Old 15th October 2006, 11:55   #1
satish_appasani's Avatar
Thanked: 45 Times
Default Help: Palio AC not working
Since last week, AC in my 2 years old Palio D stopped worked. When the AC is switched on, there is no chilled air coming out but there is hissing sound like there is some leakage. Blower seems to be working fine.
Yesterday took it to Anuroop in Hyderabad and they felt Cooling coil to be the culprit. They want me to leave the car for a complete 3 days with them to identify and fix this problem. If the whole cooling coil has to be replaced, the part alone costs RS. 8000. Later i took it to a mechanic i know and specialises in Fiat cars. He mentioned that replacing a few pipe lines in the coil may solve the problem along with filling the coolant gas.
Any suggestions on what i should do?
Thank you
satish_appasani is offline   Reply With Quote
Old 15th October 2006, 12:41   #2
airfoil's Avatar
Thanked: 67 Times
Three days to diagnose and fix an AC problem is beyond absurd!
Satish, I suggest you take your car to the AC mech on the Lower Tank Bund road and have him check it out as well.
airfoil is offline   Reply With Quote
Old 15th October 2006, 22:44   #3
Thanked: 655 Times
A hissing sound from inside the dash, is usually caused by a leak in the cooling coil. I got my cooling coil changed just 45 days ago. Yo have a choice between a Subros coil-4k, an imported equivalent-4.5k and the imported OE coil, which is about 5.5K. I know this cos my classmate is one of the biggest auto parts retailer here. I got the Subros coil and my AC is working fine. Replacement and gas bill was 1.8K.
I really don't think a few of the pipes alone can be changed and it may be an attempt to aluminium weld the coil. Not a good idea at all.
jyobeb is offline   Reply With Quote
Old 15th October 2006, 22:55   #4
Thanked: 45 Times
Thanks Jyobeb for the info.
Is Subros OEM vendor for Fiat for Cooling coils? What brand is the original coil that comes with the car? What brands are the one that cost 4.5 K and 5.5 K?
Urgent: Fiat Palio 1.2 Radiator Fan Not Working extreme_torque Technical Stuff 13 27th May 2010 12:01
Help! Baleno AC not working after car stalled in water. aaggoswami Technical Stuff 19 20th September 2009 22:56
pls help - speakers not working. manaa45 In-Car Entertainment 20 4th March 2008 10:16
palio 1.2: starter not working properly... amitverma Technical Stuff 14 3rd April 2005 00:34
