Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 6th January 2007, 09:26   #61 (permalink)
Air is 78% nitrogen, N2, and 21% oxygen, O2. So even if you put air in the tire, it's already 78% nitrogen. Many of the so called nitrogen generators don't produce much more than 90% nitrogen.
__________________
sn48001
sn48001 is offline   Reply With Quote
Old 8th January 2007, 00:31   #62 (permalink)
harsh87's Avatar
Originally Posted by pujaari View Post
HP's Hemkund service station just after the Def col flyover(Over looking JLNehru stadium) Mon-sun except saturday. go generally after 10 in the morning till 6 in eve. rs 15(4 wheelers) for all 5 tyres and u could tip the guy when u go for a recheck and Rs 10 for 2 wheelers.
just incase u cant find the station their tel no is:24361301,24361358 (written on the pamphleti got when got tyre niro filled)
some adv written on the pamphlet are:
Low Thermal Conductivity of Ntrogen
Nitro doesnt expand due to heat, therefore in summer or at hih speed, the tyre does not expand or burst due to inc in temp.
Due to high thermal coeff of expansion, nitrogen derives a stable nature. therefore, the gas does not expand due to inc in temp and hence does not exert pressure on internal wall of the tyre. it gives longer life to tyre.
The nitro gas does no contract due to low temp. thus the tyre rubber does not contract. therefore for the life of the tyre rubber increases.
Also as the tyre rubber remains softer( elastic) because of low expansion and contraction, the breaking of tyre is improved due to improved road grip.
Advantages of nitrogen gas
As the elastic property of tyre rubber is intact, the tyre does not skid on turns. the tyre makes less noise on turns.
Usage of nitrogen gas in tyre "increase the tyre life by 20-25% & fuel saving by 6-10%.
Al F1 and racing cars use nitro in tyre for better road grip, driving comfort and safety
Nitro is lighter than air in weight. Usage of nitrogen gas in wheels dec overall weight of the vehicle and hence inc fuel efficiency
The size of nitrogen gas molecules is 4 times bigger than air molecules therefore incase of puncture, the nitrogen gas escapesvery slowly from the tyre thus giving more time to drive a punctured tyre.
the advantages quoted are way too optimistic but aint a bad deal for 15 bucks will try it out soon
harsh87 is offline   Reply With Quote
Old 8th January 2007, 13:23   #63 (permalink)
jkdas's Avatar
wow! think its 50rs per or 15rs tyre at Cochin! It cant be 15rs for all 4/5 tyres
__________________
Audio, video, disco
Tat tvam asi
Old 8th January 2007, 13:36   #64 (permalink)
hydrashok's Avatar
It is Rs.50/- per tyre in Kochi/Cochin per tyre for full nitrogen filling (let-out all air, refill completely with Nitrogen). Top-ups are free. (I've topped-up 4-5 times so far. Available only in Global Tyres, near Popular, Mamangalam right now.
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 8th January 2007, 13:43   #65 (permalink)
jkdas's Avatar
thanks for confirming. I was with nikkibike when we went for free top-ups. I was sure it was 50 but got confused when I read the other post.
Now, is the 15Rs one and the 50Rs one the same thing?
__________________
Audio, video, disco
Tat tvam asi
Old 8th January 2007, 16:40   #66 (permalink)
At relatively low pressures (ie tyre pressures) N2, O2 and water vapor will all behave as ideal gases, and follow PV=nRT. Pressure will increase or decrease to the same extent as the temperature increases or decreases regardless of which gas is in the tire. (Even at 300 psi, which is about 20 atm, there is little deviation from ideality.) Therefore the comments about N2 not changing in pressure as the temperature changes are without merit.
__________________
sn48001
Old 8th January 2007, 17:35   #67 (permalink)
vikram_d's Avatar
Well what you have said is true. But the advantage with nitrogen is that there is less moisture content in it when compared to the normal compressed air available at all our petrol bunks. And oxygen and nitrogen dont expand too much by themselves because of heat. The water vapour or moisture is what causes the pressure to change due to heat. I have access is 99% dry compressed air and I have found that this air behaves much better than nitrogen that we use. But one thing I have noticed from my experience is that the ride quality is better with nitrogen than with dried compressed air.
And what you have said about 90% purity of nitrogen is not true as even the most commercial nitogen available is 95% pure.
__________________
Been there. Done that.
Old 10th January 2007, 10:14   #68 (permalink)
If moisture content is the culprit, a moisture separator attached to the compressor would do the same job. The cost of installing a separator is fraction of the cost of nitrogen generator.
