Old 21st November 2004, 16:28   #1
manson's Avatar
Thanked: 2,230 Times
hey ppl . . .
just wondering watt exactly is an induction kit and what are the costs involved and watt are its effects on performance of a zen mpfi ? and obviously on fuel efficiny as well ? any1 in bombay who does the job ?
cheers ,
manson .
manson is online now   Reply With Quote
Old 21st November 2004, 21:25   #2
iceman91's Avatar
Thanked: 22 Times
hey manson..
a good induction kit for an mpfi zen will cost around 8 to 10 k incuding a K&n filter.. it boosts the performance of the car a bit and improves efficiency too...a must for all performance modified cars
it includes a filter..a trumpet..and piping for the air intake from the filter to the throttle body...
iceman91 is offline   Reply With Quote
Old 4th January 2005, 09:47   #3
speedsatya's Avatar
Thanked: 712 Times
hey guys,
so if someone already has a k&n ,then wat additions must be done .how long does all this take.
cheers,
satya
speedsatya is offline   Reply With Quote
Old 4th January 2005, 09:59   #4
tabrez02's Avatar
speeds
There are 2 types in KN filter one is the stock and other is performance. u need not have to modify anything in either of them. only thing is performance filters looks different than the stock once. and it directly fits to you intake hose. Time taken is minimal for the stock, just open the pack and put it in the airfilter box. Performance filter has to be fitted with an extra hose which will be the middle layer for your performance filter and the intake and will not take much time. (But Performance filters makes hussing sound when the air is sucked).
tabrez02 is offline   Reply With Quote
Old 4th January 2005, 10:12   #5
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by tabrez02
speeds
yeah,
this is wat i have .the K&n making a hissing sound .but wats an induction .
i have the performance K&n which is fitted through a small pipe to the intake.
now wat additions have to be done to make this a hissing induction.
Old 4th January 2005, 10:23   #6
tabrez02's Avatar
speeds
Induction kit ! i dont know much about it and i have not seen any.
I hope the below site will help u know.
http://www.knfilters.com/kits.htm
http://www.needforspeed.co.uk/piperc.../PXindkits.htm
Old 4th January 2005, 10:57   #7
anoops's Avatar
hey mason,
there are two types of air induction kits, one is the short ram, and the other is a cold air intake system. the short ram has a small pipe with the air filter at the end. the diadvantage of this system is that it sucks air from the engine bay, and the air can be hot, so not much of a boost at slow speeds. at high speeds as more cold air gets in it works better.
the cold air intake has a longer pipe that goes below the engine or in front of it (with the air filter attached to the end), and this system draws air from the outside and not from the engine bay...this works the best because it sucks in cold air from the outside. the only problem is in the rain you could spoil the filter.
i have a short ram intake in my palio and ive fixed a 2 inch pipe behind my grill, with the other end facing my air filter. so at speeds above 40 kmph, cold air is directed towards my filter.
anoop
anoops is offline   Reply With Quote
Old 4th January 2005, 11:04   #8
anoops's Avatar
BTW the black modded skoda RS (an absolute dream,i might add) on our forum has a cold air intake...check those pics
Old 4th January 2005, 11:16   #9
lamborghini's Avatar
Thanked: 1,667 Times
hey anoops..
what was the diff in performance in your car ...
how much did u spend
is there ayplace to get it done in mumbai ....
thinkin about it and incase i get a go-ahead i will go for it ...
lamborghini is offline   Reply With Quote
Old 4th January 2005, 11:25   #10
anoops's Avatar
lamborghini,
it does make a diff at high speeds, dint find much of a diff in city conditions. but once i got my header installed it worked better. at high speeds the header and the filter really boost performance.
the filter and the flange cost me about 6k. my flange (the pipe that the filter is attached to) is a bit longer as i wanted the air filter as far away from my engine as possible so it was a wee bit more expensive.
am from bangalore so cant help you with the mumbai dealers, sorry
Old 4th January 2005, 11:32   #11
tabrez02's Avatar
hey anoop
How much did it cost for you headers and does it has sporty sound too ?
And where did you got it from ?
Old 4th January 2005, 11:41   #12
anoops's Avatar
hey tabrez,
got my headers made by RAC (owned by the rally driver ranjit ballal).. and my freeflow muffler is made by shabir (near the TV tower) he is the guy who does all raj's work. my headers (only the manifold till the cillector cost me 4.5k (gave me a deal because i know him well). the rest was done by shabir (cost me another 2k), BTW he makes the best and the sweetest sounding mufflers in bangalore.
i have a 4x1 header not the regular 4x2x1.....so it works best at high revs.
Old 4th January 2005, 11:47   #13
tabrez02's Avatar
BTW which car have you fitted this ?. Can i just have the tail end modification. i am only looking for a sporty sound. Not Loud. but sweet. Whom do you suggest ?
Old 4th January 2005, 12:13   #14
speedsatya's Avatar
Thanked: 712 Times
i think if u go for a 4x1 exhaust,ur lower end and mid range drivability will be affected .
so for city driving the 4x2x1 will be more suited.
Old 4th January 2005, 12:15   #15
speedsatya's Avatar
Thanked: 712 Times
regarding the k&n filter,i am planning to change my intake pipe from the present plastic pipe to a stainless steel one.also i plan to give a small curve to it .
so wat do u say.shud i keep the present intake pipe or will changing to this new one help.
K&N Cold air induction system RC-5052AB jassi Technical Stuff 56 27th September 2008 15:51
Induction into "Banged my car" club sammyboy Street Experiences 18 23rd July 2007 11:46
forced induction bikes paras211 Technical Stuff 30 4th May 2007 09:31
Cracked induction pipe 16v100bhp Technical Stuff 0 24th December 2006 09:28
