Old 20th October 2006, 18:21   #16
viper's Avatar
Thanked: 9 Times
Originally Posted by pillainp
OK.
Today my Swift was showing exactly half-tank (by the gauge), so I went a filled 10 litres.
After that the gauge has risen to just above the 3/4 level.
So your guage is more or less accurate, since 1/4 tank = approx 30ltrs.
Viper
viper is offline   Reply With Quote
Old 21st October 2006, 07:45   #17
goldsun's Avatar
Originally Posted by ravibhat
Once needle points "E" still 5 to 7 ltr fuel will be left, I always top it up once it reaches cut off, top up is always around 2 ltrs, I am using Shell premium which gives really good pick up compared with other trusted bunks in bangalore, this is my experience so far. Swift's Fuel gauge is mis leading for sure, since I always fill full tank always i an calculate FE every single time and its 11.5 without AC constantly. On higways its 16+ always.
I too am using Shell Super (Premium). It is good. I get an average of about 11.25 kmpl with AC always in city traffic. It is 14.5 kmpl on the highways, again with AC always.
I once tried with Speed 97, the experience as to engine smoothness and pick up was very good, but have not really checked FE.
goldsun is offline   Reply With Quote
Old 21st October 2006, 10:18   #18
MC Mayank's Avatar
Guys my earlier question -
Is it a problem leaving the car out to dry with full tank for over ten days?
MC Mayank is offline   Reply With Quote
Old 22nd October 2006, 07:56   #19
goldsun's Avatar
Post
Check out this post
http://www.team-bhp.com/forum/techni...ight=dos+donts (Long-term Parking : Do's and Don'ts)
where it is suggested not to leave the fuel tank empty. I suggest to have 3/4 of the tank filled up.
Old 28th October 2006, 11:00   #20
vikram_d's Avatar
Thanked: 940 Times
Well the true reason for the swift's fuel gauge to behave oddly is because of the shape of the fuel tank. It is shaped very slightly like the figure of an hourglass. So for the first 1/3rd part needle drops down slowly. For the 2nd 1/3rd it drops fast. And for the last part slows down again. I fill up when the fuel guage is exactly at E and fill it all the way till I can see it and not faced any problems till now.
Swift Diesel: Engine oil indication remains on till 3200 rpm narry Technical Stuff 8 24th February 2010 21:09
Is this the indication to change the battery ? zenopio Technical Stuff 9 30th July 2007 22:21
Seat belt warning indication Surprise Technical Stuff 18 29th July 2005 15:50
Tyre pressure indication on the sidewall!! Shan2nu Tyre & Alloy wheel Section 11 7th February 2005 15:37