__________________
sn48001
Old 10th January 2007, 10:18   #69 (permalink)
The rate of diffusion of a gas through a porous membrane depends on the molar mass and to some degree on the molecular diameter. N2 and O2 are almost the same size and N2 is lighter than O2, so if either gas were to diffuse out of the tyre, nitrogen would do it more quickly. Luckily, tyres are designed not to be porous membranes.
__________________
sn48001
Old 10th January 2007, 11:38   #70 (permalink)
vikram_d's Avatar
I totally agreee with you on this. But the problem is that nobody uses good quality moisture separators. The use 50micron separators which are not of any use for moisture purposes. For moisture they need to use at least 5 micron or even a 1 micron separator. But the best thing I have found that works is an air drier which I have in my factory for feeding compressed and 99% dry air to my machines.
Also the point of N2 being lighter than O2 is correct. It being lighter is the reason that the ride quality is much better than that of O2. And you have very rightly pointed out that the tyres are not porous. This sadly is a very popular misconception among people who think that tyres are porous. If they were then we would find tons of water in our tyres.
__________________
Old 10th January 2007, 16:02   #71 (permalink)
Nitrogen is used in racing cars for three main reasons.
1) Even a small variations in tyre pressure due to moisture would be crucial to wining the race.
2) These tyres are heated up tremendously during the race that tyres may tend to flame out. So nitrogen would retard any such flame outs.
3) Using Highly compressed nitrogen cylinders in the pit for operating various pnuematic tools is easier than having a compressor running.
__________________
sn48001
Old 11th January 2007, 10:36   #72 (permalink)
n_aditya's Avatar
I've filled in nitrogen in my new Michelin XM1 tires.
I feel nitrogen doesnt heat the tires as much as regular air does...
I also heard that the pressure remains constant for as much as 6 months, as nitrogen is less volatile than free air... but i may beg to differ....
here's why....
i got these mich's in november... all 4 tires filled with nitrogen and the spare JK tubetype also filled with nitrogen...
Yesterday i went for a top-up of nitrogen as i felt one of the tires looked underinflated (front Left tire). And it was... 5 psi less... FR tire - 2-3 psi less.... Spare tire had no change in psi whatsoever....
Surprising.... the other tubeless tires also were down by a psi or two... i must admit that i hadn't used the car for 2 weeks.... but then.. we dont use the spare regularly so why the leakage only from the tubeless?
now for experts... is it recommended to check every month like we normally do? or we just let is be cos it's got nitrogen?
P.S. also if i have a puncture... how many days does it take for the tubeless to go completely or almost flat...???
__________________
Download Junkie !!!
Old 11th January 2007, 10:52   #73 (permalink)
A long time. I remember when I first moved to tubeless and after a year or so, I noticed that pressure in 2 of the tyres was always 5-8 psi less. Instead of 28-29, it was at 21-22, but would never go below this or got a flat. I checked weekly and for more than a month the same cycle repeated. Finally I called my tyre fellow and when he checked them there were three punctures in total for two tyres.
It could also be a valve issue. Using good quality valves is very important for tubeless.
sandeep108 is offline   Reply With Quote
Old 11th January 2007, 11:09   #74 (permalink)
vikram_d's Avatar
here's why....
If the tyre is deflating so much then there must be some other problem. It could be a problem with the valve neck or the tyre fitting itself. I filled in nitrogen in my car all 5 tyres in July and till date there has been no reduction in pressure. I would recommend that you check your pressure atleast every month to begin with and if the deflating continues then you will need to get your tyres looked at. Also check pressure on a regular basis while using your vehicle everyday for one month. I think this deflation has happened because of the vehicle not being used. Also what kind or rims are you using? It could also be a problem with the tyre and rim contact area. Check all these points that I have mentioned and I'm sure you will find the culprit.
__________________
Old 11th January 2007, 12:48   #75 (permalink)
n_aditya's Avatar
Thanks Vikram.... Will monitor the pressure for sometime... BTW the wheels are all alloys which were OE fitment from Maruti (Limited edition esteem).
I think it is either an issue with valves or a puncture... will check and post findings.
Thanx guys.
__________________
Download Junkie !!!
Thread Tools
tyres with nitrogen losing pressure mdesai_1981 Technical Stuff 3 13th June 2008 14:31
Nitrogen in car tyres ac 427 Technical Stuff 2 26th April 2007 16:46
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
