Old 13th October 2006, 12:16   #1
mobike008's Avatar
Thanked: 7,964 Times
Question
I am facing a very strange problem with my new viva crdi. When i took delivery of car, the fuel meter showed almost empty ( just little below to white line above E mark) and low fuel warning lamp too was blinking. Filled it up in a fuel station about 5-6km from showroom. Surprisingly, the car took in only 33 litres of diesel...after filling to the top...
Again 4 days ago, i did my 2nd tank full ( after the low fuel warning started blinking) and filled the tank to brim and this time it took only 31 litres of diesel ( and the fuel meter shows it little below F mark)
My understanding is this car has a 45 litre tank capacity and 5 litre reserve...which means when the low fuel warning comes up..it shud ideally take a minimum of 40 litres, But, as you see above it's not
What could be wrong guys???
Mobike008
Old 13th October 2006, 20:52   #2
ram_hyundai's Avatar
Thanked: 48 Times
Question need more details
hi,
with the information you have given,i feel either the fuel guage is at fault or the float is not correct.you have not mentioned the mileage you have got between the tank fulls.are you getting good mileage,and the fuel needle usually goes well below the E mark.
ram
ram_hyundai is offline   Reply With Quote
Old 13th October 2006, 21:14   #3
Vid6639's Avatar
Thanked: 19,385 Times
Could it be like the lancer the hyundai has a large reserve? The lancers low fuel warning lamp comes on when theres 10litres fuel.
The car takes in only 36-38litres when the light comes on but has a 50litre tank.
Old 14th October 2006, 10:42   #4
mobike008's Avatar
Post
Originally Posted by ram_hyundai
hi,
ram
Between 1st tankful to 2nd tankful I got 440 KMS which averages to 13.3Km per litre without using AC much as most of my driving was at late nights
Do you also drive a viva? I dont think something as major as the fuel guage could go wrong with a brand new car...probably the float ain't working properly ...atleast i am hoping so !!!
Old 14th October 2006, 11:51   #5
Rudra Sen's Avatar
Thanked: 4,093 Times
Could be the case. But why are you frustrated? It's a new car and you should take it to dealer in any case. It's their headache and problem to solve, not yours.
If float/pump is the culprit (it's complete unit I guess), do not allow them to tinker with it. They must replace the unit.
Gettings brothers Accent VIVA CRDi but a mysterious issue and clutch plate problem... ajai_dev Technical Stuff 1 3rd December 2009 22:17
Help : Viva crdi or Verna crdi nitindangoria Sedans 15 10th March 2009 22:50
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
Viva Crdi Revvmaster The Indian Car Scene 7 15th June 2004 15:30
