| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | So i have this sail 1.6 for 4 months now. Done 4k+ kms. For past 1 month or so i am seeing this strange behaviour. During the early morning (i leave for office around 7.45 or so...) start, the engine revs up, and the tacho shoots upto 2k. It then settles down at aroung 1200, and then when engaged in gear it goes down to 1000. All this at idle. Never behaved like this before. Took it sundaram. The guy there said its mpfi engine saar, all mpfi engine behave like this saar, this is common saar, like that. Furhter pushing, he told that, since the engine check light was not on, there is no problem with the engine. Also that fellow brought that ECM reading kit, attached it to the car, and showed all the display. (BTW some time back the engine check light was on for me for a breif period of time, 30 mins or so). The kit showed no error code. These guys dosnt seem to accept problem unless it shows up on that kit. What u guys think? Is this normal? Tommorow going down to bandipur. Hopefully nothing shows up on the way.
__________________ In the Indian system of education, it is only a technique of cramming, retrieving and reproducing. |
| | #2 (permalink) |
| BHPian | Yup its very common with MPFI engines, since it doesn't has a choke it automatically keeps the revs high and then comes down after the engine gets heated. I guess it so because I have observed the same thing in the MPFI engines in maruti cars.
__________________ Don't limit your CHALLENGES, challenge your LIMITS! |
| | #4 (permalink) |
| Senior - BHPian Join Date: Mar 2004 Location: bangalore
| Hi, True its common. The computer takes readings from the water temperature sensor, when it reads cold, the ecm automatically goes into a rich state. So the car will warm up faster and attain the nominal operating temperature. Once the car reaches the preset temp the computer will return from the loop. Cheers Dom
__________________ Dom@Team-Bhp.Com |
| | #5 (permalink) |
| Newbie Join Date: Aug 2004 Location: Trivandrum
| I had a related problem on my 1.6 Siena. One day after it was parked at a store by a parking attendant it started revving up intermittently (even when warm) without my touching the accelerator pedal. I thought the ECU had 'learnt' the higher revs because the attendant might have revved it up more than I normally did. However the throttle body sensor was faulty and had to be replaced.
__________________ ------------------------- |
| | #6 (permalink) |
| BHPian Join Date: Feb 2004 Location: DL XX X XXXX
| ya.. happens.. even with the 800. but the wagon R and alto revv up more than the 800. And wagonR and Alto seem to have a strange thing. Engine revvs up... and u start driving while its still revving... and u have driven some.. 20kms... And you let the car idle and see the rpm..... lol.. 1500+ The only situation these cars revv down is when all of the following happen along side. (then it revvs down in about in 6-7 secs) 1) The car is stationary 2) There is no load on the engine (i.e. no a/c) 3) Engine has heated up properly. So if any one of these is not met.. the cars don't revv down. I have seen this in .. other people's cars also. No one notices. (just seen with maruti though). Remember some people say Palio specially 1.6 are so free to roll that they can travel kilometers in 5th gear without much on an engine braking. My guess is... its not the engine braking which is low..... its that the car was never given time to idle properly before shooting. This happens in the WagonR and Alto at least if they are not allowed to idle. What say?
__________________ Č╠╣€€Я$ $£Қ |
| | #8 (permalink) |
| BHPian | Thanks for that guys. So what the service center guy said was correct. Due to usual mindset, never tend to believe what they say. Now it looks like I was too sarcastic about his “saar”. My apologies to that fellow.
| | #9 (permalink) | |
| Senior - BHPian Join Date: Jul 2004 Location: Mumbai/Tokyo
| Quote:
X
__________________ ------->> X <<------- | |
| | #11 (permalink) | |
| BHPian | Quote:
In an emergency situation where u need to start off on a cold Maruti MPFI engine, "rebooting" the system (switch off the car completely for a second and then restart) makes the ECU behave in a sane manner again. What surprises me is that although MPFI Marutis are pretty common, many people (including other MPFI Maruti owners) laugh and crack jokes on me letting my car warm up for a couple of minutes! My dad & bro call it "pre-flight checks" and announce "Control tower, we are ready for take off!" after the warm up is complete and I get into gear ! I let the temp get upto the "C" mark on the temp guage before starting off, by then RPMs have settled down just under 1000. When the engine reaches operating temp. (middle of the temp guage) it settles down to about 500 RPM. | |
| | #12 (permalink) | |
| Senior - BHPian | Quote:
__________________ I've lost my phone. Please PM me your phone number if I'm on your contact list. | |
| Thread Tools | |
Similar Threads | ||||
| RPM shoots up when clutch depressed | rao_battula | Technical Stuff | 40 | 11th July 2008 10:10 |
| Fluctuating RPM - Help! | gemithomas | Technical Stuff | 28 | 11th March 2008 12:45 |
| rpm below idle rpm | tortoise | Technical Stuff | 12 | 2nd April 2007 01:51 |
| Can Engine RPM/Speed shoots up automatically in AT vehicle | shaktideep | Technical Stuff | 5 | 21st September 2006 23:51 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
