Closed Thread
Thread Tools
Old 25th October 2006, 14:22   #1 (permalink)
Raajiv's Avatar
Guys,
My car is seriously down with a major problem which unfortunately the Maruti Guys are not able to resolve.When ever,braked in neutral at speeds of 100 Km/h the car engine stops running and i have to start all again.The maruti guys have replaced the clutch gasket,engine head gasket but still the problem persists.
Guys please help me as the problem is becoming very serious and i am facing hell a lot of problem when travelling.
Raajiv is offline
Old 25th October 2006, 15:09   #2 (permalink)
nitrous's Avatar
Call Krupesh Patel of Electra automotive at 9884049268.
He can help u out.
__________________
hindu.com/mp/2008/08/25/stories/2008082522220200.htm
nitrous is offline
Old 25th October 2006, 15:28   #3 (permalink)
viper's Avatar
Originally Posted by Raajiv
Guys,
Hey,
For starters why the hell would you put the car in neutral @100kmph speeds are you looney. Have you not heard of engine braking. Coming back to your point do as Nitrous suggested.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now
Old 25th October 2006, 15:53   #4 (permalink)
Raajiv's Avatar
Viper,
When i brake from 100 normally , i shift to neutral and then brake then i shift it a lower gear for low speeds in case of any mad animal or a two wheeler crossing the road.
Raajiv is offline
Old 25th October 2006, 15:59   #5 (permalink)
vid6639's Avatar
By shifting to neutral at that high a speed your going to wear out your brakes pretty soon.
You should hold it in the gear and let the engine assist in braking and then shift to a lower gear when the speed reduces accordingly.
Also by shifting to neutral you will not have control of your vehicle.
Pls. try and avoid it.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline
Old 25th October 2006, 16:04   #6 (permalink)
viper's Avatar
Thank you Vid6639, Raajiv please change your driving/braking style. You will thank us big time. Please gradually downshift gears if you need to slow down. Use brakes as less as possible to increase life of both pads and tyres.
Viper
__________________
viper is online now
Old 25th October 2006, 16:18   #7 (permalink)
rks
rks's Avatar
As pointed out, do not shift to neutral at high speed --use engine braking. Secondly, if by any chance, your engine switches off while the car is moving and refuses to restart, do not switch off the ignition till the car has stopped -- your steering may get locked (I don't know if the steering lock happens only if you pull out the key, but why take a chance?).
rks is offline
Old 25th October 2006, 20:34   #8 (permalink)
drifter's Avatar
Whatever people have said is true...
coming to the point....the engine should not be shutting down when go into nuetral...is your car idling properly at stand still?
EDIT: Just off the top of my head, has the carburettor been cleaned recently? If not, clean it and have it properly adjusted.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline
Old 26th October 2006, 06:52   #9 (permalink)
mithun's Avatar
It's a cardinal sin to shift to neutral at 100 KM/H and that on an Omni !!! Never, ever commit such blunders and change your driving style...
And I'm wondering why you replaced clutch gasket,engine head gasket ? If that is solely due to the above mentioned problem then I would categorise you as a half-wit !!!
And you've drawn a blank on the vehicle details also...
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
mithun is offline
Old 26th October 2006, 10:45   #10 (permalink)
humyum's Avatar
I totally agree with mithun.Why the hell have u replaced clutch,gasket,engine head gasket for the problem u have above mentioned?
All the above parts replaced have got nothin to do with engine shuttin down.
Carburator seems to be the problem here.
__________________
Life is a lemon and i want my money back!!!!
humyum is offline
Old 26th October 2006, 12:30   #11 (permalink)
esteem_lover's Avatar
Guys,
man, raajiv, do not take your real car to be the lightning mcqueen. there is so much you have to learn in driving before you touch that car of yours again. please do take the advice given to you so far very seriously. no sane person would disengage gears at that speed, whether he has a merc or a 800. please always use the brake keeping the gear engaged & start downshifting as you brake.
your problem of the engine shutting off could be due to the vaccum pipes leaking. i am not an expert though. please contact a good mechanic. where do you live in chennai? pm me & i will suggest somebody for you. be careful, man.
__________________
Advertisements contain the only truths to be relied on in a newspaper. - Mark Twain
esteem_lover is offline
Old 26th October 2006, 15:06   #12 (permalink)
rjstyles69's Avatar
Viper
with what Viper says. Dont you think its madness and totally unsafe to shift to neutral at that speed? Please drive safe and use gear shift with min. brakes to reduce speed unless you have a lunatic trying to cross the road.
rjstyles69 is offline
Old 27th October 2006, 09:31   #13 (permalink)
Raajiv's Avatar
Guys,
Thanks for all your advice. i Would seriously take it. As i have started driving just 6 months back,think it would not be that diffcult to change my driving style.
Now coming back to the problem,the problem has disappeared after cleaning the carb.Thanks for all your advice.
Raajiv is offline
Old 27th October 2006, 11:05   #14 (permalink)
viper's Avatar
Guys,
Good your problem i ssolved now go back to the Maruti service centre and fire them for taking you for a ride.Make a formal complaint in writing saying they could not solve your problem changed xyz parts when it was a dirty Carb and ask for a refund.
Viper
__________________
viper is online now
Old 27th October 2006, 11:09   #15 (permalink)
drifter's Avatar
Good to see it solved....
Drifter
__________________
drifter is offline
Closed Thread
Thread Tools
Wanted:: Maruti Omni DRC Shifting gears 0 23rd April 2007 22:26
Maruti Omni.... vincentt The Indian Car Scene!! 35 26th August 2006 06:45
New Maruti Omni (Van) lamborghini The Indian Car Scene!! 67 17th April 2005 21:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
