Old 11th October 2006, 10:48   #1
Dippy's Avatar
Thanked: 192 Times
Default Help : How to read an OHC fuel gauge?
Fellows
Its been a week and a half since I'm driving my OHC. My car is giving me an FE of 10-11 kmpl with full AC. I just need some help on reading the fuel gauge.
Right now the guage reads just a bit above 'E'. Tentitively how much more fuel will be there and how many kms can I go on before I need to fill up.
Would appreciate inputs from fellow OHC owners from our forum.
Dippy is offline   Reply With Quote
Old 11th October 2006, 11:51   #2
vikram_d's Avatar
Thanked: 940 Times
Well this is something that only experience can tell you. You can do a simple test. Check what the capacity of the fuel tank in the manual and now that it is at the almost empty level fill it up completely with fuel. So you will get an approximate idea as to how much fuel was ther in the tank when you topped up. This should solve your problem. Also once you know how much fuel there is in the tank then you can approximate how much more it will go before fillup.
Old 11th October 2006, 12:33   #3
Dippy's Avatar
Thanked: 192 Times
Thanks vikram. Just needed a few more inputs as to how the long other bhpians who own OHCs have stretched their cars from the just above 'E' position before filling up
Old 11th October 2006, 12:37   #4
Mr.Bangalore's Avatar
Thanked: 43 Times
just a clarification..
i think there will be a fuel light glowing when the fuel gauge crosses 'E' position.. and in vehical manual one can find out for how much fuel the fuel low indicator will glow..
Mr.Bangalore is offline   Reply With Quote
Old 11th October 2006, 12:47   #5
Dippy's Avatar
Thanked: 192 Times
are you sure the OHC has a low fuel indicator? I some how couldnt see one on the instrument cluster
Old 11th October 2006, 12:53   #6
viper's Avatar
Thanked: 9 Times
Hey,
I did not expect this from you Dippy being such a old member. Why the hell do you want to take the car to empty. It is the worst practice. As a thumb rule you should never let your car go below qtr mark. Will save you a lot of long term problems by taking it to empty mark such as dirt entering fuel lines/injectors, and fuel pump failure.
Viper
viper is offline   Reply With Quote
Old 11th October 2006, 13:03   #7
elf
elf's Avatar
Thanked: 9 Times
Whatever you do, avoid letting your car run dry - don't need to tell you about the hassles of running outta gas in a fuel injected car.
I generally tank up again when I hit the halfway mark.
elf is offline   Reply With Quote
Old 11th October 2006, 13:14   #8
Rtech's Avatar
Thanked: 221 Times
True, definatly something that does not need to be done.
However, I would always like to know how accurate my gauge is, and how far I can stretch one tankful. You never know when this can come in use. Especially when on a bike!
Old 11th October 2006, 13:46   #9
Dippy's Avatar
Thanked: 192 Times
Viper I never let my car go empty. Its just not my thing. Its just reached above E when I got to work. Will be filling up first thing I leave work this evening. I just needed to know how accurate the fuel guage reading is in an OHC
Thanks for the info
Old 11th October 2006, 14:16   #10
iraghava's Avatar
Thanked: 156 Times
The OHC has about 5 litres of petrol left when it's just above the E mark. So about 50kms more can be expected but I would suggest you to not take the risk as pushing a car even as light as the OHC is a hard task. Don't ask how I discovered this
Also the OHC has one peculiarity - an over sensitie fuel gauge. So if you park it with the left wheels higher than the right ones within a few minutes it'll show you that it's tank is full even though it might be near E & vice-versa. Similar things also happen when the car is parked on an incline even a slight one!! The best way to see the accurate amount of fuel in the car is to check it after dirving for a few minutes on a level road which is the time the gauge is most accurate. Also if you are driving on mountains/inclines the gauge fluctuates with the conditions so take a good look at the fuel condition before setting off.
Old 11th October 2006, 14:27   #11
Dippy's Avatar
Thanked: 192 Times
Thanks for the reply iraghava
I cant really take risk of going 50 more kms with the needle above E . I also agree with your views on the fluctuating fuel guage. Honda has mentioned it in the user manual as well. I have observed in my week of driving that the slightest incline makes a difference to the needle
Thanks for the figures on the reserve capacity as well
P.S I remember Shantanu mentioning driving his Vtec for a long time even after his needle hit E . Now thats really something
Old 11th October 2006, 14:34   #12
suman's Avatar
Thanked: 257 Times
going by Ishan's logic, perhaps his right wheels were higher than the left, maybe the road was so inclined ...(just kidding )
Old 11th October 2006, 14:34   #13
Jaggu's Avatar
Thanked: 8,694 Times
old 1.3 i have ran more than 60 km from E mark and needle went to minus the E mark, was an un avoidable situation
Old 11th October 2006, 14:48   #14
Jaggu's Avatar
while on the topic that car had a wierd problem, while stopped at trafic signal with park lights on and ignition is aux position the fuel guage used to rise slowly sometimes over a long period even to full, honda had some major gizmo to absorb fuel vapour and fill tank, but once you crank engine the needle used to go normal level, bloody fuel burner of a car or what he he
Old 11th October 2006, 15:03   #15
manveet's Avatar
Thanked: 586 Times
well my OHC goes to about a mm below the red-mark. that's happened on a coupla occassions.
and fyi, there is no light in the OHC that indicates reserve.
manveet is offline   Reply With Quote
Hello Skoda - Did you read and analyze or merely read ? ajmat Indian Car Dealerships 48 11th March 2009 13:08
Lancer fuel gauge indicator Vid6639 Technical Stuff 16 21st January 2009 20:19
Fuel Gauge Problem - Contessa & Esteem falcon Technical Stuff 14 12th October 2008 10:54
Temperature Gauge links to Fuel Efficieny 2fast4u Technical Stuff 12 21st June 2006 15:39
Problem with fuel gauge in Esteem frankmehta Technical Stuff 3 14th April 2006 18:05
