Old 8th February 2017, 02:02   #16
AbhiJ's Avatar
Thanked: 465 Times
Default re: Bent key - Now what?
Originally Posted by raksrules View Post
Not sure, I think they meant that heat the metal where it is bent and then straighten it out. I will still see what those hardware store guys can do rather than trying anything myself.
Forget the heat.
Get access to a sturdy Vice with nice flat jaws .. Get a few sheets of paper/thin metal sheets to adjust where and how much you need to clamp and use your common sense.
This is a 10 minute job, tops.
AbhiJ is offline   (1) Thanks Reply With Quote
Old 8th February 2017, 09:14   #17
Mr.Boss's Avatar
Thanked: 2,410 Times
Basic science, metal is a good conductor (of heat) and the amount of heat required to make the metal portion soft is more than sufficient to melt the plastic portion.
Mr.Boss is offline   (1) Thanks Reply With Quote
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
Bent car key, need spare ByDesign Modifications & Accessories 22 21st July 2011 15:51
"King of Key" - Guess the car or bike from its key! vrprabhu Shifting gears 67 24th April 2010 18:16
help with bent rim passionpurple Tyre & Alloy wheel Section 21 24th November 2005 21:31
Bent alloys drifter Tyre & Alloy wheel Section 16 22nd September 2004 00:10
