Old 6th October 2006, 22:33   #1
Thanked: 66 Times
Default water trouble
people
have just noticed a problem in my moms vtec..ohc
when it rains water enters from the clutch n acc pedal...
the mechanics couldnt find any reasons..
wanted some opionions on the reason this could be hapenning
..only happens during the rain..
thnx in advance
Allan aLmeida
xtreme power is offline   Reply With Quote
Old 7th October 2006, 01:28   #2
veyron1's Avatar
Thanked: 38 Times
Seems your VTEC has leakage. That's it. Check the windshield sealant for bubbles. If necessary, replace sealant. Usually, OHC doesn't spring leakages unless;
a) The car is parked under the sun whole day long, or
b) The car was involved in some mishap damaging the A/B/C pillars.
Also, check the firewall. There could be chances that the brake booster mounts/clutch cable packing/throttle cable packing have gotten loose. There are chances that the water might be entering from under the hood as well.
veyron1 is offline   Reply With Quote
Trouble with tyres gladiator Tyre & Alloy wheel Section 7 26th December 2005 18:23
Ford in trouble again. Remember firestone? GTO The International Automotive Scene 3 23rd June 2005 15:02
Honda CR-Vs in trouble! Revvmaster The International Automotive Scene 5 29th March 2005 05:58
Are AutoRickshaws more trouble than help? RX135 Shifting gears 0 9th February 2005 18:03
Having Occasional Trouble Accessing TBHP ? Rehaan Shifting gears 2 14th June 2004 17:02
