Old 19th October 2006, 04:35   #1
Thanked: 26 Times
If the gearchange becomes tougher due to airbubbles in the clutch hydraulic fluid, bleeding the clutch will solve the problem..right?
Now, the clutch fluid is a continuous medium extending from the fluid reservoir through the slave cylinder, master cylinder etc..so if you just open the top cover of the fluid reservoir (without doing any bleeding), is there a chance for the air bubbles to escape?
I did just that when the gearchange got a bit tough..and it became smooth again (I'm surprised). has anyone noticed such a thing before?
Thanks for your inputs..
reji
philipreji is offline   Reply With Quote
Old 19th October 2006, 09:35   #2
Pankaj401's Avatar
I have a Bowden cable-type clutch hence no idea. But I tend to think that the clutch fluid would be too thick to let the air bubble escape easily.
Pankaj401 is offline   Reply With Quote
What is Brake bleeding???? fiery enzyme Technical Stuff 21 8th July 2013 12:03
DIY Gravity Brake Bleeding honeybee DIY - Do it yourself 12 13th October 2011 15:00
Hayden takes pole at Australia to "STOP THE BLEEDING". turbo_v12 Int'l Motorsport 9 17th September 2006 19:59
Baleno Brake Pads bleeding me dry Puffdamgcdragon Technical Stuff 17 11th August 2006 13:19
