Old 26th September 2016, 11:14   #31
arunphilip's Avatar
Thanked: 4,750 Times
Default Re: Skoda Octavia DSG Failure Compounded by Poor SKoda ASS
Originally Posted by Acharya View Post
Does it really work in this fashion? As far as I remember, manufacturers have certain quality standards, quality checks are defined on these standards. A unit either passes the tests or fails it. In fact, in sample testing whole lot is expected to be scrapped even if few units are found to be faulty.
It may not happen in the mechanical side of things, since the mechanicals of a DSG gearbox are tried and tested, and are pretty much a standard mechanical gearbox. It is definitely possible on the mechatronics side, specifically the electronics. And its the mechatronics unit that's been the most common failure point in the DSG/DQ200 gearboxes.
Companies like Intel, Nvidia, AMD all use product binning where chips with a limited number and specific pattern of flaws are sold as a fully-functional lower-end product, or chips that show instability at the extremes of testing are sold as a lower-end product. For instance, the most stable Intel i7 chips are what are unlocked for overclocking and given the K modifier, chips with flaws in the L3 cache are binned as i3.
Similarly, it is very possible that the electrical testing of the mechatronics unit will define a 'pass' if the behaviour is within specific tolerances. For an example, let's assume that the output voltage should be within ±5% variance when input voltage is 12V for the unit to be passed. Now, there's nothing that prevents VAG from specifying that units with ±1% variance goes to Audi/Porsche, ±1-3% to VW, and ±3-5% to Škoda.
All of these units are still 'passed' units, but its not a binary pass/fail, its 50 shades of gray .
Now, the original pass tolerance of ±5% would have been arrived at based on some factors which mean that those tolerances will never be approached or exceeded.
However, out in the field, how often are these systems pushed to the extremes is where these tolerances start making a difference. And that's where it appears that the DQ200 gearbox runs much closer to the edge than VAG intended - not only are the engines limited to the maximum torque the gearbox can handle (by design), but other factors like ambient temperature, etc. all reduced that inherent safety margin, to the point where variations in individual mechatronic units cause them to fail at a far higher rate than was intended.
arunphilip is offline   (6) Thanks Reply With Quote
Love Hate Relationship: My Magic Black Skoda Octavia 1.8 TSI Elegance EDIT: 95000 km update! adi_petrolhead Long-Term Ownership Reviews 294 30th December 2017 10:28
Skoda Octavia 1.8 TSi DSG - Shuddering issue! docsr Technical Stuff 74 3rd January 2017 22:01
Race Blue Skoda Octavia 1.8 TSi Elegance DSG - Now with Paddle Shifts (pg 5) abhinav.gupta88 Test-Drives & Initial Ownership Reports 88 2nd October 2016 11:59
Black Lightning: My Skoda Superb 1.8 TSI DSG-UPDATE: DSG box replaced! Swanand Inamdar Test-Drives & Initial Ownership Reports 130 10th September 2012 13:01
