Old 17th May 2010, 10:44   #31
Gansan's Avatar
Thanked: 914 Times
For the first time I started my Alto in second gear today! The car stalled in traffic, while restarting I remembered to turn the AC off, but forgot to shift to neutral. As I always depress the clutch before cranking, the car started any way, though it sounded a bit rough. And only while shifting to first gear I realized I had cranked it in second.
Could it have caused any problems with the starter/clutch/gears?
Old 17th May 2010, 10:53   #32
clevermax's Avatar
Thanked: 445 Times
It is more of a safety feature than a security feature.
I always press the clutch before cranking - a habit taught by my instructor years back.
Which all cars have cranking prevention while the engine is running?
clevermax is offline   Reply With Quote
Old 17th May 2010, 10:55   #33
Thanked: 7 Times
A thread revived after 2 years!
Just a note on a newer innovation of the clutch lock on the Scorpio VLX: in neutral, the engine will crank and start as usual. In any gear, with clutch engaged, the starter will not crank. Depress the clutch pedal in any gear, and the starter motor runs again.
That would solve Delta Wing's problem!
And now, the most recent small car, which is yet to enter the Indian Market, the Nissan Micra also has a similar feature. But then, there is also a sign in the IP that suggest you to disengage the clutch before starting. So yeah, it is a safety/security feature.
Zoomsun is offline   Reply With Quote
Old 17th May 2010, 11:41   #34
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by Gansan View Post
For the first time I started my Alto in second gear today! Could it have caused any problems with the starter/clutch/gears?
Nope, a one-off incident means no harm done; apart from the little frustration you faced so breathe easy.
Old 17th May 2010, 18:59   #35
Gansan's Avatar
Thanked: 914 Times
Hey,thanks gpa! I presumed as much, but still some reassurance feels good!
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Headlight Levelling Feature - Is it really useful ?? akash_m Technical Stuff 43 21st March 2010 16:56
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
Really Really Interesting nikibusa Shifting gears 18 13th December 2005 15:45
