Old 22nd February 2017, 06:59   #46
ecenandu's Avatar
Thanked: 1,782 Times
Default re: Using Solar / Wind Power in India (EV charging, home etc.)
Originally Posted by maddy42 View Post
Congrats that looks like a nice setup. Few queries:
Is it 250 W per panel?
Which direction is it facing?
Do you use two meters or one smart meter?
Which brand panels and who did the instal? Were you satisfied with the work?
Do you have a battery backup or storage? How does storage work if you have netmetering?
Lastly whats the area it takes up? As most probably my home needs should be satisfied by 5kw.
Maddy
1. Yes, 250 W.
2. The orientation of the picture is
N
W E
S
3. There are two meters, the DC-AC inverter is single phase.
4.Its Su-Kam branded ones. And yes, so far we are happy with the installation.
5 and 6 Holyghost has answered them
Originally Posted by Holyghost View Post
Congrats ecenandu. I guess you went with SuKam. Which brand inverter did they install?
Looks like there are a lot of trees on the left side in the picture. Is that the west side?
Thank you. Its Su-Kam branded on the outside, don't know the actual brand.
Yes buddy, it's the West side.
We started producing green power since yesterday , will update the units produced and other details next week. Once the guy from Su-Kam comes and explain it properly.
Sorry for the late reply, guys.
ecenandu is offline   (3) Thanks Reply With Quote
Old 22nd February 2017, 14:54   #47
Thad E Ginathom's Avatar
Thanked: 8,341 Times
Originally Posted by ecenandu View Post
Thank you. Its Su-Kam branded on the outside, don't know the actual brand. ...
Congratulations!
Can you please post pics and details of the inverter, batteries, etc!
<-- appreciation and envy!
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 22nd February 2017, 23:45   #48
ecenandu's Avatar
Congratulations!
Using Solar / Wind Power in India (EV charging, home etc.)-img_0361.jpg
Using Solar / Wind Power in India (EV charging, home etc.)-img_0390.jpg
We have gone for an on-grid based solar solution, so there are no batteries involved. The solar power produced will be supplied to the grid or used by the house only if there is power in the grid, that is the down side though.
The pics posted are old ones, now we have a new meter in the blank space that is seen in the second picture. The inverter can be seen in the first picture.
My dad wasn't a fan of off-grid system, mainly because of the recurrent cost of the batteries and the maintenance as well. Well, hopefully net power consumed will be negative. Will update once I get more info about it.
Old 23rd February 2017, 05:27   #49
ecenandu's Avatar
Here is a video of the system
ecenandu is offline   Reply With Quote
Old 23rd February 2017, 13:28   #50
Thank you ecenandu!
1. How does isolation from mains work when mains is down?
2. Do you have a three-phase power supply? If so, how have is the single-phase solar integrated into it?
Old 23rd February 2017, 22:32   #51
ecenandu's Avatar
I think the inverter will take care of that. Not sure.
Yes, we are having a three phase supply. Currently only one of the three phase is connected to solar power. This set up is modular, so in future you can add more capacity say 5KW to the other phase etc.
When I skimmed through the documents I couldn't find a clause where they told the modular arrangement has to be same for each phase. With my limited understanding, I think we can do 5 KW - 5 KW - 5 KW or 5KW - 3KW - 5KW, etc.
But each time you have to go through the government paperwork and all that headaches, for modular that is.
ecenandu is offline   (1) Thanks Reply With Quote
Old 24th February 2017, 00:18   #52
Thanked: 223 Times
Thank you ecenandu!
1. The inverter shuts down within 30 secs once the mains are down. This is one of tests the electricity company verifies as part of the approval process.
Moreover, by design the inverter needs mains supply for its normal functioning. The inverter is designed to check the frequency curve of the mains supply and create a matching frequency curve with a slightly higher voltage to make the current flow back to the grid. Whenever the mains fail or its voltage/frequency goes beyond what the inverter can match, the inverter stops current production and goes into stand by mode. It will resume once the mains are up or the frequency/voltage comes back to normal levels.
2. The inverter will be connected to any one phase. You can later add additional inverters to other phase later, or replace existing inverter with a 3 phase grid tie inverter.
