Old 23rd October 2006, 10:39   #1
Speedme's Avatar
Need help with a wierd sound coming from the timing belt side of the engien, Showed it to the local mechanic as per him its either the crank pulley or the water pump but I am still not convinced with his feedback.
Its a constant moving metal noise at lower RPM and becones less sbutle at higer RPM's... What can it be....
Rgds
Speedme
Speedme is offline   Reply With Quote
Old 23rd October 2006, 10:48   #2
viper's Avatar
Thanked: 9 Times
Its a bit difficult for anyone to help you out without hearing the sound. Any reason you doubt the mechanic. Normally it would be the timing tensioner or water pump if the area you are saying is correct.
Viper
viper is offline   Reply With Quote
Old 23rd October 2006, 11:04   #3
Speedme's Avatar
Yes i am pretty sure of the area and to have a rough idea of the sound its close to the sound made by a loose engien block. I just doubt the crank pulley noise. Can it be possible??
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Query regarding Opel Astra. nisweth Technical Stuff 4 17th November 2004 12:36
Opel Astra HPC amit The International Automotive Scene 13 27th September 2004 10:42
Opel Astra GTC amit The International Automotive Scene 7 21st August 2004 13:57
