Old 24th October 2016, 14:32   #1
arjab's Avatar
Thanked: 1,141 Times
Default Timing belt replaced - Now, ignition timing issues
Hi Team,
Need some help folks. Recently my 100,000 kms + run SWIFT (Petrol, G13B) had a routine timing belt change.
Authorised Maruti Service Station has messed up the ignition timing when replacing the timing belt. The culprit M.A.S.S. thought insists ignition timing is fine but i am not convinced.
Vehicle is running sluggish, acceleration is tepid, and the vehicle is heating up more than normal, (all symptoms of a classic "retarded" ignition timing). Fuel economy has crashed to 7kmpl from the usual 12kmpl i used to get.
What i seek: Being a distributor-less setup, can someone share how to go about checking the G13B's timing? Also what are the IGN timing values for the G13B engined SWIFT's please ?
Thanks in advance for all the help.
arjab is offline   Reply With Quote
Old 24th October 2016, 17:04   #2
Altocumulus's Avatar
Thanked: 503 Times
Default re: Timing belt replaced - Now, ignition timing issues
Originally Posted by arjab View Post
Hi Team,
G13B distributor less ? I don't think so. Have the position of the distributor checked. I had a similar issue with my esteem.
Altocumulus is offline   Reply With Quote
Old 24th October 2016, 17:22   #3
Sankar's Avatar
Thanked: 2,908 Times
Check the timing using a timing light on the marking on crank pulley. Works the same for your distributorless setup.
If they have messed up the timing belt installation it would affect not just your ignition timing but your valve timing would also be off and can cause issues that you report. It should pop a light on the cluster but it may not, since the 1.3 is not OBD compliant you will need the suzuki diagnostic tool to check the valve timing. Check the MASS workshop manual for correct values.
Take it to another garage with expertise if you have a choice, they can open the belt cover and check the alignment marks on the crank pulley and cam sprocket and check whether the marks line up as it should. If it does then timing is not the issue.
Sankar is offline   (2) Thanks Reply With Quote
Old 25th October 2016, 20:10   #4
Sankar's Avatar
Default Re: Timing belt replaced - Now, ignition timing issues
Swift's G13 is distributorless, Esteem MPFI has distributor like you said.
Sankar is offline   (1) Thanks Reply With Quote
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Timing (cam) belt vs chain sbasak Technical Stuff 33 10th November 2009 16:00
Lancer diesel Timing belt Tensioner - Help! dilipkumar7278 Technical Stuff 6 9th November 2007 15:18
Trouble after timing belt change hamadrayad Technical Stuff 1 6th November 2006 20:05
Changing the Timing Belt .. ?? khaadu75 Technical Stuff 5 5th February 2006 19:38
