Thread Tools
Old 27th November 2004, 02:31   #1 (permalink)
cheatingdeath's Avatar
ppl ..... 2 day my car conqued up it dint start .. the battery was ok and everything else was all rite tooo.. i suspected that petrol was not sucked in the engine .. so it was..the helpline guyz of hyndai fixed the problem ... the fuel pump valve was a bit loose.. guyz . the service guy even said that the fuelpump was ok... buit i wonder why did this happen .. as of now the car back smooth and silent
__________________
YoUr CaR DoEs NoT HaVe a BrAiN, So iT's DoUbLy ImPoRtAnT YoU UsE YoUrS.
cheatingdeath is offline   Reply With Quote
Old 27th November 2004, 12:05   #2 (permalink)
Sounds like a similar problem to what the 2003-early 2004 Honda Accords faced. Lose fuel pump valve = No fuel supply. The Accords faced this problem due to bad roads.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Thread Tools
Aircheckers by Petes- Show tyre pressure by valve cap pranil Tyre & Alloy wheel Section 66 9th July 2008 23:24
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 43 24th February 2008 09:27
Wanted: 2nd hand Fuel Pump / Fuel Pump Body ramie2400 Shifting gears 2 6th October 2007 12:16
palio 1.2 nv 'pressure sensor error and water pump issue' kapilsharma80 Technical Stuff 5 17th September 2007 18:58
Accords Fuel pump pressure regulatory valve cheatingdeath Technical Stuff 2 8th June 2004 12:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
