Old 5th October 2006, 17:06   #1
DRC
DRC's Avatar
Thanked: 48 Times
Default OOty effect..Victim of bad fuel.. Advice needed
The team-bhp meet at Ooty was great but for a few of these incedents
Hit a speed breaker when I was doing 130kmph, I thought the car almost broke, but surprisingly not damage at all, checked the tyre and the rims they are all OK,
As JK mentioned, going down hilltoo many times took the toll og the break pads. need to be replaced,
But the worrysome issue is that I had to refuel in Ooty. I chose a jazzy station to do so, hoping the fuel will be good, but not really so. Soon after refuel I noticed the drop in response. McL attributed that to the thin air in high altitude. Later when going back, I noticed black soot deposits on the bumper near the exhaust at Bandipur. I did a blotting paper test and found the presence of soot in exhaust.
I am worried now. Is the cat con gone bling . What should I do now, How do I know if it is gone bling? Should I drain the remaining fuel (I still have half a tank) and fill in fresh? What all needs to be done to restore the damage done?
DRC is offline   Reply With Quote
Old 5th October 2006, 19:13   #2
gbpscars's Avatar
good that u did not get to see the "Check Engine" light. an unplanned detour during my recent trip to Pratapgad, Maharashtra and no extra stock of good fuel, forced me to refill at a highway IOC on Mumbai-Goa highway. the guy there said XtraPremium was out-of-stock. so I filled in the 'sada'.
now I have this "Check Engine" light coming up and I doubt that the fuel filter is clogged. no time to check yet. am cabbing to office since 3 days now.
will have to catch up during the weekend.
gbpscars is offline   Reply With Quote
Old 6th October 2006, 13:00   #3
DRC
DRC's Avatar
Thanked: 48 Times
Hope the damage is not worse.
Back in Bangalore, the performance is not that bad, May be MCL thin air theory was true, but no relief from soot
Gurus please help me understand the problem, damage.
Old 8th October 2006, 21:29   #4
DRC
DRC's Avatar
Thanked: 48 Times
Nobody had a look here? Please, I need your help
Old 9th October 2006, 00:00   #5
2fast4u's Avatar
i dont know very well how much octane level is suggested by manufacturers for cars (as mine is carb version)
but in case of zx6 bike it clearly mentions on tank not to fill less than 95 Octane or there could be "Severe Engine Damage"
i believe it could be the carbon deposit build up.
suggest u dont wait much and get the fuel left in tank drained and also get all fuel lines cleaned if you get Redline cleaner to a tank full of new clean fuel should help.
also when u suspect something has changed like soot build up etc dont take it casually as in ur car if the Catcon goes for a six u will have quite a big amount to spend. so get it flushed.
2fast4u is offline   Reply With Quote
Old 9th October 2006, 01:04   #6
nitrous's Avatar
Thanked: 285 Times
Mr.DRC, pls let us know what car u're driving.
Old 9th October 2006, 11:15   #7
DRC
DRC's Avatar
Thanked: 48 Times
OK I got the fuel flushed. I was in deed scared.
My car seems to be back to normal with Shell Super, Now what I am wondering is, Should I need to fix someting before it actually breaks?
Old 9th October 2006, 11:40   #8
tsk1979's Avatar
Thanked: 16,421 Times
If it aint broken, dont fix it.
Since your car is working normally be happy that a big hole was not burnt in your pocket.
At the most you can give it for an engine flush treatment thing. Make sure you are there when it happens. Many times they say they have done it but dont follow the proper procedure.
Cochin - Ooty Advice needed karmix Route / Travel Queries 16 19th May 2012 18:31
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
A bad bad bad night for me.... Ranjan Sharma Street Experiences 38 8th April 2010 12:02
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
