Closed Thread
Old 27th October 2006, 21:16   #1
Thanked: 140 Times
Question
My WagonR has done close to 23K and its almost 3 years now. I have stock JK Tyres with tubes in steel rims. I had couple of punctures in three years and one of the tire wall is also damaged as i went over a pothole at over 80KMPH speeds on a highway. I use that tire as a stepney. Visually other tires look good. Recently i got a puncture again and took it to a local repairwalla. He said that the tube was "weak" and should be replaced. On checking the tube of another tire (which already had 2 punctures)he said those should be changed too. He said on low speeds it is ok to use repaired tubes, but not on highways, where car runs at high speeds for long duration. Is this true? If yes, please suggest what tubes should i get (make)(i donít want to compromise with safety oif my family). Anyone knows any good place in North Bangalore, where i can replace the tubes with good quality ones and also get alignment and balancing done?
hyper-VTEC is offline
Old 27th October 2006, 22:00   #2
Vid6639's Avatar
Thanked: 21,046 Times
Instead of replacing the tubes you can consider changing to tubeless tyres. Each tube will cost you roughly 300-400rs.
If you still have tread on your tyres you will get a decent rate for your old set and you can upgrade to tubeless which will offer you better ride, handling and will not deflate immediately on a puncture. Tubeless tyres are much more safer.
A good bridgestone tyre shop in north bangalore is Shivas near ramaiah college. they also do alignment and balancing.
If you do wanna change your tyres you should go for Bridgestone turanza ER-60. These offer a good ride and decent handling.
Michelins are also good but are difficult to find a reliable dealer here in bangalore. i have seen large variation in prices for michelin whereas Shivas offered me the best rates compared to any other shop.
Vid6639 is offline
Old 27th October 2006, 22:19   #3
Rudra Sen's Avatar
Thanked: 4,288 Times
At TBHP, we insist members to use search function. There are two clear benefits:
1. You find the right thread.
2. You get to know the forum better.
Check here (Don't tubes have speed ratings???) if it's ok with you. Otherwise, there are 29 pages of tyre related thread.
Thread closed.
Rudra Sen is offline
Closed Thread
Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwill! jfxavier Technical Stuff 26 13th January 2015 10:49
Mitsubishi going down the tubes! GTO The International Automotive Scene 6 11th July 2012 17:25
Tubes on a tubeless tyre?? aggressive_anush Tyre & Alloy wheel Section 21 18th July 2011 15:09
Cj3b : Yes-no-yes !! DKG 4x4 Vehicles 151 3rd August 2010 09:59
Don't tubes have speed ratings??? Shan2nu Tyre & Alloy wheel Section 18 9th July 2004 23:18
