Thread Tools
Old 28th October 2006, 15:30   #16 (permalink)
vebmetal's Avatar
Just noticed today that the sound is very noticeably lower when the car is cool... for about 20-25 minutes this morning there was almost no noise, but after that it became very loud...
please... any help?
vebmetal is offline   Reply With Quote
Old 28th October 2006, 19:01   #17 (permalink)
Pankaj401's Avatar
Could it be that the self-adjustment mechanism of the disc brakes is shot?
Pankaj401 is offline   Reply With Quote
Old 29th October 2006, 13:04   #18 (permalink)
vebmetal's Avatar
what does that mean?
Old 4th November 2006, 01:08   #19 (permalink)
Z_addict's Avatar
I'd recommend you stick with OEM brake pads. Most modern day brake pads come with a Hardware Kit (Anti Rattle/ Squeal pin/kit) that are built to specs with the Disc rotors. The "cheen-cheen" in tech speak is referred to as "Brake squeal" due to the pads being "glazed". You have not mentioned the miles/Kms on your odometer. Depending upon the condition of your Brake Pads they would need to be " Resurfaced" and the rotors would need to be "machined" on an "On Car or Off Car Brake lathe".
Z_addict is offline   Reply With Quote
Old 4th November 2006, 20:45   #20 (permalink)
wolfinstein's Avatar
No question of glazing ..! All pads OEM or Aftermarket are roughend with Sandpaper before being installed..! + Even if they are not a few spins will rough them
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 25th July 2007, 18:20   #21 (permalink)
Default Screeching sound while braking
Note from mod - Threads merged.
I'm newbie here and am facing a problem with my Indica DLX (2004) model. Around 6 months back, I started to get a strange screeching sound (as that of metal rubbing against metal) whenever I braked so I immediately took it to Concorde motors (Dairy circle) where I was informed that the brake pads are worn out and need replacement.
I got the brake pads replaced but 1month back the sound reappeared and as the car was due for a service so I sent it Concorde motors (JP Nagar). However, I was informed that due to faulty alignment of brake discs, the disc has worn out slightly and though the damage is not serious but we recommend gettting the brake pads and discs changed.
I got the discs replaced and when I got the car back, the strange screeching sound while braking (as metal rubbing with metal) had altogether dissappeared and I was one happy guy.
However, the same noise reappeared last week and after rains. I'm thouroughly confused as to what exactly could be the problem. It would be great if the experienced and expert bhpians could help me out
destroyer0690 is offline   Reply With Quote
Old 25th July 2007, 21:20   #22 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Try a reliable workshop (not dealer) and clean the caliper assembly and see if the sound goes off, it might be just some dirt in the assembly especially with rains and all. If the brake pads are worn out again, then there seems to be a alignment issue with the disc fitting.
How many kms have you driven after the pad replacement?
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 25th July 2007, 21:40   #23 (permalink)
vivekiny2k's Avatar
Location: Loveland, OH (cincinnati area), jabalpur, chennai
noise also appears if there is no insulation (grease/padding) between the calipers and the pad. even is the pads are new. this has to be taken care of while installing the pads.
__________________
______________________________________
with great power, comes great responsibility.
bigger the car, longer the cleaning time.
vivekiny2k is offline   Reply With Quote
Old 26th July 2007, 16:17   #24 (permalink)
As the Brake pads were also cahnged along with the Disc (last month) and I have driven only 500km since then
Originally Posted by n_aditya View Post
This has already been discussed before.
The earlier thread primarily focuses on what after market brake pads were used and its ill effects which definitely is not the case here which made me dig deep in to what other reasons could be there for such a noise and thus the new thread.
Old 26th July 2007, 16:39   #25 (permalink)
While I do not think this is a case of bad service (because things are all right as soon as you get the vehicle back), there is likely to be a chance that something else has not been taken into consideration while fixing the problems.
It is likely that dust / something else has got into the pads during the monsoons.
Since several people are complaining about service at Concorde, you should try a different TASC.
__________________
When the going get tough, the tough get going!!
Old 26th July 2007, 16:48   #26 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Check if your front wheels are free, there will be minor resistance but when you turn the wheel by hand and leave it (force is required) it should rotate atleast one or two times. If its too tight then you have a stuck caliper and it needs attention. Usually a good overhaul will set things right.
500 km is way too short for wear to happen, so first determine if its worn out. You can inspect the pad yourself at workshop, once you remove it from calliper. A good pad will have even wear (flat) and will have atleast 5 mm of pad on top of the metal.
Suggest you stay with the car and see whats happening, will be a good learning also.
__________________
Old 31st July 2007, 22:56   #27 (permalink)
autozealot's Avatar
OT:
Hi all,
Where can I get OE Brake discs, pads, shoes for my Qualis in Mumbai. Are these available over the counter at Shinrai? If not, where can I buy it from?
Help out.........
az
__________________
<<<<<---- USE DIVERSION ---->>>>>>
autozealot is offline   Reply With Quote
Old 3rd August 2007, 21:41   #28 (permalink)
autozealot's Avatar
Anyone ???
__________________
Old 4th August 2007, 11:46   #29 (permalink)
Don't know about OEM, but you can get good aftermarket from anygood spare shop, Check RANE, I found them pretty good.
__________________
Old 5th August 2007, 17:55   #30 (permalink)
Post Noise from brakes of 2006 baleno
Guys i recently noticed a very strong noise(like the one u get....wen u try to pull the table or a chair)from my baleno.This problem usually occurs when u apply sudden brakes while parking the car....or once u pull the handbrake before the car is full stationery.So i went allianz automobiles in south delhi.First the service advisor told me its normal and is due to water....(coz of rainy season..but since i pursued him ....he got it checked in front of me...the mechanic replied...that the BRAKE CYLINDER of Right Hand Side tyre is worn out...so i asked him to replace it coz the car is still under warranty.....at first he replied that the part is out of stock...n then said...it would be available ina couple of dayz.....n wud cost 2200 bucks....
i got a shock since he told that Brake Cyliender does not come under warranty.....
is it so......n what r reasons for the problem that occured......coz i drive the car extremely carefully....n have jus covered around 14000 kms....
do u think writing to maruti wud solve the problem......i also have a doubt that is it really the problem of wheel cyliender or something else...help me folks....i need ur help...
ashishjhamb is offline   Reply With Quote
Thread Tools
Vendor quote: "The key for good sound quality is the way its installed" harmon_bro Ask the Gurus 36 26th March 2008 11:12
Looking for info on good "Resorts" or "Home stays" in Madikeri lohithrao Route / Travel Queries 2 14th September 2007 11:28
Audi RS5 "M3 beater?" to be launched early next year "PICS" highwayblaze The International Automotive Scene 9 18th May 2007 01:59
"Pinking Sound" in my clutch!!! stevie Technical Stuff 2 1st December 2006 10:50
"welding" sound DCEite Technical Stuff 9 22nd July 2005 14:15
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
