Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 9th October 2006, 19:16   #1 (permalink)
My M800 got a big problem...<I think>
After a rain-shower, I can see a good pool of rust in front of my car;
My M800 was bought recently second-hand (around 7 years old).
Is there some explanation for this ? I am new to this car-world...
CheeseGuy is offline   Reply With Quote
Old 9th October 2006, 23:02   #2 (permalink)
theMAG's Avatar
The car has not seen much weather protection during the 7 rainy seasons so far / coastal usage/ local tinkering in lieu of original bodywork due to accident. Pick one or all the above !
__________________
If I hold a hammer, everything looks like a nail.
Old 10th October 2006, 16:29   #3 (permalink)
esteem_lover's Avatar
could you be more specific please ? if the rust is in front of your, why are you sad ? if the rust is on your car, then you should be. where exactly is it rusted ?
did you get your car from bombay ? the sea breeze kills the steel, as it does here in chennai too.
__________________
"Keep your friends close, Keep your enemies closer"
Old 10th October 2006, 21:53   #4 (permalink)
theMAG : the car doesn;t look like its worn out - has some dents here n there; but nothing that indicates a major accident; so that may not be a problem.
esteem_lover: the previous owner was from Pune; so erosion due to sea breeze ruled out.
ohh okk...the place where I park has a slight slope so when I park the car on a bit of incline...the rust puddle gathers in front of my car...that's when I realized it
never mind, when I bent down under the front of the car, the horizontal rod just near the front (dunno what is it called) 'seemed' rusted.
Old 11th October 2006, 00:27   #5 (permalink)
gd1418's Avatar
It is called the Crossmember
Old 11th October 2006, 03:26   #6 (permalink)
elf
elf's Avatar
Show it to a Maruti Udyog service center, your local garage, &/or contact a T-BHPian in your city to look into the problem.
Can any Pune guys volunteer & coordinate?
elf is offline   Reply With Quote
Old 11th October 2006, 16:33   #7 (permalink)
your car probably has/had a leaking radiator/battery which has caused the rust. please have it checked & rectified immediately before it becomes a major problem.
__________________
Old 12th October 2006, 11:38   #8 (permalink)
'had a leaking battery' seems to be the possible reason; because the previous owner had mentioned that the new battery has been newly installed.
Maybe the old one was leaking alright.
Okk.. I will take it some Maruti service center.
Thanks a lot for those suggestions and info
Thread Tools
My rusted esteem - bringing it back to shape Mr_Bean Technical Stuff 16 9th July 2009 15:19
JBL Comps Crossover Rusted, What to do? vrrraju Ask the Gurus 14 23rd July 2008 12:17
MAtiz rims rusted - help goandude Tyre & Alloy wheel Section 17 16th October 2007 16:39
Chrome Exahust Tip for Ikon getting rusted VC12 Modifications & Accessories 9 27th May 2007 12:16
Brand new rusted fiat petra!! Dovin The Indian Car Scene 29 10th October 2004 03:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
