Old 15th October 2006, 21:21   #16
Octavia2's Avatar
Lightbulb
As I said in one of my previous posts Karthik, I dont think battery disconnect erases fault codes etc. Make sure you also check your fuel tank - you'd be surprised what you can find there....
Thanks,
-P.
Octavia2 is offline   Reply With Quote
Old 16th October 2006, 20:32   #17
karthik247's Avatar
Thanked: 16 Times
Got the car checked from my regular mechanic today. Timing was again checked even tho it was correct. Since there was some work with the side skirts that had to be done, didn't have time to check the distributor. He felt that it was causing the prob, so that will be checked tomorrow. Also will try running with stock plugs and cables.
karthik247 is offline   Reply With Quote
Old 16th October 2006, 21:13   #18
Ford Rocam's Avatar
Thanked: 16 Times
ask your mechanic to check IAC valve as mentioned earlier.
Ford Rocam is offline   Reply With Quote
Old 17th October 2006, 20:17   #19
karthik247's Avatar
Thanked: 16 Times
Got the distributor cleaned today and also got the IAC checked. The missing kinda stopped, but it did happen once but that could be cuz i was low on fuel. Besides, there isn't much difference in the way it performs. I still feels its nutin different from what it used to be.
Old 21st October 2006, 21:45   #20
karthik247's Avatar
Thanked: 16 Times
Guys,
The earlier jerking problem has been sorted out. But besides that, do i need to tune the car according to the mods i've got!?? Timing, valves...??
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Lancer ICE - Installation & Tuning Queries pramodkumar In-Car Entertainment 4 25th July 2012 21:57
Lancer.ized got his Lancer.iCED Lancer.ized In-Car Entertainment 46 4th May 2009 12:14
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
