Old 2nd May 2006, 19:51   #31
speed0mania's Avatar
Question strut braces for swfit
is there anyway i can fit strut braces on my swift as the struts are covered with a plastic cover and are too high and closer to the cabin !!
i don't think there is enough space under that hood for strut braces !!
is there anyone who's installed them??
speed0mania is offline   Reply With Quote
Old 2nd May 2006, 20:58   #32
Thanked: 11,073 Times
Originally Posted by speed0mania
is there anyway i can fit strut braces on my swift as the struts are covered with a plastic cover and are too high and closer to the cabin !! !!
Why bother ! Car handles well enough and is quite stiff
Dead right!
Old 2nd May 2006, 23:58   #33
guess you're right probably wont feel the need once i get better footwear!!:-)
Old 23rd March 2008, 10:37   #34
ram_hyundai's Avatar
Thanked: 48 Times
I dug up this old thread as to avoid a creation of new thread.I had some doubts regarding the strut braces.I heard a friend mentioning lower strut braces-what are they and how are they different from the regular ones?
ram
ram_hyundai is offline   Reply With Quote
Old 23rd March 2008, 10:40   #35
vikram_d's Avatar
Thanked: 940 Times
I think lower strut braces are the same thing as anti roll bars. It is normally a rod connecting the bottom end of the struts to each other.
Correct me if I'm wrong.
Old 23rd March 2008, 10:41   #36
Sankar's Avatar
Thanked: 4,654 Times
ram
The lower brace connects the gap between the two lower arm mounts on the unibody.
Old 23rd March 2008, 10:53   #37
Thanked: 48 Times
Are they available after market for swifts.The friend who mentioned about this had a baleno and he told me that after fitting the strut braces he found it hard to steer at high speed in bends.Something like under steer ,Any comments on this?
ram
Old 23rd March 2008, 10:59   #38
vikram_d's Avatar
Thanked: 940 Times
The swift already has a lower strut brace.
Old 23rd March 2008, 15:21   #39
Thanked: 48 Times
Woow that was news Vikram.That might be the reason for the rock solid behavior around the corners.
ram
Old 23rd March 2008, 21:52   #40
vikram_d's Avatar
Thanked: 940 Times
I think it is called a stabilizer bar in company lingo.
Old 23rd March 2008, 22:59   #41
ananthkamath's Avatar
Thanked: 63 Times
Yes you're wrong. Anti-roll bars dont add stiffness to the structure but rather optimize weight transfer.
And the stabilizer bar you're referring to is the anti-roll bar, not a lower strut brace.
ananthkamath is offline   Reply With Quote
Old 23rd March 2008, 23:02   #42
narayan's Avatar
Thanked: 1,356 Times
i guess not - in a independent suspension set up, if the struts were to be connected with a rod, it would foul with the suspension i suppose..
narayan is offline   Reply With Quote
Old 23rd March 2008, 23:56   #43
Sankar's Avatar
Almost all the cars with independent suspension ( and some with non independent) does have an anti roll bar.
You're partially right in thinking that an anti-roll bar fouls with the 'working' of an independent suspension independently. Stiffer anti roll bars would make the suspension stiffer and the movement at one end of the suspension is partially transmitted to the other end. But it will never make the independent suspension behave like a non independent suspension. The anti roll bars are connected to the body/chassis of the vehicle so as to limit the roll.
Some cars even have it at the back. Some Swaraj Mazda mini buses have it at the front & rear. I have seen them.
Maruti Omni doesn't have an anti roll bar even at the front.
Old 24th March 2008, 05:41   #44
Thanked: 48 Times
So still the question is un answered.Hey gurus can any one help me please?
ram
Old 24th March 2008, 07:55   #45
vikram_d's Avatar
Thanked: 940 Times
And thanks for correcting me.
Brace yourself - i'm going to bore you to death! IronH4WK Introduce yourself 18 23rd December 2009 21:21
Strut Brace for Baleno ? Anybody? eapen Modifications & Accessories 24 8th December 2009 16:22
Strut Brace on a Vtec ajmat Modifications & Accessories 25 16th August 2006 11:57
Strut Brace for a Palio? airfoil Modifications & Accessories 8 13th September 2005 12:04
SCOOP : Brace yourselves the Murcielago is coming !!!! Dippy Super-Cars & Imports in India 28 30th December 2004 21:09
