Old 21st January 2009, 15:06   #16
razor4077's Avatar
Thanked: 258 Times
Originally Posted by ImmortalZ View Post
You can calculate it pretty easily and accurately.
Tank up to full cut off, reset trip meter, drive around, tank up again to cut off. Find out how much fuel went in and divide the trip meter figure with this number to get a mileage figure. Fill from the same pump and same vending machine for both fills and you should get a figure that's about as accurate as possible.
Yup, that's how I do calculate the FE. May not be 100% accurate, but it's close enough to give me a good idea. Whatever kpl figure you arrive at, keep a +/- 0.5 margin.
Discovered this thread today. This behaviour is consistent across most cars I've known - the warning light comes on when there is a good 5-10L of fuel left in the tank. And I believe the tank volume in the spec sheet includes the reserve capacity.
razor4077 is offline   Reply With Quote
Old 21st January 2009, 20:19   #17
Thanked: 45 Times
Default @ topic starter
My lancer too fills only around 40-42 litres for full tank upto fuel cap...i dont know why...
rajivanoj is offline   Reply With Quote
Fuel Gauge Problem - Contessa & Esteem falcon Technical Stuff 14 12th October 2008 10:54
Fuel indicator in spark whether a correct measure of amount of fuel bkm Technical Stuff 2 3rd April 2008 14:24
Temperature Gauge links to Fuel Efficieny 2fast4u Technical Stuff 12 21st June 2006 15:39
Problem with fuel gauge in Esteem frankmehta Technical Stuff 3 14th April 2006 18:05
