Thread Tools
Old 29th October 2006, 10:10   #1 (permalink)
chetanhanda's Avatar
Default LTFT , Ignition advance in Vtec
Guys,
1] My D16Y8 Vtec is running with a LTFT of more than zero, it shows a constant reading of 1.6 , anything more than zero is a problem.
2] The ignition advance varies between 10 to 30 degrees.. this again is too high ?
What problems should I be looking for considering that I have just got the ignition timing checked.
any suggestions what to look for ?
chetanhanda is offline   Reply With Quote
Old 29th October 2006, 12:24   #2 (permalink)
Pankaj401's Avatar
Originally Posted by chetanhanda
Guys,
The Long Term Fuel Trim should be 1 ideally. The value greater than 1 means you are running leaner. And for D16Y8 the operating value is +/- 20%.
The ignition advance at operating temperature and at idle should be 12 +/- 2 degrees BTDC.
Pankaj401 is offline   Reply With Quote
Old 29th October 2006, 14:59   #3 (permalink)
slight correction from my side ...
Its actually running with a ignition retard of 10 to 28 degrees and not advance of 10-28 degrees as reported in my earlier post
Old 29th October 2006, 15:11   #4 (permalink)
I thought the base value of LTFT should be ideally zero, LTFT is incremented if the STFT crosses the +/- 10% threshold for extended periods.
Not sure if it is 1, plz correct me if I'm wrong
..Also my STFT bank1 is indicating variation between -5.5% and +5.5 %
OK
Old 29th October 2006, 19:13   #5 (permalink)
Pankaj401's Avatar
+/- 20% on STFT would be the limit. You can find all this information in the civic repair manual available on Honda Hookup forum.
Old 30th October 2006, 23:55   #6 (permalink)
There are no trouble codes given by the ECU.. but after I still reset the codes.. the LTFT resets to zero.
It remains zero till I give it some 30-40 degrees of throttle.
It comes as 2.3 and and then goes down to a constant 1.6
Experts at TBHP have suggested I get the o2 sensor checked/AFR checked.
Could the lean condition be caused by dirty injectors.. ?
Will the following help ?
1] Put a new O2 sensor
2] Get the injectors decarbonized
3] Get the valve clarances checked
Thread Tools
Advance Happy Easter Wishes binoyb22 Shifting gears 6 23rd March 2008 10:19
Advance Porting and Exhaust Port Degree Help.....Yamaha RXZ malvechaitanya Motorbikes 6 11th March 2008 22:05
Ignition ON..! nayakrnr Introduce yourself 6 4th September 2007 21:30
ADVANCE Happy Birthday, manaa! Steeroid Shifting gears 30 16th November 2006 00:21
Relation between Ignition retard/advance and AFR chetanhanda Technical Stuff 30 8th November 2006 12:20
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
