Old 30th September 2006, 02:24   #1
playlife's Avatar
In most cars, we see there is a difference in the track width between the front and the rear. Most cars have wider frontal track width wrt to its rear track.
Some cars, for eg. the swift has a wider rear track width wrt its front track width.
Any reasons technically? Please share.
playlife is offline   Reply With Quote
Old 30th September 2006, 09:20   #2
vikram_d's Avatar
Thanked: 940 Times
Interesting question. Even though I own a Swift I was not aware of this. Guru's help please.
Old 30th September 2006, 10:05   #3
Rtech's Avatar
Thanked: 221 Times
The basic reason for having the front track wider than the rear is due to the weight distrubution when a car takes a corner.
Say you are taking a right hand bend. The weight of the car shifts to the front left corner. A wider front track helps reduce understeer as well as keep the car more stable. On front wheel drive cars, the added benefit of a wider front track means more space within the engine bay as well.
Old 30th September 2006, 11:40   #4
condor's Avatar
Thanked: 4,898 Times
RT, how does one explain this, considering that the difference in tracks is very small - about 1 cm, approx? That translates to about half a cm per wheel, from the center of the car?
The other point was abt the Swift's rear track being wider than the front ..
Old 2nd October 2006, 01:17   #5
playlife's Avatar
here are some more examples
MODEL- FRONT- REAR
M-Alto- 1290---- 1290
M-Zen- 1495----1495
Safari- 1500---- 1470
Indica- 1400---- 1380
Gypsy- 1300---- 1310
M-800- 1215---- 1200
Versa- 1280---- 1290
Old 2nd October 2006, 10:28   #6
Shan2nu's Avatar
Thanked: 89 Times
Firstly, are these differences intentional? What rtech said might make sense on a race car but i doubt manufacturers are really bothered about such detailing on normal family vehicles.
This diff could be due to the diff suspension setup used on the front and rear wheels.
Shan2nu
Limited Rear Seat width in modern cars! trek Technical Stuff 32 3rd October 2014 15:00
Different size/width rims on the front & rear ? AMG.EUROPE Tyre & Alloy wheel Section 14 27th December 2012 00:02
Difference in the track width of the mm 550 ngcs . sammyaulakh 4x4 Technical 63 4th December 2011 23:13
Does Rim Width Affect Handling ? speedsatya Tyre & Alloy wheel Section 21 23rd May 2010 17:29
Width of Santro Zip Plus psynaps3 Hatchbacks 4 15th April 2006 23:14
