Old 25th August 2016, 13:58   #16
adneeraj's Avatar
Thanked: 99 Times
Default Re: Restoration Report: Flood-affected Toyota Etios
Inspiring thread Vigsom.
The grit you had to get this car back on the road is amazing. Your thread portrays steps in an easy manner but I'm sure this was a herculean task!
Although I'm not a big fan of the Etios siblings, the way the car held even after 8 months of idle is amazing. That and the anti corrosion treatment done at manufacturing level shows the kind of quality Toyota must be using.
Great account! Wish you many happy miles with your car.
adneeraj is offline   (1) Thanks Reply With Quote
Old 25th August 2016, 15:55   #17
Thanked: 317 Times
Congrats on the restoration. I too did the same thing (almost similar) to a petrol car. You are lucky to get a flood damaged but running car. Toyota and Honda have such an engineering team and design so that no parts fail that restoring those car is a piece of cake (no offense). You just have to clean the whole car and get it working. For me, with Hyundai, the ECU bust out and the electrics too were not so well. I had to sort out the wiring, clean all the connectors as well as some relays. I had to get a new speedo too. My efforts are posted here.
http://www.team-bhp.com/forum/techni...ndai-getz.html (Buying & restoring a Chennai flood-damaged Hyundai Getz!)
One simple question: You have posted that you spent close to 4 lakhs to restore it. Does it include the cost of purchase. I simply cannot understand why it was so expensive.
aveemashfaq is offline   Reply With Quote
Old 25th August 2016, 17:07   #18
coolmel's Avatar
Thanked: 121 Times
Top read and great work sir. Take a bow. Respect for Toyota increased by more notches!!
coolmel is offline   Reply With Quote
Old 25th August 2016, 17:12   #19
Thanked: 3,960 Times
Originally Posted by vigsom View Post
By the way , I managed to get a tow hook so my project is now officially 100% complete.
Saw a 2014 Amaze AT , 2014 Swift vxi AT , 2012 Innova GX , 2014 Eon Magna plus , all in operation post flood.The Swift floorpan was also quite clean.Attachment 1546899
Glad that you finally sourced a tow hook. Is it possible to order the towhook from Toyota? The complete tool kit is availabke in order. Not sure about just the tow hook.
How about the floor pans of Amaze and Eon?
Old 25th August 2016, 17:44   #20
vigsom's Avatar
Thanked: 596 Times
Thank You adneeraj, aveemashfaq and coolmel.
I got into this project like a man possessed , and my focus was restoration to my standards. It wasn't easy as I had to inspect every sq.cm of the car.
Bringing these new gen cars back to pre flood state can be quite a nightmare.
You are right , Sankar.The tool kit can be ordered from Toyota but I was quite confident of sourcing the stuff from outside .
Couldn't see the floor pans of the Eon and the Amaze as the carpets were well fixed ; will keep the forum posted as I get to see 'em.
Old 26th August 2016, 11:32   #21
unBound's Avatar
Thanked: 7 Times
I read your report with utter fascination Vigsom, your efforts in restoring a flood hit car are laudable, and as you mention, the quality of metal work and engineering on the Toyota really shine through.
A couple of questions (newbie, please excuse):
1. The seats, seat covers all tend to retain water - did you not have any issues with moisture / smell from these? Or did they just dry out once the car was out of the water?
2. Water tends to seep into cabling connector joints, hydraulics and some ball joints in the suspension when the vehicle is immersed stays in the water. Remarkably you have mentioned that the ECU connectors and the ABS connectors were clean and undamaged. Again, was it a result of the water drying out once the vehicle was out of the water (and possibly kept without starting / being used) for a long time?
Thanks in advance!
unBound is offline   Reply With Quote
Old 26th August 2016, 15:19   #22
vigsom's Avatar
Thanked: 596 Times
^^ Thank You unbound
The seats were dry but as a sample, I had covers in the front two bottom parts removed , inspected the seats for moisture and dirt.Those covers were chaffed so discarded them.No smell in the seats.
The axles were free of water.The ABS module and the ECU couplers are designed to be water free.They have a gasket kind of arrangement with a snap buckle .That possibly keeps the water away.
Hydraulics - unaffected.
Old 26th August 2016, 15:32   #23
Have you done the brakes? If not i would suggest flushing the brake lines completely and filling up with fresh fluid. As you may already know brake fluid is hygroscopic and the car being submerged will let some amount of moisture to seep in through the seals. This may not pose an immediate problem but in the long run the moisture in the circuit will cause corrosion internally.
Old 26th August 2016, 15:41   #24
vigsom's Avatar
Thanked: 596 Times
Changed the brake fluid on Day2 of restoration , Sankar.
Used one liter of DOT4 and ensured that all the old fluid was out from all the brake lines plus the clutch line.
vigsom is offline   (1) Thanks Reply With Quote
Old 26th August 2016, 16:13   #25
I missed it as it was not in the opening post along with the list. But never mind I found it now in post #5
Old 26th August 2016, 18:22   #26
swiftnfurious's Avatar
Thanked: 6,527 Times
That's a great job there! After watching the below video, am kind of sure your Toyota wasn't all that difficult to be "re-started". (Please watch from 1:50 onwards).
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 29th August 2016, 11:01   #27
sgiitk's Avatar
Thanked: 3,814 Times
Great job. Thanks for pointing me to it.
Folks, he had done a great job at fixing the AC Compressor on his Corolla AT. I am happy in having diagnosed the issue almost at the outset.
Old 12th October 2016, 16:03   #28
vigsom's Avatar
Thanked: 596 Times
The last bit viz.engine oil was changed today.
I could have let the old oil go on for another 3000kms but finally decided to let the engine enjoy some fresh brew.
The new oil is Shell Helix HX5 15w40 API CH-4 which is a way higher spec than the recommended API CF.
Here is a shot of the old oil which was in the car even when it was water affected - not a drop of water in it.
Restoration Report: Flood-affected Toyota Etios-p_20161012_111125.jpg
vigsom is offline   (3) Thanks Reply With Quote
Old 27th January 2017, 21:54   #29
vigsom's Avatar
Thanked: 596 Times
A few updates to the report :
1.Changed 3 relays on the BCM as a preventive ( which is integrated with the Speedo assembly) as one of the relays viz.the ECU relay malfunctioned one day and as a result the car started , stalled and didn't start till the relay was replaced.
2.Changed the right front strut assembly to control part of the boat ride.The total cost of a Monroe assembly was 3.2k.
3.Error in judgement while reversing caused the rear right taillamp assembly to crack on impact with our building's gate.The bumper suffered a dent but I could bring it back to shape in a jiffy.Replaced the taillamp assembly.
The car left for her final home 2 and a half months back and seems to be doing well.
It was a great experience helping this machine regain some of its lost glory !!!!
Phailin (Cyclone) affected Puri-Satpara-Konark. In a Toyota Etios EDIT : Updates on Page 2 Samba Travelogues 26 3rd November 2017 19:30
Toyota ETIOS Sedan: World Premiere! Pictures, Pricing, Specs & Short Report Jaggu The Indian Car Scene 252 19th December 2010 19:51
Discount on Flood affected Cars jinu_joseph The Indian Car Scene 4 11th August 2006 13:52
