Old 29th January 2017, 18:17   #1
kapilsharma80's Avatar
Thanked: 25 Times
Default Figo 1.4L Diesel: EGR error suddenly pops up
Last week I had given my figo at ford body shop to get some work done on the back bumper.
Today when i took the delivery, i noticed the check engine light and asked the Ford team to scan the fault.
The following two errors popped up and was deleted by the technician. I am sure that deleting the error doesnt solve the issue hence i need your advice as to how should i follow up on on these egr error codes:
Figo 1.4L Diesel: EGR error suddenly pops up-img_3772.jpg
Figo 1.4L Diesel: EGR error suddenly pops up-img_3773.jpg
kapilsharma80 is offline   Reply With Quote
Old 29th January 2017, 18:30   #2
vishy76's Avatar
Thanked: 1,018 Times
Default re: Figo 1.4L Diesel: EGR error suddenly pops up
A faulty EGR valve should be the culprit if the light comes back on.
Watch out for
-abnormal idling
-a tapping noise at rpms slightly above idle
-stalling when the engine idles
If the light doesn't come back on and you don't experience these symptoms then it may be some dirt stuck in the valve itself which could have triggered the error and is now gone.
Cheers,
Vishy76
vishy76 is offline   (4) Thanks Reply With Quote
Old 29th January 2017, 18:32   #3
Thanked: 1,569 Times
My Figo Diesel (now at 83XXX Kms) had an EGR malfunction and used to stall under closed throttle idle(when the Odo was at 70xxx Kms). Ford asked for about 15,000 rupees for a new EGR unit. I blanked out the EGR using a $ 5 piece of metal sold on Ebay. All good so far.
Cheers,
Jay
JayPrashanth is offline   (3) Thanks Reply With Quote
Old 29th January 2017, 18:38   #4
Thanked: 25 Times
Thanks Vishy76 and JayPrashanth for the inputs... will check the symptoms
kapilsharma80 is offline   (1) Thanks Reply With Quote
EGR system - What's it purpose & when does the EGR valve open/close? rranjith_kum Technical Stuff 60 14th August 2017 20:15
Hyundai Elantra: EGR Error code 402 (Excessive Air Flow) stable rock Technical Stuff 6 22nd October 2014 14:08
Pioneer Head Unit Errors. Error 11 and error 17 in pioneer MP3 rajivanoj In-Car Entertainment 32 10th December 2013 17:07
The Bonnet Pops Open!! ph03n!x Street Experiences 5 21st July 2008 18:10
Clicks and pops and whines. Help !! d.kiran In-Car Entertainment 33 16th October 2007 17:06
