Closed Thread
Old 2nd January 2010, 19:33   #691
EssYouWe's Avatar
Thanked: 16 Times
Originally Posted by Raccoon View Post
You can't substitute water even if you can match the pressure, lol! You are using pneumatic tyres and not hydro tyres, I presume? Water is nowhere as compressible. The additional mass is another issue...
It was a joke!
What I meant to highlight was that we are talking about pressure here and not volume.
EssYouWe is offline
Old 2nd January 2010, 19:38   #692
Raccoon's Avatar
Thanked: 105 Times
^^^ Errr... where does volume come into the picture? Air or N or water - the volume would be almost the same in any case.
Raccoon is offline
Old 2nd January 2010, 19:49   #693
EssYouWe's Avatar
Thanked: 16 Times
What I meant by volume is that, more amount of air needs to be compressed into a smaller amount to yield a particular pressure reading.
Pneumatic tires work on the principle of requisite pressure on the inner walls.
Whatever the fluid being compressed into the tire, it'll have to be at a definite set pressure regardless of its volume at STP.
I am not sure if I am able to get my point across. Sorry about that.
Pressure is a characteristic of the tire and not of the fluid in the tire is what I meant to say.
EssYouWe is offline
Old 3rd January 2010, 11:08   #694
sumannandy's Avatar
Thanked: 219 Times
I filled my tires with nitrogen before my trip to Bangalore.
There is no obvious difference that we felt, except for the pressure loss issue. May be good for long trips.
sumannandy is offline
Old 10th January 2010, 22:58   #695
abishek2222's Avatar
Thanked: 162 Times
Originally Posted by bnzjon View Post
Nitrogen is free at HP pumps in Chennai if fuel is filled for a minimum Rs. 1000.
Thanks for the usefull info
abishek2222 is offline
Old 28th January 2010, 22:58   #696
ThePunter's Avatar
Thanked: 20 Times
Just adding an info:
At Chennai, I Got to know that in Velachery you can get Nitrogen filled in your tires. The place is called XL Tire point (selling Alloys too), after the Velachery rail Over bridge, just after the signal there, to your right.
They charge 50 per tire for the initial filling, and 10 per tire there after for every top up.
For 2 wheeler, it is 50 total for initial and 10 total for top up.
I did it for my Honda Dio. felt slightly better immediately, but cannot really guage what/why/how. Since it is in my daily route, I plan to do it from there for my Punto too.
BTW appreciate if any one could give pointers to petrol stations in this route (Velachery - T Nagar) which provides free Nitrogen filling on Fuel fills.
ThePunter is offline
Old 29th January 2010, 10:00   #697
asethi's Avatar
Thanked: 40 Times
That's too expensive! Even MASS doesn't charge so much!
asethi is offline
Old 29th January 2010, 10:42   #698
watashi75's Avatar
We have moved away from the original topic about the merits and demerits of filling nitrogen in tyres. I think it is time we opened a new thread to discuss where to get nitrogen for cheap.
watashi75 is offline
Old 9th March 2010, 18:22   #699
rakowli's Avatar
I have my Ford Ikon tubeless tyres filled with Nitrogen gas. I filled it in Nov. 09 and used to check the level with only nitrogen only at the same pump after a gap of 1 month. This Saturday, 06Mar when i went to check the pressure the pump guy to my surprise told me that you have to fill the nitrogen completely all over again. I asked him the reason which he don't know, he just said that the nitrogen validity is for 2 months and after that you have to fill the nitrogen completely by paying Rs. 20 per tyre.
I just want to know that is it like that way that you need to change the nitrogen completely after sometime.
rakowli is offline
Old 9th March 2010, 18:31   #700
Thanked: 253 Times
You do not need to change the Nitrogen, you need to urgently change your 'pump'!
anupmathur is offline
Old 9th March 2010, 19:42   #701
May be they are filling some special radio active nitrogen having a half life period of two months!
janitha is offline
Old 9th March 2010, 20:10   #702
asethi's Avatar
Thanked: 40 Times
Exactly, that person is just trying to rip you off! I last topped up nitrogen in my car tyres in Dec09, and haven't had any need to refill/topup till now. And whenever I feel the tyre pressure low, I just go to MASS and they topup free of cost!
asethi is offline
Old 9th March 2010, 20:14   #703
funnyguru's Avatar
Welcome to the IBP petrol station in Kottivakkam. The initial fill ups and the top ups are absolutely free, irrespective of you filling your tank full, or for 100 Rs...
funnyguru is offline
Old 9th March 2010, 20:48   #704
khoj's Avatar
Thanked: 1,258 Times
Could you let me know which pump is this and its location etc.
khoj is offline
Old 10th March 2010, 01:00   #705
rakowli's Avatar
It is in Dadar, Prabhadevi area in Mumbai. Just opposite to Siddhivinayak Temple. Anyhow i just refilled the Nitrogen free of cost not allowing him to change entirely. As i know the pump people very well as i stay in the near by building. but just wanted to confirm m i right or not. i knew they were looking to rip me of money but i didn't allow them.
rakowli is offline
Closed Thread
Goodyear's Self Inflating Tyres carboy Tyre & Alloy wheel Section 1 26th September 2012 00:15
Inflating a tire with liquid fire Takumi-san Technical Stuff 6 28th September 2010 13:47
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 15:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
