Closed Thread
Thread Tools
Old 18th October 2006, 02:04   #1 (permalink)
Zappo's Avatar
Question Where is the water coming out of?
Since last two days I am noticing something that has me a little worried. After parking the car in its slot once I reach office, I find that water is coming out from a pipe hanging below the engine bay. I know for sure this has to do with the AC. As soon as AC is stopped the water dripping also stops (its a little more than "dripping" actually).
Now, I never noticed this before yesterday! I am worried whether this is absolutely ok or is there something wrong? Have you guys seen this happen with your cars?
I know the following...
1. Since a pipe has been provided it is meant to drain out fluid/water. Although whether that is a natural drainage or under some sort of a problem is the worry.
2. I have seen those luxury AC buses with roof mounted AC unit at the back have a metallic bent pipe which drains out water at times when the AC is running. So there are some parallels avaialable. But again whether that is natural is the question.
What about you people? Have you seen this happen with your cars? Do let me know... if there is a problem I will need to take the car to the service station and get the AC checked lest the AC completely conks off.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline
Old 18th October 2006, 02:49   #2 (permalink)
This is natural alright....CONDENSATION....the condensed water has to be released & thus the drain pipe provided. You should be worried if you do not find any water dripping when the a/c is on or just turned off with the vehicle in a stationary position, if not, the drain pipe is blocked & you need to clear it asap.
__________________
Manish
mb_jg is offline
Old 18th October 2006, 07:54   #3 (permalink)
Rudra Sen's Avatar
What Zappo brother? Too much consumption of sweet during puja or what?
This topic has already been discussed (Water drops after using AC in esteem). Thread closed.
Rudra Sen is offline
Closed Thread
Thread Tools
Help ! Baleno under water shuvc Technical Stuff 197 6th December 2007 12:38
Water Leakage ~ H O N D A ~ Technical Stuff 20 4th October 2007 10:52
Water from AC dev Technical Stuff 15 10th May 2005 14:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
