Old 3rd November 2006, 20:59   #16
tif0si's Avatar
Originally Posted by heelntoe
in fiats i believe there is an mpfi light that has to go off for you to crank the engine.
u are right, that light takes around 10 secs to go off and when you are stuck in traffic that light is the last thing on your mind.
tif0si is offline   Reply With Quote
Old 3rd November 2006, 22:35   #17
tif0si's Avatar
in many cases if the engine is killed on the move it is advisable to crank the engine right away as the cars with power brakes can end up in a big mess
Old 4th November 2006, 06:47   #18
goldsun's Avatar
Post
Yes, the brakes will be less effective when the engine is in off state. It is better that it is started immediately on the move.
goldsun is offline   Reply With Quote
Old 4th November 2006, 08:04   #19
BMW
BMW's Avatar
Originally Posted by tif0si
in some cars like in my palio,once u turn on the ignition and start the car and if u try to start it again the key does not turn, it has some kind of a lock i guess, coz even i tried to start the car accidently a couple of times even though the engine was running,but i could not do so as the key would not turn then i realised that the engine was running,
That's cool..
Any idea whether the same kind of feature is available for NHC as well? I don't wanna try and test it out Just curious to know from fellow BHPians who have had similar experience with their NHC or even OHC in the past.
BMW is offline   Reply With Quote
Is it necessary to wait for Glow Plug light to go off before cranking a Diesel? IndigoXLGrandDi Technical Stuff 56 25th October 2013 19:51
Are Cranking Handles Practical For Starting Old Cars? anjan_c2007 Vintage Cars & Classics in India 27 6th April 2011 01:04
Steps to take before cranking (car lying idle for a year) ssjr0498 Technical Stuff 8 28th July 2008 15:04
Palio is going very cheap currently (50K-70K cash discount) mahadev_kc The Indian Car Scene 32 2nd September 2006 03:18
Fiat India website is back.Currently under construction. merve_extreme The Indian Car Scene 60 5th May 2006 11:36
