Old 5th November 2016, 23:45   #16
sam_sant2005's Avatar
Thanked: 154 Times
Default Re: The correct way to pour engine oil ('Aha!' moment inside)
I feel everyone just got excited on this thread. This may be the right way but this method makes the opening further away from the rather small opening we usually aim at. For eg pouring tropicana into a small glass or pouring oil into an engine where reach is limited, what would you prefer? Reaching the opening with the neck of the bottle or think of splash?
Imho hence the correct way may not be correct always. It has an advantage agreed.
sam_sant2005 is offline   (2) Thanks Reply With Quote
Old 21st November 2016, 14:43   #17
Rehaan's Avatar
Thanked: 23,077 Times
Good point.
In the case of pouring oil, I don't know if you're still expected to use a funnel -- which would certainly make things easier as it both raises the position of the opening & widens it.
Warning : Do NOT pour in the entire fork oil bottle! hellmet Motorbikes 18 31st March 2015 11:43
Bolero VLX CRDe 2010 - blanc pour la paix (White For Peace) blackhawk100 Test-Drives & Initial Ownership Reports 16 31st May 2010 17:47