Holyghost is offline   (4) Thanks Reply With Quote
Old 3rd March 2017, 13:36   #53
ecenandu's Avatar
Update.
First meter reading done today.
130 Units of solar power in 9 days, .
I was expecting more, greedy me.
Old 10th March 2017, 12:19   #54
Thanked: 223 Times
5kw system should produce more, but it depends on the local weather.
My 3kw system produced 12.5 units yesterday. The average has been 300 units per month. And I was unhappy that it is not producing 15units per day.
Since Oct 5, 2016, My system has produced 1593 Units as of Mar 7.
Edit: You are producing an average of14.4 units per day. Mine is at 10 per day. It is only marginally less. Lets see how much it produces this summer. And BTW, clean panels makes atleast 20% more. My panels had accumulated too much dust and the production has been around 9 units since Feb. After a heavy rain on Sun night, the production climbed to 12.5 units/day.
Holyghost is offline   (3) Thanks Reply With Quote
Old 18th March 2017, 21:27   #55
ecenandu's Avatar
Update.
There was a mistake actually. The first 9 days production was 85 and not 130 as I quoted before.
We did clean the solar panels and it was covered in dust but didn't see any drastic increase in production.
So raised a complaint and the Engineer came down and had a check, looks like they have done some fundamental mistake, he was evasive on what was the actual reason for the low production. Last two days we are getting an average of 17 units.
So my expectation wasn't greedy in the first place.
A bittersweet experience.
I will update once I get the official bill from the electricity board, will clear all the confusion.
Old 25th March 2017, 23:28   #56
ecenandu's Avatar
Update:
Last 9 days : 146 units.
Highest : 21 Units.
Lowest : 4 Units. (Power cut 10 AM to 5 PM).
Have asked the engineer how the solar panels are connected, will post the details once I get them.
Old 26th March 2017, 00:11   #57
black12rr's Avatar
Thanked: 273 Times
Update:
Highest : 21 Units.
Great .
Could you also tell some thing about cleaning the panels. I am sure after 2 or 3 days, there would be a layer of dust sitting on panels. Leaving it not cleaned after a week , would cut down on efficiency ,highly, right ?
black12rr is online now   Reply With Quote
Old 26th March 2017, 00:46   #58
ecenandu's Avatar
Originally Posted by black12rr View Post
Great .
Its been hardly a month since we started producing solar power. So don't know how much the dust will cut down on efficiency. Currently taking reading everyday, to build a baseline. So if there is any significant drop in the production over a week or two other than cloudy weather or power cuts, we will clean the panels.
If you check Holyghost's post earlier, he said there was an increase of 20% in solar production after a heavy rain.
Old 2nd April 2017, 09:04   #59
ecenandu's Avatar
Update:
My solar inverter got two MPPT trackers, so 10 panels in series(300V) is connected to each of the tracker. The inverter will give output if there is 150V or more produced from the solar panel.
Last 16 days: 282 Units.
Since our thread is about "Using Solar / Wind Power to charge your Electric Vehicle in India". With 16 days of electricity production you can charge your Tesla 90D three times over which will give you a range of 1420 Kilometers.
Not bad, eh. .
ecenandu is offline   (2) Thanks Reply With Quote
Old 2nd April 2017, 13:31   #60
At this tme, I cannot afford a proper setup, on off grid. I have to replace our inverter anyway, and have now almost decided to go for this Luminous setup. They are qoting 2 lakh for a 2kva setup. Haven't got 2 lakh: end of story (plus the fridge, new specs, ac, car detailing, etc etc on the must-spend list).
And what I fear is falling between two stools: spending far more than I need to keep a computer and lights/fan going for several-hour power cuts, but not having enough Kva to power the larger appliances.
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Alternative energy business - Wind, Solar, Biogas Etc Wolfheart Shifting gears 16 4th June 2016 12:40
Pathetic EcoSport delivery (Shreeji Ford): Low coolant levels, charging over MRP etc. ACM Indian Car Dealerships 30 30th September 2014 15:17
Project Nomad: Solar Power for charging batteries! COUGAR Modifications & Accessories 12 12th July 2010 00:47
