Old 24th April 2017, 17:27   #1
Thanked: 50 Times
Default Crack in WagonR chassis
Dear Friends
I have a 2009 model WagonR clocking around 93000 Kms till date.
Recently on noticing strange creaking sound on the front left side near the wheel, i checked the underside & noticed a huge crack on the bridging panels.
Attaching a few snaps for better understanding of the issue at hand.
I would like to know, if anybody has faced something something similar & how to get it repaired.
One way would be to weld the crack but knowing the quality of welders, i have a feeling that the weld will not last long.
"J"
finiteinjustice is offline   (2) Thanks Reply With Quote
Old 24th April 2017, 21:52   #2
Mr.Boss's Avatar
Thanked: 2,384 Times
Default Re: Crack in WagonR chassis
Is that a crack on apron? We had a similar issue reported in past
http://www.team-bhp.com/forum/techni...ml#post2042619 (Suggestion Req - WagonR bumper change)
This can be repaired (apron replacement) but a little cost and time consuming job. M.A.S.S could do the job well. Don't settle for welding, that's not the right fix.
Mr.Boss is online now   (3) Thanks Reply With Quote
Old 24th April 2017, 22:05   #3
Leoshashi's Avatar
Thanked: 10,418 Times
That should be rectified immediately. IIRC, the bolt we see there is of the transmission mount, and should be repaired ASAP. It's probably this part(highlighted in the picture)
Leoshashi is offline   (12) Thanks Reply With Quote
Old 25th April 2017, 08:30   #4
Thanked: 50 Times
Attachment 1632644
Yes you are right regarding the part, looks same in the drawing. Thanks for the advice. Anyways suppose I don't repair it for another 1000 kms what are the probable implications.
finiteinjustice is offline   Reply With Quote
Old 25th April 2017, 09:02   #5
Mr.Boss's Avatar
Depends on you luck, either you may have thousands of successful miles or the vehicle may need a tow truck immediately when you crank the engine next time. I suggest not to take any risk as apron failure may lead to failure of few surrounding parts as well. Get it corrected ASAP.
Mr.Boss is online now   (2) Thanks Reply With Quote
Old 25th April 2017, 09:05   #6
Thanked: 50 Times
Yes, I am planning to get the issue checked by Maruti guys nearby today itself
Old 25th April 2017, 10:02   #7
thatfastdude19's Avatar
Thanked: 71 Times
Though the problem is probably already clear but the question that is in my mind is that how did such a crack occur?
Metal fatigue? Manufacturing defect? Rust? Other factors like an impact on a pothole or something else?
Would really appreciate if someone puts light on the cause.
thatfastdude19 is offline   (2) Thanks Reply With Quote
Old 25th April 2017, 10:05   #8
Jaggu's Avatar
Thanked: 7,405 Times
Seems like acid water from battery (sitting on top) has been flowing onto that area. Get this fixed ASAP, it is dangerous to drive around with a broken chassis. If it breaks you are looking at a huge bill, might as well bite the bullet and get it fixed now itself.
Jaggu is online now   (8) Thanks Reply With Quote
Old 27th April 2017, 15:06   #9
Thanked: 50 Times
Attachment 1632644
Check out the item no. marked 7 in the drawing below. That is where the crack is as rightly pointed out by you
Yes, thats the same problem which i faced. Actually 6 months back i noticed that the gap between the wheel & arch on the left side had reduced to the point that at some turning positions the tyre was touching the mud flaps. On checking i noticed a small bend in the bottom portion of the left apron where the crack is seen currently. At that time the problem was rectified by flame heating the portion & hammering is back in shape. Now it has cracked. It may be that due to heating of the component it became hardened due to carburizing flame which may have lead to cracking of the same.
In our part of the country, even national higways are like offroad tracks with moon crater sized potholes. The bend in the apron was probably due to impact of regularly falling in those potholes which are impossible to dodge.
Last edited by khan_sultan : 27th April 2017 at 16:04. Reason: Back to back posts -- merging
Old 27th April 2017, 15:41   #10
Mr.Boss's Avatar
Below is the answer for your query.
I wish you should have including these details in the initial post. At least now you have some peace of mind since the root cause is known. Get it corrected ASAP.
Mr.Boss is online now   (1) Thanks Reply With Quote
Old 27th April 2017, 15:53   #11
Thanked: 50 Times
Mr. Jaagu
As you have quoted, battery water is also a cause as in WagonR the battery sits right on top of the LH apron position. If there is any spillage from the battery, it will end up exactly at the position of the crack & will lead to corrosion & thinning of the metal part. This will hasten the bending, cracks etc.
This is not a case of manufacturing defect but potholes & metal fatique contribute significantly to the crack
finiteinjustice is offline   (1) Thanks Reply With Quote
Old 27th April 2017, 16:08   #12
Thanked: 50 Times
Went to Maruti authorized service centre day before yesterday. Discussed the whole issue. Two options were given to me as below:
1) Change the complete LH apron assembly. It will require, the engine to be removed, 10 days (min.) & INR 13000.00/- (approX.) to get it done. Money is not a problem but time is.
2) Or cut out the cracked portion & weld a new one. 2 days & INR 4500.00/- (appro.) to get it done. No guarantees on lasting.
Well option1 seems the right thing to do, but i came came back without doing anything. Well they said, it may hold in this condition for some more time provided the vehicle doesn't get into large potholes. Will try to put the vehicle in the garage by may end bu till that time it would probably clock another 1000 kms. Hoping for the best.
"J"
Old 27th April 2017, 16:15   #13
Thanked: 50 Times
While i was at the Maruti service centre came across another car with similar problem as mine. It was repaired 1 year back & still holding but yes the car is sparsely used unlike my case.
Managed to take a few snaps & sharing here for all to see.
Anybody noticed the welding. I see no cracks. Check out guys
Old 27th April 2017, 22:23   #14
Thanked: 120 Times
^^ Go for the cheaper option. A similar issue in my Zen was dealt with a 400 buck patch work. Just find a good welder, the previous guy messed up the part. Most ASSs use the oxy acetylene torch only. It's skill that matters.
fighterace is offline   (1) Thanks Reply With Quote
Old 17th July 2017, 16:00   #15
Thanked: 50 Times
Sorry for the delay in updating the repair status of my car.
I got the cracked left side apron of my WagonR repaired at the workshop where i usually put my car for regular maintenance.
Before putting it up for repair, i drove for approx. 1200 kms. The crack didn't develop any further in the intervening period. Here are some pics of the repair.
After the repair i have already driven my car by aprrox. another 1500 kms. Till now i have not encountered any problem.
Total cost of repair incl. servicing, alignment, balancing, floor mat change, wiper blade change, body sound rectification & several other minor issues etc. came to around INR 11000.00/-
Now how the heck did my windshield develop the crack?!! Zappo Technical Stuff 44 12th February 2015 21:35
Crack in front windshield a4_attitude Technical Stuff 52 29th May 2012 12:04
Crack on the bumper nicejits Modifications & Accessories 4 10th August 2007 15:50
silencer got a crack sankeerthreddy Modifications & Accessories 9 25th April 2007 18:59
Baleno bumper crack issue kiranpashtakar Technical Stuff 11 28th March 2007 18:26
