Old 24th October 2006, 10:02   #16
nogutsnoglory's Avatar
yeah...they replaced a shim in the carb which had worn out... but this was done in the prior service and had not solved the problem of jerking....
nogutsnoglory is offline   Reply With Quote
Old 24th October 2006, 17:31   #17
santhoshx's Avatar
Originally Posted by BMW
timing must have been advanced by 2 degrees to cater to high octane value of LPG.
Can you provide detailed info on this, I am using LPG for sometime but this is a new info for me
santhoshx is offline   Reply With Quote
Old 24th October 2006, 18:38   #18
BMW
BMW's Avatar
santhoshx, which car do you have and what model?
BMW is offline   Reply With Quote
Old 24th October 2006, 18:49   #19
Jaggu's Avatar
Thanked: 8,694 Times
shim that was replaced, was it a rubber thingie?
and good diagnosis vacum advance tubes are notorious with the carbed cars and they tend to play havoc with timing
wrt advance timing, what i gather is maybe for better response with LPG the guys who instal usually advance to better the response
Old 25th October 2006, 09:26   #20
santhoshx's Avatar
its a 1999 Zen LX fitted with a "Star Gas" LPG kit.
Old 25th October 2006, 11:01   #21
BMW
BMW's Avatar
santhoshx, make sure that the timing of your car is advanced to 12 degrees. The normal setting for petrol is 10 degrees.
Old 25th October 2006, 11:42   #22
Rice_tuner's Avatar
Thanked: 13 Times
i'm running 12 degrees on my zen...does help provided u use higher octane fuel (i use 91)
cheers.
Rice_tuner is offline   Reply With Quote
Old 25th October 2006, 12:50   #23
BMW
BMW's Avatar
Yeah that's right. 10 degree setting is required for 87 octane fuel. For higher octane fuel its better to advance timing by 2 degrees.
Old 26th October 2006, 17:47   #24
santhoshx's Avatar
Thanks , I will check this out with my workshop and let you know their comments
Old 27th October 2006, 02:00   #25
ankitahuja's Avatar
Thanked: 46 Times
Question Higher octane, higher degree?
cheers.
About what you said, a little off topic but if I use 93 Octane then do I further advance the degree on my car? I drive a OHC and use Speed 97
Old 27th October 2006, 09:31   #26
viper's Avatar
Thanked: 9 Times
You cannot advance the timing on your car it is controlled by the ECM. They are referring to Carburetted cars.
Viper
viper is offline   Reply With Quote
Sputtering Toyota Corolla paras211 Technical Stuff 22 29th July 2009 09:04
Sputtering exhaust note etchemkay Technical Stuff 14 18th April 2007 19:06
No more ZEN for Zen Lovers abhibh The Indian Car Scene 65 8th May 2006 17:17
Used Zen vs new Zen shuvc Hatchbacks 12 18th August 2005 19:16
E-Zen & B-Zen.... MustangMan The Indian Car Scene 3 2nd July 2005 21:27
