GLS 2002 Santro Automatic 2005 | |
| Thread Tools | |
Similar Threads | ||||
| tyres with nitrogen losing pressure | mdesai_1981 | Technical Stuff | 3 | 13th June 2008 14:31 |
| Nitrogen in car tyres | ac 427 | Technical Stuff | 2 | 26th April 2007 16:46 |
| Nitrogen filling in car tyres | sn48001 | Tyre & Alloy wheel Section | 1 | 5th January 2007 14:47 |
