View Poll Results: What handling setup do you prefer? - Understeer/Oversteer/Neutral
Slightly Understeery 12 17.14%
Slightly Oversteery 39 55.71%
Neutral 19 27.14%
Voters: 70. You may not vote on this poll
Old 10th October 2008, 23:51   #61
Thanked: 528 Times
I like the steering feel and precision in the Forester. It feels light at low speeds but tightens up and provides excellent feedback at speeds while remaining responsive to any slight input you give.
You dont need keep doing 'corrections' as you go along curves. AWD which is said to nullify both understeering and oversteering must be contributing to this precision.
I also like the way it soaks up road irregularities (including big pot holes) at the same time remaining flat during cornering.
Guna is offline   Reply With Quote
Old 11th October 2008, 01:12   #62
nitrous's Avatar
Thanked: 282 Times
Originally Posted by DKG
Oversteer and understeer or the lack of it has little meaning if the suspension is simply not setup to handle the forces a car encounters while cornering
Can you elaborate ??
Old 11th October 2008, 09:38   #63
DKG
DKG's Avatar
Thanked: 928 Times
Unless the suspension setup is optimised for cornering the overall perceived benefits of oversteer or understeer are compromised. To enjoy the distinct feel of a car that either has oversteer dialled into its steering setup, or understeer, the suspension must allow for flat cornering. When the two happen together its distinctly pleasurable. A car that wallows or rolls heavily into corners can scare the hell out of you rendering the steering setup meaningless.
In practical situations its understeer which is safer as it gives the user time to correct. Whereas a car with oversteer can scare the hell out of you as the rear end comes swinging out. Now imagine if the suspension setup is weak, this can make your heart jump out of your throat!
DKG is offline   Reply With Quote
Old 11th October 2008, 12:06   #64
nitrous's Avatar
Thanked: 282 Times
Default Topic is Handling
OT:
I think you need to get your basics right about oversteer and understeer. Its got everything to do with suspension setup.
Here we're talking about handling which means zero bodyroll,
Also, why is 'steering setup' coming in here again unless its a competition car with a higher steering ratio?
Old 11th October 2008, 14:47   #65
DKG
DKG's Avatar
Thanked: 928 Times
Nitrous suggest you get your facts right before commenting about others getting theirs right.
The suspension setup in a car is fixed and you cannot control that element while driving. Likewise, tire grip and weight transfer that takes place in cornering is something you cannot do anything about unless you use the following:
Steering
Brakes
Engine power
When faced with an understeer or oversteering situation the first element you use is the steering. You obviously don't know that the latest in steering technology is using electronics to first determining whether a car is understeering or oversteering, then a signal from your steering inputs goes to a controller which determines the degree of steering assist required to correct the situation. That's what you call steering setup and this is a critical safety element that modern cars are developing.
Perhaps you don't know but using the steering, brakes, and/or engine power you can make a car oversteer/understeer at will. And by the way its not just suspension that has to do with under/oversteer its also the aerodynamics of the car, the ability of the tyres to grip and the weight transfer characteristics of the car. Steering setup is one element mfgs are looking at to handle the oversteer/understeer characteristics in different situations
The natural tendency of a car to under/over steer in situations is something that is affected by way too many factors. To counter it modern automotive design is looking at active steering systems.
Old 11th October 2008, 15:35   #66
DKG
DKG's Avatar
Thanked: 928 Times
Before we get sidetracked from the original discussion about whether oversteer or understeer and neutrality are the only three factors affecting handling my initial response was no. The other factors that affect handling are
1. Body roll
2. Weight transfer characteristics
3. Behaviour of the car on different road surfaces, here unsprung weight and other issues like chassis flex play a role
4. Last but not the least the Driver
The combined effect of all these, with the aspect of over/under steer affects the handling of the car.
Anyone slightly familiar with car design aspects will know that optimising handling compromises ride quality and comfort. So this whole game of an optimal setup is complex and most mfgs opt to dial in understeer as its safer. A car with a tendency to oversteer can surprise the wits out of an unsuspecting driver.
Old 11th October 2008, 17:10   #67
abhik's Avatar
For me:-
1.RWD
2.Tail hanging out in corners and counter steer or drift out of it!
Ah! Just wish i had a RWD.
abhik is offline   Reply With Quote
Old 11th October 2008, 20:37   #68
Path_Finder's Avatar
For me it depends on the driving mood - generaly it is a bit of oversteer; but at times do some lazy driving then it is understeer!
Path_Finder is offline   Reply With Quote
Old 11th October 2008, 21:25   #69
gendarmee's Avatar
Thanked: 21 Times
under steering + RWD.
gendarmee is offline   Reply With Quote
Old 12th October 2008, 15:35   #70
abhik's Avatar
But Why? Or maybe "+ LOADs of torque" should have been added too.
Old 13th October 2008, 09:54   #71
DKG
DKG's Avatar
Thanked: 928 Times
As a matter of interest to those wondering why I referred to steering setup when it came to oversteer/understeer found an article in Wikipedia under Understeer subject which clearly explains how steering ratios affect this aspect. The higher the ratio the more the understeer and, obviously, the lower the ratio the more the oversteer. Manufacturers invariably tweak steering ratios to counter the natural bias a car develops as a result of its many aspects that either cause understeer or oversteer.
The problem faced though is that steering ratios are traditionally fixed. But behaviour of the car varies and sometimes a vehicle can experience either understeer or oversteer depending on the conditions that may cause either the front or the rear wheel sets to slip.
BMW is one of the first to use what is called active steering systems. They use a electronic steering by wire device. When a driver turns the steering, a signal reaches a controller which in turn measures the degree of yaw or spinning that the car is experiencing through yaw sensors. This tells the controller if the car is experiencing oversteer or understeer. It then activates a motor which gives varied assist to the steering rack so that the over/understeer is corrected. The end result is like a variable gear ratio steering. Coupled with traction control this enables a car to remain neutrally poised in most situations
Old 24th October 2008, 12:20   #72
ac 427's Avatar
Thanked: 114 Times
understeer and rear wheel drive. simple
ac 427 is offline   Reply With Quote
What car you prefer? v12 The Indian Car Scene 475 7th November 2012 12:38
Which one would you prefer, car or bike? Shan2nu The Indian Car Scene 70 20th April 2012 20:05
Which SUV would you prefer?? Sid Schumacher The Indian Car Scene 29 18th February 2005 00:44
Which imported car would you prefer Sid Schumacher The Indian Car Scene 4 23rd November 2004 01:26
Which Bike would you prefer??? nikibusa Motorbikes 19 13th November 2004 14:54
